Armbianmonitor:
I'm trying to install driver for my wifi dongle that is equipped with rtl8812bu chip.
I have been searching over the net for a few days, but have been unable to successfully install the driver.
What I tried:
I'm using latest availabel Armbian_5.75_Rock64_Debian_stretch_default_4.4.174_desktop.img
After first boot, I did apt-get update and upgrade.
Then in armbian-config, I installed "Headers, Source and Full firmware package".
then extracted
linux-source-4.4.174-rockchip64.tar.xz and
linux-rockchip64-default_4.4.174_5.75_config.xz
in /usr/src/linux-headers-4.4.174-rockchip64 directory.
After that applied the workaround found here.
"make scripts" works after without any error after above steps.
now the driver.
The dongle comes with a cd with the linux driver in it.
The drivers compiles fine,  but at the last step I get
modprobe: ERROR: could not insert '88x2bu': Exec format error
I can provide full output if required.
Next. I tried this driver:
https://github.com/cilynx/rtl88x2BU_WiFi_linux_v5.3.1_27678.20180430_COEX20180427-5959
I found this comment on this forum that says he was able to install the driver in rockpro64
although I followed basically same procedure (except building armbian myself),
The installation was not successfull.
I got
when I executed the last command
"modprobe 88x2bu"
This is what I found in dmesg
[31040.865892] 88x2bu: version magic '4.4.173-rockchip64 SMP mod_unload aarch64' should be '4.4.174-rockchip64 SMP mod_unload aarch64'
all previous command succeeded without any error.
So can anyone please help?
Let me know if I should provide any other log or anything.
Thanks in advance.
Update: Did
modprobe --force 88x2b
now if I insert the device, I get :
[ 1093.378297] usb 4-1: new high-speed USB device number 29 using xhci-hcd
[ 1093.506907] usb 4-1: New USB device found, idVendor=0bda, idProduct=b812
[ 1093.506931] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1093.506947] usb 4-1: Product: USB3.0 802.11ac 1200M Adapter
[ 1093.506961] usb 4-1: Manufacturer: Realtek
[ 1093.506975] usb 4-1: SerialNumber: 123456
[ 1093.538973] 88x2bu: version magic '4.4.173-rockchip64 SMP mod_unload aarch64' should be '4.4.174-rockchip64 SMP mod_unload aarch64'
device not working yet.
Edited by badhon_raj
Update
Armbian provides kernel headers while 3rd party wireless chip drivers are user's problem. Try to work this out with a driver maintainer - if any.
Armbian is maintained by a few, not by a hundred people.
Moved to general section since support is related for onboard hardware only.
