SecureXperts Posted March 8, 2019 Posted March 8, 2019 Hello, When I would like to start my PPP connection my Kernel says missing Module: I use the RockPi 4b with the Image https://dl.armbian.com/rockpi-4b/Ubuntu_bionic_dev_nightly.7z root@rockpi00001:/opt/LTE# pppd call gprs & root@rockpi00001:/opt/LTE# Couldn't open the /dev/ppp device: No such file or directory modprobe: FATAL: Module ppp_generic not found in directory /lib/modules/4.20.13-rockchip64 pppd: You need to create the /dev/ppp device node by executing the following command as root: mknod /dev/ppp c 108 I have created the mknod /dev/ppp c 108 but nothing changes in terms of Modules. Could you please add this module to the next build please? Many Thanks Roman
martinayotte Posted March 8, 2019 Posted March 8, 2019 On 3/8/2019 at 2:25 PM, SecureXperts said: Could you please add this module to the next build please? Expand Done ! https://github.com/armbian/build/commit/fa232d17ed1488bd19be4dbc9f7f3b174f85ef73 2
