willie Posted March 10, 2019 Share Posted March 10, 2019 I tried some steps. 1. The image is Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_server_20180209.img.xz 2, The arm box is Amlogic S905X 2+16 emmc. 3. Printf the save.log when run "ddbr" and "./install.sh". 4. It no boot when run reboot, see reboot.log. 5. I don't how to save the image to emmc,no boot from TFcard. save.log ******************************************* Done copy ROOTFS ******************************************* Writing new kernel image... 65536+0 records in 65536+0 records out 33554432 bytes (34 MB, 32 MiB) copied, 0.828127 s, 40.5 MB/s /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. done. Write env bootargs ******************************************* Complete copy OS to eMMC parted DATA ******************************************* root@amlogic:~# reboot.log aml_dt soc: gxl platform: p212 variant: 2g dtb 0 soc: gxl plat: p212 vari: 1g dtb 1 soc: gxl plat: p212 vari: 2g Find match dtb: 1 There is no valid bmp file at the given address amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 8 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet detect sadckey .... saradc - saradc sub-system Usage: saradc saradc open <channel> - open a SARADC channel saradc close - close the SARADC saradc getval - get the value in current channel saradc test - test the SARADC by channel-7 saradc get_in_range <min> <max> - return 0 if current value in the range of current channel gpio: pin GPIOAO_2 (gpio 102) value is 1 Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** card out [sd_inand_staff_init][246], debug emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 Booting... Unknown command 'unifykey' - try 'help' Unknown command 'unifykey' - try 'help' Err imgread(L252):Fmt unsupported!genFmt 0x0 != 0x3 InUsbBurn noSof emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 [MSG]mmcinfo failed! emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ** Bad device usb 0 ** Err imgread(L252):Fmt unsupported!genFmt 0x0 != 0x3 gxl_p212_v1# Link to comment Share on other sites More sharing options...
balbes150 Posted March 11, 2019 Share Posted March 11, 2019 19 hours ago, willie said: /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. Your firmware does not have a compatible kernel version. Link to comment Share on other sites More sharing options...
willie Posted March 12, 2019 Author Share Posted March 12, 2019 Hi,Balbes150, I'm glad to receive your reply. A- My box is S905X 2GB-4bit-DDR 16GB-emmc ssv6051-wifi. I need to setup canon printer and save the image to emmc, but I was in trouble and asked for help. 1, I upgrade the image file Armbian_5.75_Aml-s905_Ubuntu_bionic_dev_4.19.21_desktop_20190216.img, it can save to emmc and boot from emmc. But it can't install and setup canon MP288 printer driver. 2, I upgrade the image file Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_mate_20180203.img, it can install and setup canon MP288 printer driver But it can't save to emmc and boot from emmc. B- I have downloaded the armbian/build source code and successfully run install.sh, I have 3th issues: 1, How to configure ssv6051 wifi. 2, How to compile and package the image. 3, How to Burn Image in Batch。 Link to comment Share on other sites More sharing options...
balbes150 Posted March 12, 2019 Share Posted March 12, 2019 2 hours ago, willie said: But it can't install and setup canon MP288 printer driver. What do you mean can't install ? Write in detail what you do and what messages you receive from the system. 2 hours ago, willie said: I have downloaded the armbian/build source code and successfully run install.sh, I have 3th issues: https://docs.armbian.com/ Link to comment Share on other sites More sharing options...
willie Posted March 12, 2019 Author Share Posted March 12, 2019 root@amlogic:~# apt-get install cnijfilter-mp280series Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: cnijfilter-mp280series:amd64 : Depends: libc6:amd64 (>= 2.14) but it is not installable Depends: libpng12-0:amd64 (>= 1.2.13-4) but it is not installable Depends: libpopt0:amd64 (>= 1.14) but it is not installable Depends: libtiff5:amd64 (>= 4.0.3) but it is not installable Depends: cnijfilter-common:amd64 (>= 4.10) but it is not going to be installed E: Unable to correct problems, you have held broken packages. root@amlogic:~# Link to comment Share on other sites More sharing options...
balbes150 Posted March 12, 2019 Share Posted March 12, 2019 43 minutes ago, willie said: amd64 This package is built for AMD (x86_64) and cannot be used on the ARM platform . Link to comment Share on other sites More sharing options...
willie Posted March 13, 2019 Author Share Posted March 13, 2019 Thank you! How to install canon driver! Link to comment Share on other sites More sharing options...
