Lope Posted March 19, 2019 Posted March 19, 2019 I just installed the latest Ubuntu Bionic Image with 4.x kernel, fully updated and upgraded. On Orange Pi Zero 1.4 512MB + IO expansion kit board Armbian 5.75 Ubuntu 18.04.2 LTS Linux orangepizero 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:02:47 CET 2019 armv7l armv7l armv7l GNU/Linux `cat /proc/asound/cards` "No sound cards" In armbian-config, I enabled analog-codec, `update-initramfs, rebooted, but there's still no sound card. mocp complains there is no driver. speaker-test (starts like this) Playback device is default Stream parameters are 48000Hz, S16_LE, 1 channels Using 16 octaves of pink noise ALSA lib confmisc.c:767:(parse_card) cannot find card '0' Anyone know what the issue is? $ cat /boot/armbianEnv.txt verbosity=1 logo=disabled console=serial disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=analog-codec usbhost2 usbhost3 w1-gpio rootdev=UUID=4cf6b202-4b00-45d6-b06a-8e235506621e rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u $ cat /etc/asound.conf pcm.!default{ type hw card 0 } ctl.!default{ type hw card 0 } After the above and a reboot, I didn't have any codec modules loaded So I did this $ modprobe sun8i-codec-analog sun4i-codec $ aplay -l aplay: device_list:270: no soundcards found... $ cat /proc/asound/cards --- no soundcards --- $ ls -lah /dev/snd total 0 drwxr-xr-x 2 root root 60 Mar 20 06:04 . drwxr-xr-x 13 root root 14K Mar 20 06:04 .. crw-rw---- 1 root audio 116, 33 Mar 20 06:05 timer
guidol Posted March 20, 2019 Posted March 20, 2019 also after reboot no soundcard with aplay -l ? did you create (when aplay shows the analog audio card) a /etc/asounf.conf ?
Lope Posted March 20, 2019 Author Posted March 20, 2019 Hi @guidol Thank you I just did some more searching and found your very useful forum posts about audio issues you had with orange pi zero I did try making /etc/asound.conf as per examples on the orange pi forums, which didn't help. I'm going to see if I've got all the modules loaded. I've edited my first post with more commands and outputs. I added sun4i_codec sun8i_codec_analog to /etc/modules YES, progress!!! $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 YES!!! IT WORKS. IT WORKS!!! It's ALIVE!!!!! (demented laughter) Muahahahah Wow! I'm impressed with the sound quality!!! 2
Febs Posted December 21, 2020 Posted December 21, 2020 On 3/20/2019 at 12:47 AM, Lope said: overlays=analog-codec Hello, is it possible to listen to audio on the av socket thanks to this? Or did you have to connect anything with the gpio pins? Thanks.
