Mustafa85 Posted March 20, 2019 Posted March 20, 2019 Hi, Recently I have installed "Armbian_5.75_Orangepizero_Debian_stretch_next_4.19.20" on my OrangePi Zero . I configured both Ethernet and wifi connection but I had a problem with the wifi, my board does have an IP address but I can not connect through ssh nor pinging that IP. The connection is Ok and I can get access to internet but I can not ping from any other devices on the network (error Destination host unreachable), But I noticed that if I ping (from the orangepi board ) the host machine then I will be able to connect through ssh to that IP. I dont know if its a problem with arp last thing that I tried was to disable the network manager but I still have the same issue.
guidol Posted March 21, 2019 Posted March 21, 2019 check with nmtui your ip address - there should be a /24 at the end of the ip of your OPi Zero..... like 192.168.7.8/24 but only for the ip of your zero and not at the gateway or dns-ip I got tge same like problem, because if you enter only the ip for your zero in nmtui then nmtui will add a /32 when you do save the connection and then your zero is very "lonely"... 1
Mustafa85 Posted March 21, 2019 Author Posted March 21, 2019 Thank you very much, you save my 10 days work .... perfectly work 1
