Basically, I'm trying to get iptables to block per country:
https://daenney.github.io/2017/01/07/geoip-filtering-iptables.html
I got most of things work until getting problem on installing xtables-addons-dmks
# apt-get install --reinstall xtables-addons-dkms
Deleting module version: 2.12
completely from the DKMS tree.
Done.
Unpacking xtables-addons-dkms (2.12-0.1) over (2.12-0.1) ...
Setting up xtables-addons-dkms (2.12-0.1) ...
Loading new xtables-addons-2.12 DKMS files...
Building for 4.4.174-rk3399
Building initial module for 4.4.174-rk3399
Error! Build of xt_ACCOUNT.ko failed for: 4.4.174-rk3399 (aarch64)
Consult the make.log in the build directory
/var/lib/dkms/xtables-addons/2.12/build/ for more information.
# cat /var/lib/dkms/xtables-addons/2.12/build/make.log
DKMS make.log for xtables-addons-2.12 for kernel 4.4.174-rk3399 (aarch64)
Mon Mar 25 18:58:27 PDT 2019
make: Entering directory '/usr/src/linux-headers-4.4.174-rk3399'
Makefile:667: arch//Makefile: No such file or directory
make: *** No rule to make target 'arch//Makefile'. Stop.
make: Leaving directory '/usr/src/linux-headers-4.4.174-rk3399'
I have both kernel headers and source installed from armbian-config.
Any pointer to get correct commands to solve this problem would be appreciated.
Thanks,
From the logs it looks like that architecture definition is missing. Why and where this is pulled out ... no idea is this a problem of DKMS, kernel sources or elsewhere. Very unlikely that has anything to do with our work but there is another solution to this problem. Use build tools and recompile kernel with options you need and send changes upstream, to our kernel config, that you will not lost changes and next upgrade.
