I installed Waydroid on an Amlogic Meson GXM (S912) TV box. The SOC has a Mali-T820 GPU, and the box has 2 GB of RAM and 16 GB of eMMC. This was easy to do and Waydroid worked, but it was very slow, even before it heated the SOC to 80°C, which is probably its throttling limit. I removed Waydroid because it was too slow. I wasn't trying anything demanding. Even navigating Android Settings was ridiculously slow. This is a bit surprising because the hardware was designed for running Android. I was not running much else, just Wayfire and one or two Alacritty consoles. I don't think I was running out of memory. Is it possible to get decent Waydroid performance on other arm64 hardware?
Update 2: 6.16-rc1 works with issues.. Good news: It Loads and registers the rga, vpu [ 1.340230] rockchip-rga 20060000.rga: Registered rockchip-rga as /dev/video0 [ 1.345260] hantro-vpu 20020000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2 [ 1.345656] hantro-vpu 20020000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3 Issues: swap file is gone HDMI output not working probably more, not sure
Progress update: I managed to boot 6.6.22 with applied hantro and rkdevc drivers in the kernel, I'm not sure if this was already discovered but i found something on the 6.6.22 kernel. Hantro and some Rockchip drivers are found in the Device Drivers -> Multimedia Support -> Media Platform Devices Rockchip Raster 2D Graphic Acceleration Unit Rockchip Image Signal Processing v1 Unit Rockchip Video Decoder (on 6.6.22 this can be found in staging drivers) Hantro VPU Driver Use Reference Frame Compression for HEVC Hantro VPU Rockchip support Hantro VPU Allwinner support Current issues: No Display working, but i got ssh working enough to tell me probably what's wrong with the kernel, Now I'm going to try and do the same but this time with the 6.16-rc1 patches found in Github: Kwiboo/linux-rockchip just to see if that would work also.
@Dangrain Glad to see its working now. please do a guide on it, not only will it help other people it will also help you how to do it again in-case you forgot how to do it haha!
Hello. BTT says what BTT Pi and CB1 is same, but realy not. Dunno why i brought what board. But now I owner of this "piece of ****" So. New board, clean install v25.11.2 for BigTreeTech CB1 running Armbian Linux 6.12.58-current-sunxi64 Packages: Debian stable (trixie) armbianEnv: overlays=gpu tft35_spi extraargs=fbcon=rotate:2 fbcon=rotate:2 for screen rotation, because armbian not from btt and didn`t have feature like param_tft35_spi_rotate Next, help me to determine how to enable UARTs and I2C From BIGTREETECH_Pi_V1.2.1 Hardware Pdf UART0: CPUX-UTX CPUX-RX UART2 (May work as i2c0; uart2-pi-pins; i2c0-pins ) Pi5 Pi6 UART3 (May work as i2c2; uart3-pi-pins; i2c2-pi-pins ) Pi9 Pi10 I2C (i2c4-ph-pins; spi1-pins): PH6 PH7 (must work, i`ll think i2c4-ph overlay present) All pins present in sun50i-h616-bigtreetech-cb1-sd, but didnt have overlays for it... I wish to stay uart0 for u-boot console first uart setup for klipper connections to mcu. any help? If I understand right PH6 is 7*32+6=230 gpioinfo output line 230: unnamed input consumer=kernel line 231: unnamed input consumer=kernel
SuzSinclair replied to jock's topic in Rockchip CPU Boxes
Totally new to this system, need some help where to start and how to do it i have the RK3328, i verified this via AIDA, how can i install armbian system on this one can someone please help which are the correct images etc.. any steps would be highly appreciated. thanks Suz -
Jamie Fargen replied to iMagz's topic in Allwinner sunxi
Does this mean you have a working DTS that fixes the issue with smc starting the the other 3 CPUs successfully? -
Kunshakolime replied to sicxnull's topic in Allwinner CPU Boxes
Hi, can anyone help me with my board, I tried all 4 images from the github releases for the x96q, flashing them into sd card on windows using belenaetcher, then pluging into the box and booting it, it gets stuck at red light, the moment I eject the sd card it boots into android. am I doing something wrong or I need a specific image? -
Success! Thank you so much @Harleyyyu! It now boots perfectly off the eMCP. If anyone wants it I can write a small guide on how to do this, just to make this easier and faster for folks in the future.
@Harleyyyu great , let's follow for project and keep us updated , please
X88 RK3328 android box looking to install armbian photos attached
Werner replied to SuzSinclair's topic in Rockchip CPU Boxes
moved -
Hello @Malay, et.al, after submitting my PullRQ to the Armbian repo, I think it's best to cope first with the annotations I received from that. It complains about missing board photos, and some LLM generated blurb partly valid suggestions, partly not. The current status of Armbian's Spacemit support does not make the RV2 board a good video player: GPU support is missing and I'm pretty unsure if it's possible to include the HW video encoding / decoding feature that is in the chip. Which is 4k@30 with diverse codecs according to the chip description PDF. I am glad, that X11 framebuffer video runs and I am unsure if I can proceed here b/c I am not a video / GPU / EGL / vulkan specialist. Anyhow, thank you for the pointer to the Spacemit FAQ I did not recognize until now. While the PowerVR page from mesa3d states: "no IMG BXE-2-32" (https://docs.mesa3d.org/drivers/powervr.html), the respective Gitee repo contains closed-source BSD licensed Risc64 compiled shard objects (*.so), probably similar to the Nvida binary user space closed drivers that does the GPU support for the big videos cards. This may be worth a look, but as I wrote above, prio task is to bring the support into the Armbian tree. Best // Sven-Ola
I'm currently trying to build my own kernel for armbian bookworm, using this Github Linux-rockchip: linuxtv-rkdevc-hevc-v2 (6.16-rc1) Goal is to try and make hantro work with native mainline V4L2-Request-API to achieve zero-copy decoding and bypass the legacy Rockchip MPP. i just want to experiment the OS and the VPU it self at this point
@Dangrain If there’s no HDMI, no LEDs, and nothing at all after power-on, that usually means the SoC isn’t even loading u-boot from eMCP. In that state there are no logs to collect yet it’s failing before the kernel starts. Since the same image boots from SD, the issue is almost certainly bootloader placement or compatibility on eMCP, not the OS itself. boot using the sd-card first then try directly flashing the U-Boot to the EMCP and see if that makes it boot 🤷 dd if=u-boot.bin of=/dev/mmcblk1 bs=512 seek=64 sync (device/offset may vary by board)
@HarleyyyuI'd provide logs If I could get logs but just nothing happens, the screen stays black and no LEDs on the board turn on either. I just followed the instructions from page 1. Any idea how I could attempt to at least diagnose what's up?
Hello, sven-ola! First of all, thank you very much for your work! HDMI audio now works well on the Edge. Secondly, I'm not particularly knowledgeable about this, so please forgive me in advance for this possibly stupid question 🙂 It's impossible to implement video hardware acceleration support in the firmware, from here - https://sdk.spacemit.com/en/faqs/ ? If I understand correctly, patched versions of FFmpeg and GStreamer are needed, and they should also be integrated in firmware into the k1x-vpu-firmware and mpp . Is this possible? When playing any video (even at very low resolution), there is terrible lag. The board should easily support 4K HEVC, but it can't play 720p video properly. At the same time, the Banana Pi BPI-F3 board with similar technical characteristics copes with video 4K HEVC https://docs.banana-pi.org/en/BPI-F3/BananaPi_BPI-F3.
is there any way to increase the gpu memory? as of right now it's just sitting at 16MiB, i want to set it at 128MiB. I tried doing cma=128M but after rebooting the device it kinda softbricked it. It does boot upto the tty screen but i can't login directly using usb keyboard or ssh. Edit: i was dumb, the reason it bricked it self was due to coherent_memory being set to 128M as well, cma is fine.
http://blog.armbian.com/content/images/2026/01/githubhighlights-2-2.webpThis week’s Armbian development saw a wide range of updates focused on automation, hardware support, and workflow improvements. Key highlights include the introduction of automatic YAML target generation, expanded support for Hetzner ARM64 runners, and enhancements to the redirector update workflow with cache mirror support. Several board-specific fixes and feature additions were made, including improved power cycle handling for meson-sm1 devices and new binary files for RK35 series components. The team also advanced kernel support, notably enabling RDNA2 GPU compatibility and initial kernel 6.18 support for Ayn odin2. Continuous integration and build reliability received attention through Docker-based unit tests and improved artifact management. Overall, these changes reflect ongoing efforts to streamline development processes and broaden hardware compatibility across the Armbian ecosystem. Add automatic target YAML generation from image-info.json. by @igorpecovnik in armbian/armbian.github.io#184Add board-level extension to mask Wayland desktop sessions. by @schwar3kat in armbian/build#9268Add cache mirror support to redirector update workflow. by @igorpecovnik in armbian/armbian.github.io#189Add edge branch support to community targets. by @igorpecovnik in armbian/armbian.github.io#195Add exposed.map download step to download index workflow. by @igorpecovnik in armbian/armbian.github.io#190Add Hetzner server creation with cloud-init, swap, and configurable runners. by @igorpecovnik in armbian/actions#13Add new binary files for various RK35 series components. by @ghhccghk in armbian/rkbin#42Add regulator-boot-on to meson-sm1-odroid and -hc4 to fix power cycle during boot. by @ean365 in armbian/build#9217Add scripts/generate_targets.py to workflow push trigger. by @igorpecovnik in armbian/armbian.github.io#185Add workflow for enabling 16 Hetzner ARM64 runners. by @igorpecovnik in armbian/armbian.github.io#196arm64: enable AMD DC display controller for RDNA2 GPU support. by @igorpecovnik in armbian/build#9273atf: rk3399: fix PL330 DMA controller initialization. by @iav in armbian/build#9285Bump sm8250. by @CodeChenL in armbian/build#9180Change actions folder to actions-report. by @igorpecovnik in armbian/armbian.github.io#188Change exposed.map minimal patterns from bookworm to trixie, add forky as fallback. by @igorpecovnik in armbian/armbian.github.io#194chore: use release-signing policy for Windows artifacts. by @SuperKali in armbian/imager#87ci: add PR build artifacts with public download links. by @SuperKali in armbian/imager#81ci: use Docker containers for unit tests. by @igorpecovnik in armbian/configng#720cli: kernel-dtb: check dtc for version 1.7.2 before producing normalized dts. by @rpardini in armbian/build#9270config: arch: amd64: fix building kernel amd64 target with on arm64 host. by @rpardini in armbian/build#9271deps: update dependencies and document glib vulnerability. by @SuperKali in armbian/imager#88Enable debug. by @igorpecovnik in armbian/actions#14Enable Firefox download from PPA, drop Jammy and Oracular. by @igorpecovnik in armbian/os#424Exclude non-community trunk builds from promotion. by @igorpecovnik in armbian/armbian.github.io#193extension: grub: deploy qemu binary when doing cross build. by @amazingfate in armbian/build#9282feat: add image status warning for nightly builds and community boards. by @SuperKali in armbian/imager#83fix api change since v6.17. by @Spider84 in armbian/bcmdhd-dkms#5fix api change since v6.19. by @amazingfate in armbian/bcmdhd-dkms#6Fix uptime-kuma Docker image detection regex. by @igorpecovnik in armbian/configng#722fix: reduce board image scale and improve CI cache strategy. by @SuperKali in armbian/imager#86fix: regenerate Tauri updater signatures after SignPath code signing. by @SuperKali in armbian/imager#89fix: use any_changed output for reliable changed files detection. by @igorpecovnik in armbian/configng#725fix: use published_at for release sorting. by @igorpecovnik in armbian/community#46Framework: Add "Repeat Build Options" string at the end in case of er…. by @iav in armbian/build#9276framework: add custom_kernel_make_params extension hook. by @iav in armbian/build#9284Generate separate exposed.map patterns for stable and community boards. by @igorpecovnik in armbian/armbian.github.io#192Include community boards in exposed.map generation. by @igorpecovnik in armbian/armbian.github.io#191Initial support for kernel 6.18 on Ayn odin2. by @kasimling in armbian/build#9286mainline: bump to 6.19-rc6. by @EvilOlaf in armbian/build#9278memoize: add user feedback and configurable timeout for flock. by @iav in armbian/build#9262NanoPi R5C: Update to v2026.01; enable BTRFS support. by @okrc in armbian/build#9291orangepi5-plus: u-boot: restore vendor uboot with blobs. by @rpardini in armbian/build#9287orangepi5-plus: u-boot: use mainline ATF; bump to v2026.01; drop funky CE config options. by @rpardini in armbian/build#9261Override new yaml files - drop the code here if it works.. by @igorpecovnik in armbian/os#423radxa-e54c: board config: replace 'hacky' Wayland fix with wayland-sessions-mask extension. by @schwar3kat in armbian/build#9281radxa-zero2/khadas-vim3l: u-boot: disable LWIP. by @rpardini in armbian/build#9272refactor: conditionally hide custom image button when manufacturer is selected. by @SuperKali in armbian/imager#85refactor: standardize redis module and improve workflow reliability. by @igorpecovnik in armbian/configng#723Reload redirector after we check all mirrors. by @igorpecovnik in armbian/armbian.github.io#178Remove browsers from RISC-V desktop app groups. by @igorpecovnik in armbian/armbian.github.io#186Rockchip 6.18.y: drop upstreamed patches. by @igorpecovnik in armbian/build#9288Rockchip EDGE: drop up-streamed patches. by @igorpecovnik in armbian/build#9290rockchip64: station-m3: Enable USB type-C port. by @kasimling in armbian/build#9246rootfs: enable loong64 in qemu binfmt registration. by @igorpecovnik in armbian/build#9279scripts: use git commit date for 'edited' timestamp instead of filesystem mtime. by @igorpecovnik in armbian/armbian.github.io#177Switch Docker module to distribution maintained packages. by @igorpecovnik in armbian/configng#719Update CI documentation to reflect automated target generation. by @igorpecovnik in armbian/documentation#867Use armbian-apps config for app-specific images. by @igorpecovnik in armbian/armbian.github.io#187work-around Ubuntu Rust coreutils bug in dirname affecting linux-headers board-side compile of scripts/mod. by @iav in armbian/build#9264View the full article
so whats the status on this issue is it resolved by running the rolling forky release and using network manager ?
