  2. Today armbian-config doesn't show other kernels, it's impossible to switch. * Show only mainstream kernels on the list? => no * No other kernels available! => ok
  3. Yes, I did read that. I was also thinking maybe the decompression on-the-fly could be a point of failure. Just now, I installed USBImager and wrote the image to a uSD. No presets applied (.not_looged_in_yet) First boot went smoothly. I updated with armbian-upgrade and rebooted and all looked OK. πŸ€·πŸ»β€β™‚οΈ Since I changed 2 things (using USBImager and no presets) I can't say what helped.
  5. You need an overlay for that camera and 6.1.115-vendor-rk35xx does not have that AFAIR, older legacy 5.10 has it AFAIR. Look for something called RPi camera v1 or that sensor name.
  6. It would be interesting to compare corrupt and non corrupt cards, including partition tables, etc. Windows might be playing bad with partition tables - if one only inserts ESXi boot disk into windows machine, such disk becomes non bootable. AFAIR this is because ESXi relies on records order in the gpt table of the disk, while windows strips away blank records so that if eg second and third records are blank then windows will move the fourth record to the second place, while ESXi relies on the fourth record in a table. I personally met this issue a few years ago and it took a while to find the solution of reordering gpt table records back to restore ESXi boot.
  7. I do agree, that it doesn't. But it looks like Armbian kernel is built with arm-linux-gnueabihf-gcc Taken unalignment problem the same flag was used with which the kernel and headers were built. It doesn't help either.
  8. armbian-config : System > Storage > "STO001 - Install" or directly nand-sata-install You will get β”‚ β”‚ 1 Boot from SD - system on SATA, USB or NVMe β”‚ β”‚ β”‚ β”‚ 2 Boot from eMMC - system on eMMC β”‚ β”‚ β”‚ β”‚ 3 Boot from eMMC - system on SATA, USB or NVMe β”‚ β”‚ β”‚ β”‚ 4 Boot from MTD Flash - system on SATA, USB or NVMe β”‚ β”‚ β”‚ β”‚ 5 Install/Update the bootloader on SD card (/dev/mmcblk1) β”‚ β”‚ if you select boot from eMMC I think the installer will replace RoobiOS u-boot (and I guess Roobi Boot Menu) with Armbian U-Boot. I still need to experiment with Roobi OS (i.e. if there is a bootloader in SPI flash like on PC instead of only on eMMC). But you might want to try "boot from SD - system on NVME" and keep the Armbian bootloader on SD with the SD card kept plugged. If you install the bootloader on the eMMC likely you won't get the Roobi Boot menu anymore. About the boot priority, I guess it is written in the Radxa doc. It depends on how they configured their U-Boot.
  9. Ok, that draft was way more complicated than it should and there's an easier way, also we need to logout and login again for the extension to show. Is it a problem if we restart GNOME shell during install? Here's a better script: 1 #!/bin/bash 2 git clone --depth=1 https://github.com/fthx/no-overview.git 3 NO_OVERVIEW=$(jq -r .uuid no-overview/metadata.json) 4 gnome-extensions pack no-overview 5 gnome-extensions install $NO_OVERVIEW.shell-extension.zip 6 # Restart GNOME shell 7 gnome-extensions enable $NO_OVERVIEW in line 6, I found the following: https://github.com/brunelli/gnome-shell-extension-installer/blob/4357903be8646d940902852bf3e150f625e350e6/gnome-shell-extension-installer#L288 This is not doable in Wayland from what I read around... so this will install, and the user will have to enable it manually.
  10. No, nothing happened. When I tell gnome-extensions list it return empty. On my x86 desktop running Noble Gnome.
  11. thanks @prahal - the only image I was able to successfully create and boot from was the initial image mentioned in my original post. At that stage there was: - eMMC with RoobiOS pre-installed - NVMe with nothing on it - micro SD card with the https://dl.armbian.com/rock-5-itx/Bookworm_vendor_minimal image Because it was booting to the error message of not being able to mount mmcblk01p as the root file system, I'm guessing that means the boot sequence is eMMC, NVMe and then micro SD. So I thought I would double-check, given that I now have a working NVMe installation ... so I reburned the https://dl.armbian.com/rock-5-itx/Bookworm_vendor_minimal image to micro SD card to see if the board would boot to that before the existing OS on the NVMe drive. IT DID! Not only that but it booted cleanly (asked me to create the root password and my user account)! I had used the same image file that I had downloaded for the first installation so I really have no idea why it worked this time. Now I guess I have to work out how to transfer that to the NVMe drive ... I suspect there are plenty of Google answers for that so that's my research for next week.
  12. Hi everyone, and thanks a lot for the help. I found the solution: the problem was Windows 11 on my laptop. After writing the Armbian image, if the SD card stays inserted, it becomes corrupted within a few seconds. This happens only with Armbian and only with R3S images. I have no idea why. So, to get a proper SD card, I need quick hands to remove it immediately after the writing finishes (no matter which software is used to write).
  13. This part didn't work for you? It was cool that if I had Extension Manager running I could see the toggle turning on and off as I enable/disable. Also, I had to fully reboot to see it working.
  14. Hello, I've recently bought a rock 5B plus. I have a brand new crucial P310 nvme 1TB with the goal to boot from it. As the title says, sometimes the nvme drive is properly detected, sometimes not. (Everytime the controller is visible in lspci, but only sometimes shows in lsblk). When the drive is properly detected, I can write to it and it works fine, without issues. I've noticed that it is more likely to be detected on a cold boot (ie. if I turn off the power and come back the next day, the first time it will probably show up). I have the official radxa 65w PD power adapter (although I've also tried a lot more during the process with the same results). I tried with the official radxa debian image, and with armbian, and the results are exactly the same on both. Btw, I would like to mention that armbian noble gnome doesn't boot even from the sd card (blue led but no display output, I let it for over 10 minutes), only the minimal/iot works. I don't know what else to try at this point, I can post any info / logs you may want. Thanks!
  15. Yes, that's the idea I guess. I played around a bit, but could not enable it with the script ... yet.
  16. You don't need that. Most likely unrelated to this problem, but dd does not verify what was written: https://docs.armbian.com/User-Guide_Getting-Started/#flash-to-sd-card Did you try booting with defaults? Agree, that's not normal. We are seeing some regressions on Allwinner related Crust support to https://github.com/armbian/build/commit/e76540693522baec079ec7633a918a9168ce130c (responsible for low level power management operations) Nothing obvious, no quick solutions based from what is seen from the logs.
  17. If you build the module in question on the target machine, why do you use stuff like "ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-"? Doesn't make sense when building natively.
  18. Any luck? my tx1 is in the mail.
  19. @Nick AI tried to extract the dts from the working image, cloud you help me find any clues. Thank you. I was able to gain access to the os that works, this is the dmesg: dmesg | grep eth [ 8.550757] libphy: 5020000.eth: probed [ 8.568109] sunxi-gmac 5020000.eth eth0: eth0: Type(8) PHY ID 001cc916 at 0 IRQ poll (5020000.eth-0:00) [ 12.765916] sunxi-gmac 5020000.eth eth0: Link is Up - 1Gbps/Full - flow control off [ 12.775526] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready I also upload the pic of ethernet chip. dts.zip
  20. Yesterday
  21. That part of the instructions is clear. It's the steps involving the "wipe_part" file that supposedly erases partitions on the eMMC and the flashing of the second loader file that I can't make out. It looks like the instructions were edited to make them unusable. Nicolas has had the same issue in the H96 subforum with bad instructions and people asking for help due to the lack of clarity. I was able to make the board boot from SD card after flashing it with the YYT provided Debian 11 image, but only to Armbian Noble. No Debian distros work. When a Debian SD is inserted, the board boots then enters a systemd-devd shell with error messages about a UUID not being found. All Debian images do the same, I think it has to do with the eMMC memory not being seen because it is still formatted and not cleared. I have never seen a shell like this. Armbian Noble still boots properly, but only Noble. I need a Debian minimal distro in order to install OpenMediaVault and save my friend's files.
  22. Greetings; I have downloaded this https://dl.armbian.com/cubox-i/Noble_current_server and verified that I got what I was supposed to (ASC, SHA). I have used a brand new usbimager to install it on various freshly formatted (brand new SD Formatter) and verified working Samsung Evo 32GB, SanDisk Extreme Plus 16GB, Extreme Plus 32GB. All the formatting, imaging and installation done on an Ubuntu 25.04 laptop. After usbimager is done, if I use the Ubuntu Disks application to look at the drive, the first partion shows as free space, which seems suspicious. When I insert the newly-set up SD cards in the Cubox-i4, I see the bootloader start and then do its handoff to the operating system... and then nothing. No more signal on the HDMI cable, nothing out on ssh, nothing. The Cubox-i4 tries to reboot every few minutes with no more successful outcome. This same Cubox-i4 runs fine with the last SD card system disk I built for it using the previous Debian server image. Does anyone have any ideas? Thanks in advance!
  23. Thank you @Igor. I downloaded and confirmed sha on Armbian_25.8.1_Tritium-h5_trixie_current_6.12.35_minimal.img.xz. I confirmed my card with F3 and used the SD Format tool to format my uSD card. I wrote the image to my uSD card. $ sudo unxz -c Armbian_25.8.1_Tritium-h5_trixie_current_6.12.35_minimal.img.xz | dd of=/dev/sde bs=1M oflag=direct conv=fsync status=progress iflag=fullblock I then mounted the newly written uSD card and changed the verbosity to 7 in /boot/armbianEnv.txt and added my .not_logged_in_yet and .rootfs_resize to the /root directory of the uSD card. First boot started out well, but 30 seconds in, it hung. I pulled the power after 30 minutes. Here's the log from my serial console: After pulling the plug and re-plugging it in, Armbian booted, but it took a long time. I know the board is not fast, but I went to lunch and came back to finally see the auto log in root prompt. I ran armbian-upgrade and rebooted. This time it was much faster to get to the log in prompt. I'd say this is solved with the new Armbian image, but the hang up at 30 seconds and pulling of power is not ideal. I'm not sure what else I can give you to debug that.
  24. I don't know much, I enabled it as a test, but I like the overview, as I have my favorites easily run as soon as I log into gnome. Maybe we could do: download it to /usr/share/gnome-shell/extensions/ and then run gnome-extensions enable no-overview@fthx. Here's a draft script that may be useful for the ones that want that: git clone --depth=1 https://github.com/fthx/no-overview.git NO_OVERVIEW=$(jq -r .uuid no-overview/metadata.json) mkdir -p /usr/share/gnome-shell/$NO_OVERVIEW gnome-extensions enable $NO_OVERVIEW Does that help?
  25. Try with one additional parameter: EXTRAWIFI="no"
Γ—
Γ—
