dale replied to Jean-Francois Lessard's topic in Amlogic meson
Hi, @Jean-Francois Lessard I'm using a x98h box with self-built image. I have issue with the tm16xx kernel module using a patch https://github.com/paolosabatino/armbian-build/blob/main/patch/kernel/archive/rockchip64-6.16/general-driver-tm16xx-led-driver.patch The vfd controller is AIP1688 which is similar to fd628. Do you have any idea why it fails? -
Yup, I opened a bug report about this on his github, I have yet to receive an answer. I'm having trouble figuring out if it's a hardware issue or a software issue, since I don't have a second bug to test at the same time. When I try the Makerbase OS on this same board, I don't have connectivity either, but at least, the link led turns on and off with the cable connect/disconnect.
Did you try to build the image with compile.sh and this following setting? INCLUDE_HOME_DIR=yes See https://docs.armbian.com/Developer-Guide_Build-Switches/#advanced
Hello ! I'm trying to build my custom Armbian image for a Raspberry Pi. When I build it with these settings, I get a rolling release, which I don't want. compile.sh BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes DISABLE_IPV6=true INCLUDE_HOME_DIR=yes KERNEL_CONFIGURE=no NETWORKING_STACK=network-manager RELEASE=trixie EXPERT=yes BOARD=rpi4b But when I boot with the official armbian minimal image (Armbian_25.8.1_Rpi4b_trixie_current_6.12.41_minimal.img) It's not on the rolling release. Do I miss a setting ? edit: I've tried with building the image on the main and the v25.08 branch.
@Ducdanh Nguyen you forgot these steps choose "Show CSC/WIP/EOS/TVB" choose "I understand and agree" you should see a few x96q in the list. -
@Nick A heres the complete info : 🧠 DRAM Chip 1: Marking: MPF694C4G-P Maker: UniIC (UnilC) Type: DDR3/DDR3L Density: 4 Gb (512 MB) Date code: 2021 (week 11) Chip 2: Marking: SBC13H4G150 Maker: UniIC (UnilC) Type: DDR3/DDR3L Density: 4 Gb (512 MB) Date code: 2020 (week 11) ✅ Total RAM = 1 GB (2 × 512 MB) 💾 Storage (eMMC) Chip: Marking (line 1): NCEMAM60-08G Maker: FORESEE Type: eMMC Flash (not raw NAND) Capacity: 8 GB Marking (line 2): 000 Serial/Batch: Z1S1801147073 Date code: 1802 → Year 2018, Week 02 ✅ Total storage = 8 GB eMMC (manufactured early 2018) -
Nanopi Neo Air stuck at 'Loading kernel' booting from eMMC
devAtronia replied to devAtronia's topic in Allwinner sunxi
@eselarm Thanks for the reply. We are using U-Boot: 2024.01-armbian-2024.01-S866c-P00ff-Ha5c2-V4cad-Bb703-R448a (Jan 21 2025 - 02:21:57 +0000) Allwinner Technology U-Boot 2024.01-armbian-2024.01-S866c-P00ff-Ha5c2-V4cad-Bb703-R448a (Jan 21 2025 - 02:21:57 +0000) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: FriendlyARM NanoPi NEO Air DRAM: 512 MiB Core: 64 devices, 16 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial,usbkbd Out: serial Err: serial Net: No ethernet found. starting USB... No working controllers found Autoboot in 1 seconds, press <Space> to stop -
@laibsch Thanks for the reply. Yes. The filesystem is formatted as ext4. # df -h Filesystem Size Used Avail Use% Mounted on udev 186M 0 186M 0% /dev tmpfs 49M 5.7M 43M 12% /run /dev/mmcblk2p1 7.0G 5.2G 1.5G 79% / tmpfs 244M 0 244M 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 244M 8.0K 244M 1% /tmp /dev/zram1 49M 5.5M 40M 13% /var/log tmpfs 49M 0 49M 0% /run/user/0 tmpfs 49M 0 49M 0% /run/user/1000 # file -sL /dev/mmcblk2p1 /dev/mmcblk2p1: Linux rev 1.0 ext4 filesystem data, UUID=d3fe76cc-f19f-40a6-b8db-44a87f92714f (needs journal recovery) (extents) (64bit) (large files) (huge files) By bricked, I mean exactly that. Device boot is interrupted on the "Loading kernel" message. In these cases, the device can be recovered by booting from an SD Card and running fsck -
I have identified the ram chip and nand, but don't know where wifi is, i think thats not very important since i have alot of usb wifi and ethernet -
@IBV Thanks! I will look into that info and check if we can do this conversion is runtime, and if so, how it can be automated. -
Yeah, also on my laptop (Arch with upstream 6.16 kernel) this problem does not happen, so it shouldn't be because of specific patches to the rtw88 kernel in the RPi kernel repo. It only happens when I use the kernel built with Armbian build system. I am completely clueless about what could be causing this 🤷♂️
Armbian doesnt seem to see sata harddrives.
Popolon replied to DontMindMe's topic in Radxa Rock 5 ITX
Sorry that was resolved 2 days ago, but I don't see and never seen this long list. Only 3 options vendor 6.1, 6.12 and edge (6.16), This morning I also seen the u-boot wasn't the good one. I downloaded for rock5-itx, but had linux-u-boot-cyber-aib-rk3588-edge instead of linux-u-boot-rock-5-itx-edge, changed it, rebooted (on 6.16) worked, tried again 6.12, still no display. I needed to arch-chroot on the armbian to take a screenshot (but I've the same dispay on armbian itself): I seen 6.16.4 is now available and work, after /boot/config-6.16.4-edge-rockchip64, gcc 13.3.0 is now again used instead of old 11.x :). Debian Trixie has GCC 14.2.0 CONFIG_CC_VERSION_TEXT="aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0" And after changelog on kernel.org, patch for AV1 acceleration had been applied on this version: https://cdn.kernel.org/pub/linux/kernel/v6.x/ChangeLog-6.16.4 Fixes: 003afda97c65 ("media: verisilicon: Enable AV1 decoder on rk3588") Sorry I maybe mix too much subjects in the same post, but: I also seen a minimal IoT version of Trixie for Rock5-itx. Can I made safely a debian os upgrade from apt? Or is it better to wait release for desktop version ? Another point. On armbian, only LLVMpipe is used, I compiled last mesa git on arch, will try to do this for debian too. and some application that need to use EGL+dri (wings3D, blender, obs) report broken DRI2 access. I'm not sure if it's due to some kernel patchs (I reuse the armbian 6.16 kernel on arch), or to the current state of mesa-git. They all works with llvmpipe. Othere applications like PPSSPPSDL work fine without it. Ex, with wings3d + forced zink: MESA_LOADER_DRIVER_OVERRIDE=zink GALLIUM_DRIVER=zink wings3d WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance libEGL warning: egl: failed to create dri2 screen WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance -
Hello @Nick A i did everything git cloned now im in setup, heres what i choosed: 1. Do not change kernel configuration And after that, i don't found any compactible for my h313 also note that mine firmware is based off d9 Pro 5g so i think it could use the same dram settings and wifi chip except for the cpu. Hope this helps! -
Use the provided curl command at the end of every build run or use "SHARE_LOG=yes" with the compile command to auto-upload. Nobody will try to read through this unformatted mess.
Easiest way is to use the customize-image.sh file in userpatches. Stuff there gets executed within chroot on the sdcard just before its closed and assembled. More advanced way is using extensions. Check extensions folder for examples.
How to compile and modify the apt source during compilation??
Werner replied to lay's topic in Khadas EDGE2
You can either experiment with the CLEAN_LEVEL switch or use kernel-patch or uboot-patch (depending on what you want to modify) to create proper patch files from the diff. -
Try change the folder permission, chmod -r 775 /home/odroid/
The apt source is always overwritten by the cache source when modified. How can I modify this cache source. How can I modify this cache source?? help help
MXQ MBX Model M201 amlogic s805
s-petersen replied to s-petersen's topic in TV Boxes running Armbian
Did you download stretch already, before I remove it to put up Bionic? -
@Nick A I woke up and i'll start working on it. -
Looks good! Thank you. What's the best way to get start customizing the build?
Great! Thank you. I will try it.
Olivier Sikora replied to s-petersen's topic in TV Boxes running Armbian
OH MY GOD YOU HAVE THAT TOO? can you please share it? i need that image, i can host it on google drive myself if someone would need it - Yesterday
Hello, everyone. I'm using Armbian_25.5.2_Orangepizero3_bookworm_current_6.12.30-homeassistant_minimal on 4GB OpiZero3. When booting from sd, the bluetooth controller is initialized correctly. I made a boot from usb-ssd via armbian-config: everything works fine, but the bluetooth controller is not initialized. /sys/class/bluetooth is empty. Switch back to sd - it works again. Boot from ssd - no. I compared whether it transferred the distribution correctly from sd to ssd - all files are the same. What could be the problem?
