PiRogue installation for NanoPI_R4S problems
Superuser replied to Superuser's topic in Software, Applications, Userspace
Everything is good, thanks for the help and sorry for confusion, I only should to change PiRogue default interface after installation, this is PiRogue interface detection problem... -
@Vinicius Guastala I agree with @fabiobassa, thanks for the very detailed post of your board and broad description of the behaviour. I would suggest you to erase the internal flash and try to boot from sdcard with this armbian image. It is an "experimental" image with opensource Trust OS; many recent boards are having issues with proprietary trust os, possibly yours has similar issues, so you could give a shot to this. By the way, the serial log output would be indeed very handy if you have the chance to find the serial port. Beware also that armbian (and multitool) use 115200bps baud rate for the serial, while proprietary software uses 1.5Mbps baud rate!
@gurzixo much better to steer to an officially supported SBC from armbian, if you need something reliable: https://www.armbian.com/download/?device_support=Platinum support&arch=aarch64
@Vinicius Guastala first of all thank you for so much detailled infos and your efforts to find any relevant pin on your board. Yes china manufacturers are well known to use the first avaible chip they have unused on desk so I am not at all surprised to have this frankstein model of a 322x Unfortunately I don't own such board, so really at the moment I have few clues to point you on the right direction. Mine are generic considerations: 1) no separate chips apart from cpu, just one big big chip = ECMP usually 8 giga rom, 1 giga ram ( good for you if it is 16/2 but i doubt) 2) to me looks more interesting the FGHI part for uart, REMEMBER that uart speed is 1500000 ( yes!!!!! one million 500000) but follow the tracks for any missing resistor/missing short that stop the uart signal from CPU to pads 3) if you have a radio-aficionado or a tv technician that owns an oscilloscope finding the uart pads will be easier Sorry if I am not any further useful for your case, cannot buy every single new board that comes out on market, but if for you is important feel free to send me one sample for study and development EDIT : I just remebered that if you are lucky because not all boards have enabled. you'll find a uart on the sd card reader, starting from most right pins and counting 4 . Let me be more clear : two small and two big, from right....on the 4 you will have a uart at 1.500.000 Of course if you put the sd in you will lose this signal, but at least confirm you have any readable character on that pin )
Not sure which board you are using but if you look at the u-boot defconfig file you will see the dram config in there. https://github.com/NickAlilovic/build/blob/v20250306/patch/u-boot/u-boot-h616/171-add-x98h-defconfig.patch The row with h616 is your dram config settings
Hello again Jock an all the other members of this topic ! After a long time without fiddling with those lovely boxes, I need now a low-cost Linux box (typically 4gb/64gb) for setting up a simple local web server with node/express/nginx. Would someone be kind enough to provide a working AliExpress link of such a box where at least Eth and maybe WiFi are working out of the box? Thanks a lot, Michel
Vinicius Guastala replied to jock's topic in Rockchip CPU Boxes
Hello Guys, This will be a long post, so I already apologize for that! I am trying to install armbian in the most generic MXQ PRO 5G 4K ever. No joking when I say it’s generic, because I have some proof that this Frankenstein monster is actually a MX9 and a MXQ 4K PRO merged together. Here are some board Details: MoBo: MXQ-EP-2-V1.0 CPU: Rockchip RK3228A Wifi: SV6256P Storage: Samsung KMQ7X000SA – B315 (Is this a ECMP 8GB+8GB or a emmc?) I call it a MXQ Frankenstein, for the following reasons: According to the info and the picture from this source, the “MX9 4K 5G” has the exactly same MoBo “MXQ-EP-2-V1.0”, but with the SV6152P wifi instead. According to this other forum post, the OP has posted pics from his "TXC2-MXQ-EP-V10” MoBo, which looks basically identical to my “MXQ-EP-2-V1.0”, but it has the SV6152p wifi like the MX9 4K 5G, but with a RK3229 CPU instead. This post was very useful for me because of the Short Pad for Mask Mode for this version is the same as mine. In this other post, we see the same “MXQ-EP-2-V1.0” Mobo, but with with a SanDisk storage chip instead. And in the same post, in the last comment we see another user with a 8GB/128GB variant with the same SV6152p wifi from the above “TXC2-MXQ-EP-V10” So including my version, it seems we have at least 5 different versions of this horrendous Frankenstein device, for the “lowering cost reasons” we already know…. Despite many tentatives, I am not able to make the “multitool” (or amrbian directly) to boot, from any method. Tried many times from SD, from USB and even after it is copied directly to the eMMC, all following the guides from the 1st page from this post, but also from other internet sources. Simply I’ve got a black screen output whenever the SD Card with multitool or armbian in inserted, with no leds turned at all. Unfortunately I have not done the backup from my original ROM before I have tried to write armbian directly to the emmc, because I did not know that was possible back then, and now I’m also not able to find my original ROM. I have tried many (10+) different ROMs, flashing from Linux and Windows, but I ending up having the same behavior as booting armbian, with no Video and no LEDs, until I finally came across to the ROM called “MXQ-EP-2-V1.0_SV6152P_OK By: (Zer013)” from this site. With said ROM, I was able at least to get the HDMI video and LED’s blinking, but I got stuck at a boot animation loop forever. For some reason, only when I flash it from Windows using BatchTool or RKDevTools it works. At least I was able to test different Loaders, and with this ROM, I have tested successfully all the loaders below, either flashing by Linux or Windows. (Remember: The device gave video and LEDs, but I still got stucked at ROM’s boot screen): RK322XMiniLoaderAll_V2.47_spectek_en_ddr2_rd_odt_171209.bin – This was extracted from the above ROM image that give me workin LEDS and HDMI Video rk322x_loader_v1.10.238_256 from a 2020 comment on this thread from a guy trying to overclock his ddr memory. rk322x_loader_v1.10.238_256.bin from first page, from the “Installation (without SD card, board with eMMC)” section I was trying to flash different loaders in hope that some of them would make my armbian to boot from the SD card, but without any luck unfortunately. I have also tried to erase the flash completely to force the SD Card boot, but I have got the same no-screen / no-leds behavior. If anybody has any ideas on how to go further to install armbian in this board, I would appreciate a lot! I don’t need the wifi for the purpose I intend to use it, so minimal installation is more than enough for me. I’ve been turning it on mostly with just the USB cable in the OTG port, so at least I can check the device status with lsusb in linux. Sometimes I do some tests with the power cable turned on, and I have noticed the same behavior as well. Does it make any different to turn it on by USB or Power Connector? I’m still not able to find the Serial UART pins, even after I have tried soldering my USB-TTL in different points of the Board as there is no printed info, so this also adds to the overall complexity. Despite my efforts with the multimeter, I was not able to identify them yet. Since I’m afraid to burn another USB-TLS adapter, I’m being cautious and only using the GND and RX pins from the adapter. So far, I have found 2 interesting pins, but they only give me gibberish text, despite trying different baud rates (I have tried them all). Most promissing PIN for now is the pin labeled “K” in the pic below, as it is the one that gives me more output when the device is booting, almost in the same time as a normal system boot… So my “guess” is that the Pink K is the board TX pin… Attached there are all the photos of the mentioned components from my board. -
It loooks like the Panfrost gpu driver is made as a module in the kernel configuration, marked with an M and not *. If I want this module to be built into the kernel, can I change it from M to * to do this? When built as a module, how do I turn it on? Is it in armbian-config (under overlays) or some other place?
Server vs Desktop images
sakittelsen replied to sakittelsen's topic in Software, Applications, Userspace
Thanks, found it. run this command to start building with an extension: ./compile.sh ENABLE_EXTENSIONS=mesa-vpu -
https://docs.armbian.com/Developer-Guide_Build-Switches/ Look for ENABLE_EXTENSIONS
How do I enable those extensions during the image build? -
Here is an sample implementation of both: https://forum.armbian.com/topic/51915-server-vs-desktop-images/#findComment-218346
You can see here what the most important one does: https://github.com/armbian/build/blob/main/extensions/mesa-vpu.sh
sleep & wake on same pin for NanoPi Neo v1.4 Armbian-23 6.1.63
dandan7932 replied to dandan7932's topic in Allwinner sunxi
Hey Dandaman46, I managed to kinda hack the functionality i wanted with the wake-up timer and a magnetic hall effect sensor (A3144 or DRV5053) : import os import OPi.GPIO as GPIO from OPi.pin_mappings import sunxi assert sunxi("PG11") == 203 # GPIO-G11 - Wake/Sleep Pin DRV5053 button_wake = "PG11" GPIO.add_event_detect(button_wake, GPIO.RISING, callback=None, bouncetime=200) GPIO.setmode(GPIO.SUNXI) GPIO.setwarnings(False) # disable when production ready.. GPIO.setup(button_wake, GPIO.IN) # PG11 as Sleep/Wake Pin # pull it LOW (magnet away) to wake (needs pull-down resistor?) # pull HIGH (magnet near) to sleep (needs pull-up resistor?) if GPIO.input(button_wake) == GPIO.HIGH: os.system("echo +5 > /sys/class/rtc/rtc0/wakealarm") os.system("echo mem > /sys/power/state") elif GPIO.input(button_wake) == GPIO.LOW: pass -
Yes, that sound right. Now I have to learn how to use backports or ppa ...
Does this include graphics, like gpu driver, mesa, opengl, vulkan and so on? -
Hm sounds like it all boils down to mesa. Ubuntu Noble has kisak ppa to provide a more current version while Debian can pull more recent mesa packages from backports. mesa-vpu extension should deal with that.
Keyboard layout missing
3000 EUR is a bit steep I'll use armbian+config for now. -
I have problems with gpu drivers. Some builds have Panfrost drivers, and some har software rendering. Often, Ubuntu has Panfrost, but Bookworm has Software. Prebuilt images often have Panfrost, but if I build the same image myself, there is no gpu driver. Learning about overlays, and looks like I have to enable gpu drivers there. I want to use Debian and not Ubuntu, but Ubuntu seens to have better hardware support (audio/video drivers). Not sure if that is just something I "think"
Did you also start screen or minicom on the SBC ? For example: screen /dev/ttyS0 115200 And on PC: screen /dev/ttyUSB0 115200 Make sure you use the same speed on both sides.
Stuck on jammy, can't upgrade to noble
Domas replied to Domas's topic in Software, Applications, Userspace
Hi there, thanks for trying to solve this, Here it goes: orangepiplus:~:% aptitude search '~o' i A apport-core-dump-handler - Kernel core dump handler for Apport i armbian-focal-desktop-xfce - Armbian desktop for Ubuntu focal i A at-spi2-common - Assistive Technology Service Provider In i A clang-10 - C, C++ and Objective-C compiler i A clang-18 - C, C++ and Objective-C compiler i A cpp-13 - GNU C preprocessor i A cpp-13-arm-linux-gnueabihf - GNU C preprocessor for arm-linux-gnueabi i A cpp-arm-linux-gnueabihf - GNU C preprocessor (cpp) for the armhf a i crda - wireless Central Regulatory Domain Agent i A cron-daemon-common - process scheduling daemon's configuratio i A dbus-bin - simple interprocess messaging system (co i A dbus-daemon - simple interprocess messaging system (re i A dbus-session-bus-common - simple interprocess messaging system (se i A dbus-system-bus-common - simple interprocess messaging system (sy i A dhcpcd-base - DHCPv4 and DHCPv6 dual-stack client (bin i A dracut-install - dracut is an event driven initramfs infr i A fonts-dejavu-mono - Vera font family derivate with additiona i fonts-ubuntu-font-family-conso - console version of the Ubuntu Mono font i A g++-13 - GNU C++ compiler i A g++-13-arm-linux-gnueabihf - GNU C++ compiler for arm-linux-gnueabihf i A g++-arm-linux-gnueabihf - GNU C++ compiler for the armhf architect i A gcc-13 - GNU C compiler i A gcc-13-arm-linux-gnueabihf - GNU C compiler for the arm-linux-gnueabi i A gcc-13-base - GCC, the GNU Compiler Collection (base p i A gcc-14-base - GCC, the GNU Compiler Collection (base p i A gcc-arm-linux-gnueabihf - GNU C compiler for the armhf architectur i A gcr4 - GNOME crypto services (daemon and tools) i A gir1.2-girepository-2.0 - Introspection data for GIRepository libr i hddtemp - hard drive temperature monitoring utilit i A keyboxd - GNU privacy guard - public key material i A libamd3 - approximate minimum degree ordering libr i A libappstream5 - Library to access AppStream services i A libapt-pkg6.0t64 - package management runtime library i A libarchive13t64 - Multi-format archive and compression lib i A libasound2t64 - shared library for ALSA applications i A libatk-bridge2.0-0t64 - AT-SPI 2 toolkit bridge - shared library i A libatk1.0-0t64 - ATK accessibility toolkit i A libatopology2t64 - shared library for handling ALSA topolog i A libatspi2.0-0t64 - Assistive Technology Service Provider In i A libavcodec60 - FFmpeg library with de/encoders for audi i A libavutil58 - FFmpeg library with functions for simpli i A libblockdev-crypto3 - Crypto plugin for libblockdev i A libblockdev-fs3 - file system plugin for libblockdev i A libblockdev-loop3 - Loop device plugin for libblockdev i A libblockdev-mdraid3 - MD RAID plugin for libblockdev i A libblockdev-nvme3 - NVMe plugin for libblockdev i A libblockdev-part3 - Partitioning plugin for libblockdev i A libblockdev-swap3 - Swap plugin for libblockdev i A libblockdev-utils3 - Utility functions for libblockdev i A libblockdev3 - Library for manipulating block devices i A libboost-iostreams1.83.0 - Boost.Iostreams Library i A libbpf1 - eBPF helper library (shared library) i A libcamd3 - symmetric approximate minimum degree lib i A libcanberra-gtk3-0t64 - GTK+ 3.0 helper for playing widget event i A libcanberra0t64 - simple abstract interface for playing ev i A libcbor0.10 - library for parsing and generating CBOR i A libccolamd3 - constrained column approximate library f i A libcholmod5 - sparse Cholesky factorization library fo i A libclang-common-10-dev - Clang library - Common development packa i A libclang-common-18-dev - Clang library - Common development packa i A libclang-cpp10 - C++ interface to the Clang library i A libclang-cpp14t64 - C++ interface to the Clang library i A libclang-cpp18 - C++ interface to the Clang library i A libclang1-10 - C interface to the Clang library i A libclang1-14t64 - C interface to the Clang library i A libclang1-18 - C interface to the Clang library i A libcodec2-1.2 - Codec2 runtime library i A libcolamd3 - column approximate minimum degree orderi i A libcups2t64 - Common UNIX Printing System(tm) - Core l i A libcupsfilters2-common - OpenPrinting libcupsfilters - Auxiliary i A libcupsfilters2t64 - OpenPrinting libcupsfilters - Shared lib i A libcurl3t64-gnutls - easy-to-use client-side URL transfer lib i A libcurl4t64 - easy-to-use client-side URL transfer lib i A libdav1d7 - fast and small AV1 video stream decoder i A libdb5.3t64 - Berkeley v5.3 Database Libraries [runtim i A libdv4t64 - software library for DV format digital v i A libdw1t64 - library that provides access to the DWAR i A libelf1t64 - library to read and write ELF files i A libevdocument3-4t64 - Document (PostScript, PDF) rendering lib i A libevent-2.1-7t64 - Asynchronous event notification library i A libevent-core-2.1-7t64 - Asynchronous event notification library i A libevview3-3t64 - Document (PostScript, PDF) rendering lib i A libext2fs2t64 - ext2/ext3/ext4 file system libraries i A libflac12t64 - Free Lossless Audio Codec - runtime C li i A libfuse2t64 - Filesystem in Userspace (library) i A libgail18t64 - GNOME Accessibility Implementation Libra i A libgcc-13-dev - GCC support library (development files) i A libgcc-14-dev - GCC support library (development files) i A libgck-2-2 - Glib wrapper library for PKCS#11 - runti i A libgcr-4-4 - Library for Crypto related tasks i A libgdbm-compat4t64 - GNU dbm database routines (legacy suppor i A libgdbm6t64 - GNU dbm database routines (runtime versi i A libgegl-0.4-0t64 - Generic Graphics Library i A libgeoip1t64 - non-DNS IP-to-country resolver library i A libgimp2.0t64 - Libraries for the GNU Image Manipulation i A libgirepository-2.0-0 - GLib runtime library for handling GObjec i A libglib2.0-0t64 - GLib library of C routines i A libglibmm-2.4-1t64 - C++ wrapper for the GLib toolkit (shared i A libgnome-desktop-3-20t64 - Utility library for the GNOME desktop - i A libgnutls30t64 - GNU TLS library - main runtime library i A libgpgme11t64 - GPGME - GnuPG Made Easy (library) i A libgphoto2-6t64 - gphoto2 digital camera library i A libgphoto2-port12t64 - gphoto2 digital camera port library i A libgs-common - interpreter for the PostScript language i A libgs10 - interpreter for the PostScript language i A libgs10-common - interpreter for the PostScript language i A libgtk-3-0t64 - GTK graphical user interface library i A libgtk2.0-0t64 - GTK graphical user interface library - o i A libgtkmm-2.4-1t64 - C++ wrappers for GTK+ 2 (shared librarie i A libgtkmm-3.0-1t64 - C++ wrappers for GTK+ (shared libraries) i A libgts-0.7-5t64 - library to deal with 3D computational su i A libgxps2t64 - handling and rendering XPS documents (li i A libheif-plugin-aomdec - ISO/IEC 23008-12:2017 HEIF file format d i A libheif-plugin-libde265 - ISO/IEC 23008-12:2017 HEIF file format d i libhogweed5 - low level cryptographic library (public- i A libhogweed6t64 - low level cryptographic library (public- i A libhwy1t64 - Efficient and performance-portable SIMD i A libical3t64 - iCalendar library implementation in C (r i libicu66 - International Components for Unicode i A libicu74 - International Components for Unicode i A libieee1284-3t64 - cross-platform library for parallel port i A libimath-3-1-29t64 - Utility libraries from ASF used by OpenE i A libiw30t64 - Wireless tools - library i libjson-c4 - JSON manipulation library - shared libra i A libjxl0.7 - JPEG XL Image Coding System - "JXL" (sha i A libldap2 - OpenLDAP libraries i A liblerc4 - Limited Error Raster Compression library i A libllvm10 - Modular compiler and toolchain technolog i A libllvm14t64 - Modular compiler and toolchain technolog i A libllvm18 - Modular compiler and toolchain technolog i A libllvm19 - Modular compiler and toolchain technolog i A libmagic1t64 - Recognize the type of data in a file usi i A libminizip1t64 - compression library - minizip library i libmpdec2 - library for decimal floating point arith i A libmpg123-0t64 - MPEG layer 1/2/3 audio decoder (shared l i A libmtdev1t64 - Multitouch Protocol Translation Library i A libnetplan1 - Declarative network configuration runtim i libnettle7 - low level cryptographic library (symmetr i A libnettle8t64 - low level cryptographic library (symmetr i A libnpth0t64 - replacement for GNU Pth using system thr i A libntfs-3g89t64 - read/write NTFS driver for FUSE (runtime i A libnvme1t64 - NVMe management library (library) i A libobjc-13-dev - Runtime library for GNU Objective-C appl i A libopenexr-3-1-30 - runtime files for the OpenEXR image libr i A liborc-0.4-0t64 - Library of Optimized Inner Loops Runtime i A libparted-fs-resize0t64 - disk partition manipulator - shared FS r i A libparted2t64 - disk partition manipulator - shared libr i A libpcap0.8t64 - system interface for user-level packet c i libpcre2-posix2 - New Perl Compatible Regular Expression L i A libperl5.38t64 - shared Perl library i A libpkcs11-helper1t64 - library that simplifies the interaction i A libpng16-16t64 - PNG library - runtime (version 1.6) i A libpoppler-cpp0t64 - PDF rendering library (CPP shared librar i A libpoppler-glib8t64 - PDF rendering library (GLib-based shared i A libpoppler134 - PDF rendering library i A libppd2 - OpenPrinting libppd - Shared library i A libppd2-common - OpenPrinting libppd - Auxiliary files i A libproc2-0 - library for accessing process informatio i A libpskc0t64 - OATH Toolkit Libpskc library i A libpsl5t64 - Library for Public Suffix List (shared l i A libpython3.12-minimal - Minimal subset of the Python language (v i A libpython3.12-stdlib - Interactive high-level object-oriented l i A libpython3.12t64 - Shared Python runtime library (version 3 i libpython3.8-minimal - Minimal subset of the Python language (v i A libqpdf29t64 - runtime library for PDF transformation/i i A libqt5core5t64 - Qt 5 core module i A libqt5dbus5t64 - Qt 5 D-Bus module i A libqt5gui5t64 - Qt 5 GUI module i A libqt5network5t64 - Qt 5 network module i A libqt5printsupport5t64 - Qt 5 print support module i A libqt5sql5t64 - Qt 5 SQL module i A libqt5test5t64 - Qt 5 test module i A libqt5widgets5t64 - Qt 5 widgets module i A libqt5xml5t64 - Qt 5 XML module i A librav1e0 - Fastest and safest AV1 encoder - shared i A libraw23t64 - raw image decoder library i A libre2-10 - efficient, principled regular expression i A libreadline8t64 - GNU readline and history libraries, run- i A libreiserfscore0t64 - ReiserFS core library i libsepol1 - SELinux library for manipulating binary i A libsframe1 - Library to handle the SFrame format (run i A libsharpyuv0 - Library for sharp RGB to YUV conversion i A libsmbclient0 - shared library for communication with SM i A libsnapd-glib-2-1 - GLib snapd library i A libsnmp40t64 - SNMP (Simple Network Management Protocol i A libssh2-1t64 - SSH2 client-side library i libssl1.1 - Secure Sockets Layer toolkit - shared li i libssl3t64 - Secure Sockets Layer toolkit - shared li i A libstdc++-13-dev - GNU Standard C++ Library v3 (development i A libstoken1t64 - Software Token for cryptographic authent i A libsuitesparseconfig7 - configuration routines for all SuiteSpar i A libsvtav1enc1d1 - Scalable Video Technology for AV1 (libsv i A libswresample4 - FFmpeg library for audio resampling, rem i A libsystemd-shared - systemd shared private library i A libtevent0t64 - talloc-based event loop library - shared i A libtiff6 - Tag Image File Format (TIFF) library i A libtirpc3t64 - transport-independent RPC library i A libtss2-esys-3.0.2-0t64 - TPM2 Software stack library - TSS and TC i A libtss2-mu-4.0.1-0t64 - TPM2 Software stack library - TSS and TC i A libtss2-sys1t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-cmd0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-device0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-libtpms0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-mssim0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-spi-helper0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-swtpm0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tctildr0t64 - TPM2 Software stack library - TSS and TC i A libumfpack6 - sparse LU factorization library i A libunistring5 - Unicode string library for C i A libv4l-0t64 - Collection of video4linux support librar i A libv4lconvert0t64 - Video4linux frame format conversion libr i A libvpx9 - VP8 and VP9 video codec (shared library) i libwebp6 - Lossy compression of digital photographi i A libx264-164 - x264 video coding library i A libxmlsec1t64 - XML security library i A libxmlsec1t64-openssl - Openssl engine for the XML security libr i A libxt6t64 - X11 toolkit intrinsics library i A libzvbi0t64 - Vertical Blanking Interval decoder (VBI) i A llvm-18-linker-tools - Modular compiler and toolchain technolog i A mesa-libgallium - shared infrastructure for Mesa drivers i A netplan-generator - Declarative network configuration for va i numix-blue-gtk-theme - Variant of the Numix theme with blue hig i perl-modules-5.30 - Core Perl modules i A perl-modules-5.38 - Core Perl modules i A pkgconf-bin - manage compile and link flags for librar i A python3-netplan - Declarative network configuration Python i A python3-rlpycairo - plugin for the ReportLab PDF Toolkit. i A python3.12 - Interactive high-level object-oriented l i A python3.12-minimal - Minimal subset of the Python language (v i python3.8-minimal - Minimal subset of the Python language (v i A systemd-dev - systemd development files i systemd-resolved - systemd DNS resolver i ttf-ubuntu-font-family - sans-serif font set from Ubuntu (transit orangepiplus:~:% Here: orangepiplus:~:% apt-cache policy | grep http | awk '{print $2" "$3}' | sort -u http://apt.armbian.com jammy/jammy-desktop http://apt.armbian.com jammy/jammy-utils http://apt.armbian.com jammy/main http://ports.ubuntu.com/ubuntu-ports jammy/main http://ports.ubuntu.com/ubuntu-ports jammy/multiverse http://ports.ubuntu.com/ubuntu-ports jammy/restricted http://ports.ubuntu.com/ubuntu-ports jammy-security/main http://ports.ubuntu.com/ubuntu-ports jammy-security/multiverse http://ports.ubuntu.com/ubuntu-ports jammy-security/restricted http://ports.ubuntu.com/ubuntu-ports jammy-security/universe http://ports.ubuntu.com/ubuntu-ports jammy/universe http://ports.ubuntu.com/ubuntu-ports jammy-updates/main http://ports.ubuntu.com/ubuntu-ports jammy-updates/multiverse http://ports.ubuntu.com/ubuntu-ports jammy-updates/restricted http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe https://github.armbian.com/configng stable/main Do release upgrade downloads the updater package (noble.tar.gz) and then I think it has update link insides, or it just seems so. It tries to download files even if I comment out all of the /sources.list.d/ which is strange in my view.. This is probably my external hard drive that I actually use for data backups (primary use of this whole system). It is fstab and is automounted on every start. It could be that it was actually disconnected when doing armianmonitor 😉 But this is to be sorted later. Thanks for pointing that out Any ideas? This is really too complicated for me to solve on my own at this point. -
Can you be more specific?
UART won't connect no matter what I do
devmichelcastilho replied to devmichelcastilho's topic in Beginners
Thank you so much for the responses, IBV and Werner! I'm connecting from the PC USB to the SBC serial com port, then attempting to run Screen from the PC. -
it could be that there is a bug in one distro that is not present or already fixed in the other it could be that one image is missing a package that should have been installed (this would be a bug in Armbian if it affects one of the images we publish) best you can do is to report bugs if you think there is one
