On my TV box X88 pro 10 128 GB (Armbian 24.11.0-trunk.321 6.11.4-edge-rockchip6), the driver does not work when set to led-config 2. After studying, I performed several operations and everything worked. Maybe it will help someone!! In armbian-config, install led-config 2 and wlan-ap6334 next 1. dtc -I dtb -O dts /boot/dtb/rockchip/overlay/rockchip-rk3318-box-led-conf2.dtbo -o /root/rk3318-box-led-conf2.dtso 2. In the /root/rk3318-box-led-conf2.dtso file, edit reg = <0x24> to <0x0> 3. dtc -I dts -O dtb -f /root/rk3318-box-led-conf2.dtso -o /boot/dtb/rockchip/overlay/rockchip-rk3318-box-led-conf2.dtbo Wi-Fi and Bluetooth are working, the display is working too, but for some reason the lan and power symbols are mixed up. I solved it through the display service file
darcyg replied to Hqnicolas's topic in Rockchip CPU Boxes
I only tested the main configuration to ensure that the kernel and file system rootfs are normal, and other configurations have not been tested yet The attachments are patch files and several modified source files. The testing was conducted in my own buildroot project. It has not been tested in armbian yet (there are currently some issues with the armbian compilation environment). My buildroot project was launched based on the DTS of this post. I believe it should be available in armbian. add-rk3576h96-m9s-dts.patch rk3576-linux.dtsirk3576-h96-m9s.dtsrk3576.dtsi - Today
CubieTruck: Attempted to kill init after kernel update to 6.6.75?
Crazyphil replied to Crazyphil's topic in Allwinner sunxi
It's a bit embarrassing, but in my case the fault was entirely mine. I seemed to have messed around a bit too much with the system. However, maybe this helps someone else with their problem as well. One of the changes I did to my system caused the /lib directory to be replaced by an actual directory instead of a symlink to /usr/lib. As the init.d script is stored in /usr/lib/init, the boot process couldn't find it anymore under the path it expects it to, the kernel panicked. I then removed the directory including all its contents and replaced it with the correct symlink again. Since then, my Cubietruck has been working fine. -
I have resolved it, modified in the driver.
Thank you for reporting. It's a problem with a mirror. Here is email I sent to admin: After this job finishes, mirror will be out of the pool, temporally. Here https://docs.armbian.com/Mirrors/#current-mirrors you can search for alternative download locations manually and try to use torrent - It is much faster.
Meanwhile, I have enabled ADB and debugging over wifi, and have connected to cli: 127|rk3528_box:/ $ uname -a Linux localhost 5.10.157-ab10 #319 SMP PREEMPT Sat Nov 11 21:49:28 CST 2023 aarch64 Toybox I think it is possible to copy firmware image from ADB session. If someone did/have instructions please point here.
I found this I hope it helps you @Luiz-SP
thanks @darcyg if you can, share it with us -
David A replied to Crazyphil's topic in Allwinner sunxi
Same issue with Armbian 25 / kernel 6.6 😞 -
Hello there, I recently gained remote access to a Banana Pi F3 to test it, and everything went smoothly. The board was running Bianbu Linux, and I was able to install and use Docker without issues. Now, I'm considering purchasing the board and was wondering if the Armbian image would also support running Docker. Do you have any insights on this? Thanks!
hey, @cmuki! Using the dts from the rk3576-evb1-v10 / rk3576-armsom-sige5 / rk3576-rock-4d in the https://github.com/radxa/kernel/arch/arm64/boot/dts/rockchip/ directory After modification, they can all boot the Armbian version h96-m9s Note: The rk3576-linux.dtsi file forcibly specifies the UUID of the rootfs device partition, which may cause system boot failure. Adjustments might be needed. The basic modification method is simple: disable the PCIe and GMAC1 configurations, modify the reset_pin configuration of GMAC0 to gpio2 and PB3 to enter the system. I used rock-4d as the template for modification. Other modifications have not been thoroughly studied yet. -
Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
hi, ubuntu22 gome desktop How to fix USB sound card with card1 identifier 1
Build Image with Debian 12 VM on QubesOS
Werner replied to joejoe44's topic in Advanced users - Development
Have you tried installing qemu-user-static package manually and retry? -
Tried a few hours later? Alternativly you can choose a fixed mirror from here: https://docs.armbian.com/Mirrors/
@Nick A oh your build for the Tanix TX6S worked perfectly for me already (thanks!) though I did notice some weird behaviour on my other box that's supposed to be identical to this one. stuff like armbian-config freezing when trying to format the eMMC mainly. I noticed a hang in the kernel in the dmesg when that happened so I suspect there might be some minor difference in the hardware that I'll look into later. for right now I've moved to a box with an amlogic s905y4, which is a whole other can of worms. I got debian-on-amlogic to boot so I'm hoping I can copy over the u-boot and dtb in other to get armbian working on it, since it has more features for SBCs. thanks for your help nick!
@jwillb00 try this build. https://github.com/LYU4662/t95zplus-h618-build
Hi everyone, I'm having trouble recovering my Android TV box T95 Max with the following specs: CPU: Allwinner H616 RAM: 4GB ROM: 32GB Board: AXP313A V3.0 The box was freezing after boot, so I tried to reflash the firmware using PhoenixCard / suit. What I’ve Tried So Far: Downloaded and flashed T95-H616-A27.img & T95-H616-A29.img through FEL mode and Flashing completed successfully but the box only shows a black screen on both HDMI and the small front panel screen. Tried other firmware images labeled for T95 Max H616 AXP313A Tried re-burning the SD using different cards and readers I found a working Armbian img that worked from SD card: https://github.com/NickAlilovic/build/releases/download/v20240716/Armbian-20240716-unofficial_24.5.0-trunk_Transpeed-8k618-t_bookworm_edge_6.7.12_xfce_desktop_Secure_Boot.img.tar.xz I want to restore the TV box to a working firmware (Android 10 or 12) if possible. And is there any method to revive bootloader if it's corrupted Any working image file would be a huge help. Board Image attached:
