I'm having a problem installing a driver. Once compiled correctly, the system gives me an error. Note that I performed the same procedure with : RaspiOS on an arm64 board (RPi4B) with the same kernel version, and it worked. Debian 12 on a PC, and it worked. Armbian on an arm64 board (RPi4B) with the same kernel version, and it worked. Armbian on an armhf board (nanopineocore) with the same kernel version, and it worked. But does not work with Armbian Bookworm on a nanopineocore2 board: epsilonrt@nanopineocore2:~/src/tty0tty/module$ sudo modprobe tty0tty modprobe: ERROR: could not insert 'tty0tty': Exec format error epsilonrt@nanopineocore2:~/src/tty0tty/module$ modinfo tty0tty filename: /lib/modules/6.12.20-current-sunxi64/updates/dkms/tty0tty.ko license: GPL description: tty0tty null modem driver author: Luis Claudio Gamboa Lopes <lcgamboa@yahoo.com> depends: name: tty0tty vermagic: 6.12.20-current-sunxi64 SMP mod_unload aarch64 epsilonrt@nanopineocore2:~/src/tty0tty/module$ uname -a Linux nanopineocore2 6.12.20-current-sunxi64 #1 SMP Sat Mar 22 19:54:28 UTC 2025 aarch64 GNU/Linux The problem does not come from the driver which loads very well on all the systems mentioned at the beginning of the post, for example with Armbian Bookworm on an RPi 4B board: epsilonrt@r14:~/src/tty0tty/module$ sudo modprobe tty0tty epsilonrt@r14:~/src/tty0tty/module$ dmesg | tail [ 15.046221] bcmgenet fd580000.ethernet end0: Link is Up - 1Gbps/Full - flow control off [ 21.678333] Bluetooth: RFCOMM TTY layer initialized [ 21.678364] Bluetooth: RFCOMM socket layer initialized [ 21.678384] Bluetooth: RFCOMM ver 1.11 [ 84.092535] mempolicy: Request by 'ps' to set policy to 5 ignored [ 84.092553] mempolicy: Request by 'ps' to set policy to 3 ignored [ 261.550048] mempolicy: Request by 'ps' to set policy to 5 ignored [ 261.550065] mempolicy: Request by 'ps' to set policy to 3 ignored [ 643.744771] tty0tty: loading out-of-tree module taints kernel. [ 643.750941] tty0tty null modem driver v1.4 epsilonrt@r14:~/src/tty0tty/module$ ls /dev/tnt* /dev/tnt0 /dev/tnt1 /dev/tnt2 /dev/tnt3 /dev/tnt4 /dev/tnt5 /dev/tnt6 /dev/tnt7 Also, the same error occurs with another driver like v4l2loopback: epsilonrt@nanopineocore2:~/src/v4l2loopback$ sudo modprobe v4l2loopback modprobe: ERROR: could not insert 'v4l2loopback': Exec format error epsilonrt@nanopineocore2:~/src/v4l2loopback$ modinfo v4l2loopback filename: /lib/modules/6.12.20-current-sunxi64/updates/v4l2loopback.ko alias: char-major-10-255 license: GPL version: 0.14.0-25-g8d806ad author: Vasily Levin, IOhannes m zmoelnig <zmoelnig@iem.at>,Stefan Diewald,Anton Novikovet al. description: V4L2 loopback video device srcversion: FC835C7E0E75B1C90BC5391 depends: videodev name: v4l2loopback vermagic: 6.12.20-current-sunxi64 SMP mod_unload aarch64 parm: debug:debugging level (higher values == more verbose) (int) parm: max_buffers:how many buffers should be allocated [DEFAULT: 2] (int) parm: max_openers:how many users can open the loopback device [DEFAULT: 10] (int) parm: devices:how many devices should be created (int) parm: video_nr:video device numbers (-1=auto, 0=/dev/video0, etc.) (array of int) parm: card_label:card labels for each device (array of charp) parm: exclusive_caps:whether to announce OUTPUT/CAPTURE capabilities exclusively or not [DEFAULT: 0] (array of bool) parm: max_width:maximum allowed frame width [DEFAULT: 8192] (int) parm: max_height:maximum allowed frame height [DEFAULT: 8192] (int) epsilonrt@nanopineocore2:~/src/v4l2loopback$ uname -a Linux nanopineocore2 6.12.20-current-sunxi64 #1 SMP Sat Mar 22 19:54:28 UTC 2025 aarch64 GNU/Linux epsilonrt@nanopineocore2:~/src/v4l2loopback$ lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Armbian 25.2.3 bookworm Release: 12 Codename: bookworm You can find all the details at armbian/build#8153 For all my tests I use the images available for download on the Armbian site. It appears that the driver compliance checking system is corrupted on Armbian sunxi64. Could the team look into this issue ? Thanks.
So.. this neat board has mainline kernel but with no video output and it has a mali panfrost GPU. My question to all you dev pros of the kodi tv boxes is... Is there anyone capable to fix video output on this wee board that has it on radxa 5.15 default debian kernel?
no access all links to your images are not available
Они видны, но не работают. root@x98h:~# lsusb Шина 005 Устройство 002: ID 8301:0089 Беспроводная клавиатура Hapurs HPBT05R 2.4 G Mini Wireless Touchpad Шина 005 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 003 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 004 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 002 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 006 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 001 Устройство 003: ID 148f:7601 Ralink Technology, Corp. Беспроводной адаптер MT7601U Шина 001 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 007 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Лучше всего работает: Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop., но нет Wi-Fi и звука. dmesg.txt
Thank you very much. As usual I tried to get into the wrong car)) I will try
There is a stripped-down firmware in the Armbian images. Update it using armbian-config. Maybe the USB-WI-FI will work. But keep in mind that the updated firmware will take about 1 GB of memory.
pithecanthrope, That DTS is specific for the raspberry pi lcd... not for the red pcb ili9486. Do you have that? You can name the DTS any filename, for example ~/ili9486/ili9486-35.dts cd ~/ili9486-35 sudo armbian-add-overlay ili9486-35.dts The command will also add it to armbianEnv.txt Make sure to not add any other overlays related to SPI It is very nice that the raspberry pi lcd doesn't need us to fabricate a custom cable, just plug it in the correct orientation. Are you using Linux 6.12?
HI @kratz00. I'm indeed trying to get myself familiiarized with the build system and making pull requests for this and some other little nitpicky things that I think might help others. Hi @Nova, There is also the Helios64, also from Kobol: https://kobol.io/ There have been some issues with it though, related to the DFS function and the 2.5Gbe NIC hardware. I'm running mine for some years already, albeit still on Buster (from 2020 with kernel 5.9.13). Also I am not using the DFS function and set the CPU frequency (fixed governor either powersave or performance) explicitly before it starts backing up (it's my long term backup server). Most probably the newest armbian will run without major issues - except the 2.5Gbe NIC functionality as that was hardware related. Groetjes, PS I'm not affiliated with Kobol in any way whatsoever.
Please give me a link to your image. I'm trying to make a micro computer for my child, so I'm puzzled by remaking the console, if he wants to watch cartoons he'll figure it out. This is useful, the kid is 6 years old and he only watches cartoons, both on TV and on the phone.
Unfortunately, the USB adapter was not detected either, there is still no sound. this image used: Armbian-unofficial_25.05.0-trunk_Transpeed-8k618-t_bookworm_edge_6.12.11_xfce_desktop.img
@incbot just use a fresher image rather than a two years old one: https://github.com/armbian/community/releases/tag/25.5.0-trunk.444
@svyatoslav there’s android firmware but the Linux driver is old. Your dmesg doesn’t show any wifi info because there’s no driver. Unless you know how modify kernel drivers I would forget about it and use a usb wifi adapter.
firepower https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_Vontar-h618_bookworm_edge_6.12.11_xfce_desktop.img.xz https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_Transpeed-8k618-t_bookworm_edge_6.12.11_xfce_desktop.img.xz this?
E: Unable to correct problems, you have held broken packages. [💥] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [💥] Cleaning up [ please wait for cleanups to finish ]
There was ssv6x5x android drivers in the tanix and vontar firmware i upload. You could try them.
Hi catotinha, Once you know the ip that the router assigned to you (if you go to the settings of the router where you have the devices connected, and see there what the Orange Pi is) just make it in Windows that you are on the same network with the command line with administrator privileges "ssh root@192.168.1????. Then enter "root" and "1234". Then just ask ChatGPT for help and a whole world of possibilities opens up. I was just yesterday asking him for help, since mine, from time to time, freezes". So good luck, and please share your experience. It may also be useful to me. Big hug,
Need Kernel source for linux-image-current-sunxi64 6.12.20
ovacikar replied to ovacikar's topic in Orange Pi Zero 2
This 3rd party module needs both kernel headers and kernel source. The Makefile bundled with the code applies patches to an existing kernel module source code and compiles it. I ran the build script on a separate debian vm and created a tarball of the source tree. i will try to transfer it to the opi later today. -
Gustavo Noronha helps break down C++ and shows how that knowledge can open up new possibilities with Rust. View the full article
going replied to ovacikar's topic in Orange Pi Zero 2
The kernel headers that you have installed are quite enough to build the kernel module, the source codes of which you have. If the source codes are already in the kernel, then you just need to configure the kernel before compiling. launch: After you finish the configuration, the build system saves your configuration file (it will tell you where it did it). Save it under the name ./config/kernel/linux-sunxi64-current.config It is assumed that you are in the armbian/build directory. launch: ./compile.sh BOARD=orangepizero2 BRANCH=current kernel -
@svyatoslav there’s a driver for the wifi chip but it only works on older kernels. You’ll need to port the code over to the latest kernel. https://github.com/paolosabatino/ssv6x5x/tree/master Click on the show csc/wib/eos/tvb button. You will see x98h and other h618/h616 boxes there.
Good day people. Tell me, there is an ancient 4k ULTRA HD PRO 2/16 Gb H96MAX box (blue board). After installing armbian 23.08.0 on it, everything works well RIGHT AWAY even without using overlays. However, after apt upgrade, armbian25.2.3 arrives and the system hangs at boot. The inspection showed that in/boot/dtb/( in reality it is/boot/dtb-6.3.13-rockchip64/rockchip) there is no hardware tree). Moving the hardware tree from 23.08.0 allows the system to boot, but hdmi hangs (by ssh the system works, but the screen of the real console hangs). In addition, WiFi is no longer visible (it is not in the settings at all), connection is possible only by RJ45. Question: are there any chances to make 25.2.3 work normally (and what is needed from me for this) or just fix the system on 23.08.0? PS Many thanks to the community for working image 23.08.0
@kvvvp try this sudo update-alternatives --set iptables /usr/sbin/iptables-legacy sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy
