Meanwhile, I have enabled ADB and debugging over wifi, and have connected to cli: 127|rk3528_box:/ $ uname -a Linux localhost 5.10.157-ab10 #319 SMP PREEMPT Sat Nov 11 21:49:28 CST 2023 aarch64 Toybox I think it is possible to copy firmware image from ADB session. If someone did/have instructions please point here.
I found this I hope it helps you @Luiz-SP
thanks @darcyg if you can, share it with us -
CubieTruck: Attempted to kill init after kernel update to 6.6.75?
David A replied to Crazyphil's topic in Allwinner sunxi
Same issue with Armbian 25 / kernel 6.6 😞 -
Hello there, I recently gained remote access to a Banana Pi F3 to test it, and everything went smoothly. The board was running Bianbu Linux, and I was able to install and use Docker without issues. Now, I'm considering purchasing the board and was wondering if the Armbian image would also support running Docker. Do you have any insights on this? Thanks!
darcyg replied to Hqnicolas's topic in Rockchip CPU Boxes
hey, @cmuki! Using the dts from the rk3576-evb1-v10 / rk3576-armsom-sige5 / rk3576-rock-4d in the https://github.com/radxa/kernel/arch/arm64/boot/dts/rockchip/ directory After modification, they can all boot the Armbian version h96-m9s Note: The rk3576-linux.dtsi file forcibly specifies the UUID of the rootfs device partition, which may cause system boot failure. Adjustments might be needed. The basic modification method is simple: disable the PCIe and GMAC1 configurations, modify the reset_pin configuration of GMAC0 to gpio2 and PB3 to enter the system. I used rock-4d as the template for modification. Other modifications have not been thoroughly studied yet. -
Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
hi, ubuntu22 gome desktop How to fix USB sound card with card1 identifier 1
Build Image with Debian 12 VM on QubesOS
Werner replied to joejoe44's topic in Advanced users - Development
Have you tried installing qemu-user-static package manually and retry? -
Tried a few hours later? Alternativly you can choose a fixed mirror from here: https://docs.armbian.com/Mirrors/
@Nick A oh your build for the Tanix TX6S worked perfectly for me already (thanks!) though I did notice some weird behaviour on my other box that's supposed to be identical to this one. stuff like armbian-config freezing when trying to format the eMMC mainly. I noticed a hang in the kernel in the dmesg when that happened so I suspect there might be some minor difference in the hardware that I'll look into later. for right now I've moved to a box with an amlogic s905y4, which is a whole other can of worms. I got debian-on-amlogic to boot so I'm hoping I can copy over the u-boot and dtb in other to get armbian working on it, since it has more features for SBCs. thanks for your help nick!
@jwillb00 try this build. https://github.com/LYU4662/t95zplus-h618-build
Hi everyone, I'm having trouble recovering my Android TV box T95 Max with the following specs: CPU: Allwinner H616 RAM: 4GB ROM: 32GB Board: AXP313A V3.0 The box was freezing after boot, so I tried to reflash the firmware using PhoenixCard / suit. What I’ve Tried So Far: Downloaded and flashed T95-H616-A27.img & T95-H616-A29.img through FEL mode and Flashing completed successfully but the box only shows a black screen on both HDMI and the small front panel screen. Tried other firmware images labeled for T95 Max H616 AXP313A Tried re-burning the SD using different cards and readers I found a working Armbian img that worked from SD card: https://github.com/NickAlilovic/build/releases/download/v20240716/Armbian-20240716-unofficial_24.5.0-trunk_Transpeed-8k618-t_bookworm_edge_6.7.12_xfce_desktop_Secure_Boot.img.tar.xz I want to restore the TV box to a working firmware (Android 10 or 12) if possible. And is there any method to revive bootloader if it's corrupted Any working image file would be a huge help. Board Image attached:
I'm on the most recent Armbian 25.2.3 Noble version. When I try the command $ yes | sudo apt dist-upgrade I get the following error: Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done Get more security updates through Ubuntu Pro with 'esm-apps' enabled: ... Learn more about Ubuntu Pro at https://ubuntu.com/pro The following upgrades have been deferred due to phasing: gnome-shell gnome-shell-common ubuntu-drivers-common The following packages will be upgraded: thunderbird 1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. Need to get 68.6 MB of archives. After this operation, 453 kB of additional disk space will be used. Get:1 http://apt.armbian.com noble/noble-desktop arm64 thunderbird arm64 9:128.10.1+build1-0ubuntu0.24.04.1~mt1armbian1 [68.6 MB] Err:1 http://apt.armbian.com noble/noble-desktop arm64 thunderbird arm64 9:128.10.1+build1-0ubuntu0.24.04.1~mt1armbian1 File has unexpected size (68620562 != 68620660). Mirror sync in progress? [IP: 2a01:4f9:3b:4943::2 80] Hashes of expected file: - SHA512:e49ee18c96333c4dfbb188458a3fb8ce271874d1aaf830ce4aed2ff5b3f59220cc4ead01243323047a6d7ef7258b6f2f66f5d231ea83dfc53356e4d9aeeef0d6 - SHA256:581efd7ac140c5c416648efad6fcea96ed4cccc9db6e8300b6200860399d9f5c - SHA1:de05de93f62cf5b298bddbdc65fcb95fe0c4062e [weak] - MD5Sum:91c1809c8ca059ebdfb71787b02f3b4b [weak] - Filesize:68620660 [weak] E: Failed to fetch http://fi.mirror.armbian.de/apt/pool/noble-desktop/t/thunderbird/thunderbird_128.10.1+build1-0ubuntu0.24.04.1~mt1armbian1_arm64.deb File has unexpected size (68620562 != 68620660). Mirror sync in progress? [IP: 2a01:4f9:3b:4943::2 80] Hashes of expected file: - SHA512:e49ee18c96333c4dfbb188458a3fb8ce271874d1aaf830ce4aed2ff5b3f59220cc4ead01243323047a6d7ef7258b6f2f66f5d231ea83dfc53356e4d9aeeef0d6 - SHA256:581efd7ac140c5c416648efad6fcea96ed4cccc9db6e8300b6200860399d9f5c - SHA1:de05de93f62cf5b298bddbdc65fcb95fe0c4062e [weak] - MD5Sum:91c1809c8ca059ebdfb71787b02f3b4b [weak] - Filesize:68620660 [weak] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? It seems like some checksum or some other validation data doesn't match the actual data. Thanks for any guidance on this matter.
Hi, sorry to bother you again. I recently tried to use latest Armbian 25.2.2 Bookworm and unfortunately 10mbps mode is not working. I suppose there is a regression. @brentr May I kindly ask you to have a look again at this topic? Cheers
These forums are for Armbian Linux issues. This is not the place to ask for android firmwares.
Hello I am using a Debian 12 VM on Qubes OS 4.2 to attempt to build an Armbian image for a Rockpro64. As you can see by the build logs, these 3 commands are failing: update-binfmts --enable qemu-arm update-binfmts --enable qemu-aarch64 update-binfmts --enable qemu-riscv64 Then arch-test command output causes script to error out with: arm64: not supported on this machine/kernel So far I have attempted to enter the docker container and manually run the command but I get this error: root@1631353b980f:/armbian# update-binfmts --enable qemu-arm update-binfmts: warning: qemu-arm not in database of installed binary formats. update-binfmts: exiting due to previous errors Any help is greatly appreciated as I continue to try solving this, thank you!
Good afternoon everyone. I need your help. I have an Android TV Box TX9 and I need the ROM (Firmware) for it because I can't find it anywhere. Could someone help me download this firmware so I can resurrect my device? Thank you all.
@jwillb00 I’m using miniarch patches with my build. This is kernel 6.12. I also have 6.14. When I have time I’ll update to 6.15. https://github.com/NickAlilovic/build/tree/v20250306/patch/u-boot/u-boot-h616 https://github.com/NickAlilovic/build/tree/v20250306/patch/kernel/archive/warpme-6.12
In this second article of a three-part series, I look at how Matt Godbolt uses modern C++ features to try to protect against misusing an API that deals with destructive state transition based on a talk he gave on making code easy to use and hard to misuse. View the full article
