Hello everyone, I followed the configuration steps for the st7735s LCD driver, and here are the details of my setup and observations so far: Configuration Files and Commands /boot/overlay-user/st7735s-fb5.dts Command used: armbian-add-overlay /boot/overlay-user/st7735s-fb5.dts dmesg Output Filtered dmesg output related to framebuffer or SPI: Observations Based on dmesg, the driver and display appear to be detected. Relevant messages are logged during updates. The command fbi works correctly, and running cat /dev/fb0 reveals some data. However, the display remains bright white, and nothing is visible on the screen. I attempted to test various initialization sequences (the commented-out sections in the overlay file) but without success. Next Steps Before writing this post, I wanted to conduct more testing, particularly with the LCD initialization parameters, but I'm unsure how to proceed further in debugging this issue. I'd appreciate any advice or suggestions to resolve the display issue! Thanks in advance for your help.
When I switched to trixie lxde was not yet available, therefore I have been working with lxqt (x11) for almost a year now. With your message I realised there is lxde for trixie. Since the mirroring problem I found myself looking for a wayland "windowmanager" a few weeks ago. Installing labwc and the sid-package "lxqt-wayland-session" you can use lxqt with wayland. I have been using lxqt/wayland for a few days now. Some functions are missing (I do miss the oxygen mouse cursors in wayland). Can't say much about stability yet. So YMMV. If you lookup lxqt/wayland on github you'll find it is a recent development, somewhere between alpha and beta stage. However if your strict on kde, lxqt might not be for you since it is qt-based (althought the looks of lxde are mostly similar).
@NiTr0 I guess transferring the dtb to official armbian kernel 6.12.43 will work. Most of warpme’s collection of patches are already in the official armbian build. There might be some differences. the reason I use warpme patches is because he’s usually quick at porting his patches to the latest kernel versions. I made a 6.18 build but I haven’t had time to test it yet. Don’t worry about those wifi errors it will work fine.
kernel update actually works, I'm now on -current mainline kernel (-edge works OK too); trouble is only in .dtb in mainline package # uname -a Linux transpeed-8k618-t 6.12.43-current-sunxi64 #1 SMP Wed Aug 20 16:30:58 UTC 2025 aarch64 GNU/Linux thanks; there are brcmfmac4334-sdio.bin and brcmfmac4334-sdio.rockchip,rk3318-box.txt; I've renamed them to brcmfmac4334-sdio.transpeed,8k618-t.bin and brcmfmac4334-sdio.txt - wifi appears in device list, there are some strange messages in dmesg but I think it'll work ok [23108.014126] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3 [23108.023494] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2 [23108.214552] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [23108.214581] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2) [23108.214910] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
Well, I do think X11 is going to fall behind at some point if it continues to lack support of new things. I don't know the status for gaming on Wayland. I use lutris and wine to play WoW. Which doesn't yet work on these machines. Perhaps with 6.16. I'm an Xmonad user and I wouldn't touch gnome or kde with a ten foot pole. I'll use fvwm2 in a pinch. So far there isn't a "wm" on Wayland that compares to Xmonad, and I wouldn't use hypr land or any thing related to it for politics. Nasty people. Sway is the most promising at the moment, but it is too close to i3 which is too limited. There is no way Xmonad will become a compositor. So something has to happen. Not using 2 screens might be the easiest. I don't need two. But the Nanopi m6 has two. I can just get another without a screen and use this one as a server. Just living in the increasingly limited realm of X11 seems to be the thing to do unless I want to write a compositor. I've thought about adding compositing abilities to emacs. Someone has done a bit of that. Might be politically difficult to get it in. It would also mean writing a new Exwm. I'll just hang on to X because Wayland still doesn't meet my needs, and it has nothing capable of replacing what I have on X.
@emor acid Here's some information on H616/H618 ethernet phy. This is the 100Mbit ethernet built inside the H618 SOC. https://lore.kernel.org/linux-sunxi/20250526002924.2567843-1-james.hilliard1@gmail.com/T/#t In your dmesg log it shows your box is loading a generic phy. It should be loading the Allwinner phy. For example @NiTr0 logs above. Your box might be using a 1000Mbit external ethernet chip. If that's the case your dts settings will be very different. You'll need check if your box supports Gigabit Ethernet and find the Ethernet chip on your board. @NiTr0 Just freeze the kernel updates using armbian-config. My armbian build is unofficial so you can't use the official armbian kernels. I'm using patches created by warpme and my own custom patches. So the kernel update feature will not work. https://www.google.com/search?q=armbian+config+freeze+kernel&oq=armbian+config+freeze+kernel&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCDY4MDJqMGo3qAIAsAIA&sourceid=chrome&ie=UTF-8 For wifi your box is looking for You need find the brcmfmac4334 bin file and rename it to brcmfmac4334-sdio.transpeed,8k618-t.bin. Also, the brcmfmac4334 txt to brcmfmac4334-sdio.txt. I think it's already in /lib/firmware/brcm under a different name.
labwc (wayland) crashes on exit
robertoj replied to robertoj's topic in Software, Applications, Userspace
This bug is not showing again with Trixie, and the repository labwc 0.8.3 (same), same orange pi zero 3, same HDMI monitor. -
@Nick A here, compile with this patch +&mdio1 { + rmii_phy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; +}; journalctl.log dmesg.log
First resize framebuffer to a convenient one and then start x11vnc xrandr --fb 1920x1080 -d :0 x11vnc -display :0
One suggestion I can give you is to try a fresh image from https://github.com/armbian/community/releases. Make a backup of the eMMC and clean it up (multitool can do both things), then try to boot from sdcard with the new image. Newer images come with u-boot v2025.10-rc5 and a "fix" to reset the VOP before entering the kernel. Some people on the other thread reported that disabling u-boot HDMI made the HDMI work once in Linux. With kernel 6.17 this issue hit my box and I could arrange a fix, perhaps this fix will address your problem too (for reference: https://github.com/armbian/build/pull/8674/files#diff-70c2c867b6e2024080868c0d5c3230d58be2d2c4b88a24291b0469c7d2229629)
IR receiver stops working after suspend/resume
The Tall Man replied to tanod's topic in Orange Pi 5 Plus
I've never been able to wake up my Orange PI 5 Plus from suspend. It just goes into oblivion - requiring a hard restart. The keyboard and mouse don't wake it up. Tapping the power button doesn't wake it up. I've tried it on Armbian as well as pure Debian Trixie. Apparently something is off in the design of the SBC. But also hibernation doesn't work (again in Armbian and in pure Trixie). Using a 32 GB (32 * 1024^3) swap for a "32 GB" (actually around 31 GB) RAM device, and setting RESUME to the swap partition, the hibernation option appears. But when used, it just goes into oblivion (like suspend). I left it alone like that once for about 20 minutes, it was still in limbo. and when I (have to) hard restart it, the previous supposedly-hibernated state is gone. Given that the SBC is capable of doing a power shutdown from the OS (i.e. after dumping allocated RAM to the swap), there is no legitimate reason for hibernation to not work. But it doesn't. -
Armbian_25.8.2_Orangepi5_noble_current_6.12.49.img.xz fails to boot
djtecha6 replied to djtecha6's topic in Orange Pi 5
Just to help anyone else that ran into this. I was able to get up and running by Armbian_25.8.2_Orangepi5_noble_current_6.12.49_minimal (1).img.xz then on boot I found the IP address on my network and SSH'd to it. Once on I used armbian-config to go and fetch the edge kernel 6.16.4-edge-rockchip64 Display is now working, but the older USB for the keyboard doesn't work. Only the USB 3.0 does. -
Thanks, ok this works but only over SSH. Maybe the other ones did too and the fact my monitor wouldn't turn on for them had me stuck. -
Those who are not getting hardware acceleration in Trixie, should compile their own mpv-0.4.0 with patches (in addition of using the ffmpeg-v4l2request deb version) Some guidelines here: https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/page/5/#findComment-226875
Hello everyone, is there a solution to install Armbian on it? Thanks to all the experts.
I compiled kernel on debian vm which I just brought up via Vagrant but I guess that maybe I assigned not enough vCPUs to this vm (just 1). Yes, you're right, real kernel package is much smaller as around 103M vagrant@test-debian12:~/build/output/debs$ ls -lh linux-image-current-meson_25.11.0-trunk_armhf__6.12.51-Sa915-D8343-P0029-C8d22H47a6-HK01ba-Va132-B14f4-R448a.deb -rw-rw-r-- 1 vagrant root 103M Oct 9 17:43 linux-image-current-meson_25.11.0-trunk_armhf__6.12.51-Sa915-D8343-P0029-C8d22H47a6-HK01ba-Va132-B14f4-R448a.deb I think I will go with using this new Armbian disk Image (this 1.3 GB file ;-)) so it will be easier to get this working. I have copy of my old drive so I don't have to worry about loosing any data . To be honest, I very occasionally compiling something from sources not even mention of cross-compiling kernel even if I use Linux on daily basis (work and home). I really appreciate your time in helping me with this and I think this information is very valuable as many people are still using the Odroid C1 board. Many Thanks !!!
Ok, I was trying to work out what you were doing, as 1.3GB is an insanely large size for the kernel (it is 12MB on my system!), but I think I have now (and why it took so long). I'm guessing at the following. If I am incorrect, I apologise. At a guess I would say that you ran that ./compile command directly on your Odroid? Is that correct? If so, that will be why it took so long (you are meant to build the image on a different, more powerful, host device). What you did was fine, but it is (obviously) slower as it is a fairly underpowered device. Secondly, I think you are misunderstanding what you have done. I believe the file in output/images you are talking about is this (or named similar): -rw-rw-r-- 1 user root 1.4G Oct 10 13:45 Armbian-unofficial_25.11.0-trunk_Odroidc1_trixie_current_6.12.51_minimal.img This is not the kernel. This is the entire Odroid C1+ image (including boot and rootfs partitions) to be burned to SD/eMMC. It is basically an updated version of what you downloaded as a standard image. You are meant to take this file and burn it to your media, as you did with the standard image. That would be the easiest step now (copy that file off your Odroid, burn it to your eMMC, place burned image back into your Odroid and go back through first run setup). It may also be possible to just install your new kernel, which was built as part of the above process. Note: I have never done this before, but I see no reason why it shouldn't work (you can always fallback to burning the whole image if this doesn't work, just copy the .img file off first). This would leave you on Bookworm/Noble though rather than Trixie, which may be fine for you. Within the build/output/debs folder you should find a series of debian (.deb) packages. These will include the kernel (it will be the one which starts linux-image-current-meson_25.11.0-trunk_armhf__6.12.xx). You can install this with: Note: Update <kernel file name> to the correct name of your kernel sudo dpkg -i build/output/debs/<kernel file name>.deb I would also be installing any of the other deb packages in that folder with the kernel version number in the name (ie __6.12.51.xx) as most likely those packages will be required as they will have been built against your new kernel. Whichever way you go, once done, you can reclaim the space from the build process by just deleting the build folder. It is only needed for the build process to generate the images/packages. Once these images/packages have been installed, the build folder is no longer required.
I've reinstalled armbian on flash, switched to -current kernel branch and replaced .dtb with valid one - device boots OK, except wifi (it's still unavailable), btw I don't need wifi on it. so I have a question: how to copy .dtb at each kernel update? Or it'll be easier just to forbid kernel update (how to do this?) Here's bootlog: U-Boot SPL 2025.01-armbian-2025.01-S6d41-P65b3-H8869-Va3a9-Bb703-R448a-dirty (Oct 08 2025 - 13:44:47 +0300) DRAM:testing 32-bit width, rank = 2 read calibration failed! testing 32-bit width, rank = 1 DRAM:Store cfg DRAM:1st writing pattern DRAM:detecting column address bits detected 11 columns DRAM:restore cfg DRAM:reconfigure for all active rows DRAM:store cfg DRAM:2nd writing pattern DRAM:detecting row address bits detected 16 rows DRAM:restoring cfg DRAM:end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.14(debug):armbian NOTICE: BL31: Built : 13:42:51, Oct 8 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0a3760, model: Transpeed 8K618-T INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.01-armbian-2025.01-S6d41-P65b3-H8869-Va3a9-Bb703-R448a-dirty (Oct 08 2025 - 13:44:47 +0300) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: Transpeed 8K618-T DRAM: 4 GiB Core: 68 devices, 22 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: apply fix for AC300 ephy bb version bug ... using AC300 emac1 ephy default config ... eth0: ethernet@5030000 starting USB... Bus usb@5101000: sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@5101400: USB OHCI 1.0 Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5101000 for devices... 1 USB Device(s) found scanning bus usb@5101400 for devices... 1 USB Device(s) found scanning bus usb@5200000 for devices... 1 USB Device(s) found scanning bus usb@5200400 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 8 ms (566.4 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 205 bytes read in 7 ms (28.3 KiB/s) The file allwinner/sun50i-h618-transpeed-8k618-t.dtb was not found in the path /boot/dtb/allwinner Load fdt: /boot/dtb/allwinner/sun50i-h618-transpeed-8k618-t.dtb 37503 bytes read in 18 ms (2 MiB/s) Working FDT set to 4fa00000 Failed to load '/boot/dtb/overlay/sun50i-h616-fixup.scr' 25209433 bytes read in 1290 ms (18.6 MiB/s) 38217736 bytes read in 1952 ms (18.7 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42760000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 25209369 Bytes = 24 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 487f5000, end 49fffa19 ... OK Loading Device Tree to 0000000048783000, end 00000000487f4fff ... OK Working FDT set to 48783000 Starting kernel ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.41 [/sbin/fsck.ext4 (1) -- /dev/mmcblk2p1] fsck.ext4 -a -C0 /dev/mmcblk2p1 armbi_root: clean, 44150/460672 files, 540723/1903616 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Armbian 25.11.0-trunk.38 trixie! and dmesg: [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.12.43-current-sunxi64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP Wed Aug 20 16:30:58 UTC 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Transpeed 8K618-T [ 0.000000] OF: reserved mem: 0x0000000040000000..0x000000004007ffff (512 KiB) nomap non-reusable secmon@40000000 [ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000013fffffff] [ 0.000000] NODE_DATA(0) allocated [mem 0x13f7d26c0-0x13f7d477f] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x000000004007ffff] [ 0.000000] node 0: [mem 0x0000000040080000-0x000000013fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff] [ 0.000000] cma: Reserved 128 MiB at 0x00000000f8000000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 31 pages/cpu s89496 r8192 d29288 u126976 [ 0.000000] pcpu-alloc: s89496 r8192 d29288 u126976 alloc=31*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=19261dfd-7753-43cf-91f1-a7dbdbdd0887 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=0ab155bb-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=0ab155bb-01 cgroup_enable=memory", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1048576 [ 0.000000] Policy zone: Normal [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000f4000000-0x00000000f8000000] (64MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 52395 entries in 205 pages [ 0.000000] ftrace: allocated 205 pages with 5 groups [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000571] Console: colour dummy device 80x25 [ 0.000584] printk: legacy console [tty1] enabled [ 0.000752] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000767] pid_max: default: 32768 minimum: 301 [ 0.000851] LSM: initializing lsm=capability,yama,apparmor,ima,evm [ 0.000926] Yama: becoming mindful. [ 0.001155] AppArmor: AppArmor initialized [ 0.001334] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.001361] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.003884] rcu: Hierarchical SRCU implementation. [ 0.003892] rcu: Max phase no-delay instances is 1000. [ 0.004186] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.005086] smp: Bringing up secondary CPUs ... [ 0.005666] Detected VIPT I-cache on CPU1 [ 0.005768] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.006402] Detected VIPT I-cache on CPU2 [ 0.006456] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.007037] Detected VIPT I-cache on CPU3 [ 0.007093] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.007177] smp: Brought up 1 node, 4 CPUs [ 0.007192] SMP: Total of 4 processors activated. [ 0.007197] CPU: All CPU(s) started at EL2 [ 0.007203] CPU features: detected: 32-bit EL0 Support [ 0.007209] CPU features: detected: CRC32 instructions [ 0.007260] alternatives: applying system-wide alternatives [ 0.008280] Memory: 3847692K/4194304K available (17472K kernel code, 2506K rwdata, 10900K rodata, 6336K init, 865K bss, 210320K reserved, 131072K cma-reserved) [ 0.009745] devtmpfs: initialized [ 0.016132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.016156] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.019975] 23200 pages in range for non-PLT usage [ 0.020060] 514720 pages in range for PLT usage [ 0.020381] pinctrl core: initialized pinctrl subsystem [ 0.023505] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.024521] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.024650] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.024841] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.024878] audit: initializing netlink subsys (disabled) [ 0.025331] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1 [ 0.025717] thermal_sys: Registered thermal governor 'fair_share' [ 0.025724] thermal_sys: Registered thermal governor 'bang_bang' [ 0.025730] thermal_sys: Registered thermal governor 'step_wise' [ 0.025736] thermal_sys: Registered thermal governor 'user_space' [ 0.025783] cpuidle: using governor menu [ 0.026001] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.026108] ASID allocator initialised with 65536 entries [ 0.026282] Serial: AMBA PL011 UART driver [ 0.031457] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.031527] /soc/interrupt-controller@3021000: Fixed dependency cycle(s) with /soc/interrupt-controller@3021000 [ 0.031622] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.031658] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.031677] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.031695] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000 [ 0.031735] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.032150] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.034174] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.034529] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.034601] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.034667] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.034734] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.034754] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000 [ 0.034921] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.034996] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.038774] /soc/hdmi@6000000: Fixed dependency cycle(s) with /connector [ 0.038847] /connector: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.040501] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.040512] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.040521] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.040526] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.040533] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.040539] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.040546] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.040551] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.041613] cryptd: max_cpu_qlen set to 1000 [ 0.108174] raid6: neonx8 gen() 1901 MB/s [ 0.176236] raid6: neonx4 gen() 1864 MB/s [ 0.244301] raid6: neonx2 gen() 1786 MB/s [ 0.312373] raid6: neonx1 gen() 1526 MB/s [ 0.380450] raid6: int64x8 gen() 1186 MB/s [ 0.448503] raid6: int64x4 gen() 1319 MB/s [ 0.516579] raid6: int64x2 gen() 1175 MB/s [ 0.584638] raid6: int64x1 gen() 869 MB/s [ 0.584645] raid6: using algorithm neonx8 gen() 1901 MB/s [ 0.652698] raid6: .... xor() 1389 MB/s, rmw enabled [ 0.652705] raid6: using neon recovery algorithm [ 0.653326] iommu: Default domain type: Translated [ 0.653335] iommu: DMA domain TLB invalidation policy: strict mode [ 0.653921] SCSI subsystem initialized [ 0.654105] usbcore: registered new interface driver usbfs [ 0.654142] usbcore: registered new interface driver hub [ 0.654178] usbcore: registered new device driver usb [ 0.654483] pps_core: LinuxPPS API ver. 1 registered [ 0.654490] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.654510] PTP clock support registered [ 0.654890] scmi_core: SCMI protocol bus registered [ 0.655129] Advanced Linux Sound Architecture Driver Initialized. [ 0.656018] NetLabel: Initializing [ 0.656024] NetLabel: domain hash size = 128 [ 0.656030] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.656105] NetLabel: unlabeled traffic allowed by default [ 0.656112] mctp: management component transport protocol core [ 0.656118] NET: Registered PF_MCTP protocol family [ 0.656566] clocksource: Switched to clocksource arch_sys_counter [ 0.660223] VFS: Disk quotas dquot_6.6.0 [ 0.660261] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.660469] netfs: FS-Cache loaded [ 0.661006] AppArmor: AppArmor Filesystem Enabled [ 0.669081] NET: Registered PF_INET protocol family [ 0.669341] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.734561] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.734631] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.734650] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.734904] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.735859] TCP: Hash tables configured (established 32768 bind 32768) [ 0.735988] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.736084] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.736352] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.736415] ARM FF-A: FFA_VERSION returned not supported [ 0.736748] Trying to unpack rootfs image as initramfs... [ 0.742067] Initialise system trusted keyrings [ 0.742138] Key type blacklist registered [ 0.742339] workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 0.742391] zbud: loaded [ 0.742909] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.744360] integrity: Platform Keyring initialized [ 0.811001] xor: automatically using best checksumming function 32regs [ 0.811028] async_tx: api initialized (async) [ 0.811041] Key type asymmetric registered [ 0.811048] Asymmetric key parser 'x509' registered [ 0.811197] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.811471] io scheduler mq-deadline registered [ 0.811480] io scheduler kyber registered [ 0.811532] io scheduler bfq registered [ 0.815466] ledtrig-cpu: registered to indicate activity on CPUs [ 0.825407] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled [ 0.836527] loop: module loaded [ 0.839915] usbcore: registered new interface driver usb-storage [ 0.840446] mousedev: PS/2 mouse device common for all mice [ 0.841503] sun6i-rtc 7000000.rtc: registered as rtc0 [ 0.841531] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T01:10:45 UTC (90645) [ 0.841810] i2c_dev: i2c /dev entries driver [ 0.842064] mv64xxx_i2c 5002c00.i2c: can't get pinctrl, bus recovery not supported [ 0.843082] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 0.844483] sdhci: Secure Digital Host Controller Interface driver [ 0.844491] sdhci: Copyright(c) Pierre Ossman [ 0.844520] Synopsys Designware Multimedia Card Interface Driver [ 0.845277] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.845630] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000002 [ 0.846043] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 0.846205] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 0.846313] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 0.846418] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 0.846497] sun8i-ce 1904000.crypto: Register cbc(aes) [ 0.846562] sun8i-ce 1904000.crypto: Register ecb(aes) [ 0.846581] sun8i-ce 1904000.crypto: Register cbc(des3_ede) [ 0.846598] sun8i-ce 1904000.crypto: Register ecb(des3_ede) [ 0.846615] sun8i-ce 1904000.crypto: Register md5 [ 0.846633] sun8i-ce 1904000.crypto: Register sha1 [ 0.846651] sun8i-ce 1904000.crypto: Register sha224 [ 0.846669] sun8i-ce 1904000.crypto: Register sha256 [ 0.846686] sun8i-ce 1904000.crypto: Register sha384 [ 0.846704] sun8i-ce 1904000.crypto: Register sha512 [ 0.846722] sun8i-ce 1904000.crypto: Register stdrng [ 0.846847] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0 [ 0.847238] hid: raw HID events driver (C) Jiri Kosina [ 0.847358] usbcore: registered new interface driver usbhid [ 0.847365] usbhid: USB HID core driver [ 0.848241] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available [ 0.848362] random: crng init done [ 0.859469] NET: Registered PF_INET6 protocol family [ 1.972242] Freeing initrd memory: 24616K [ 2.016072] Segment Routing with IPv6 [ 2.016163] In-situ OAM (IOAM) with IPv6 [ 2.016338] NET: Registered PF_PACKET protocol family [ 2.016373] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 2.016500] 8021q: 802.1Q VLAN Support v1.8 [ 2.016583] 9pnet: Installing 9P2000 support [ 2.016677] Key type dns_resolver registered [ 2.024253] registered taskstats version 1 [ 2.024661] Loading compiled-in X.509 certificates [ 2.036982] zswap: loaded using pool zstd/zbud [ 2.037212] Demotion targets for Node 0: null [ 2.037452] Key type .fscrypt registered [ 2.037459] Key type fscrypt-provisioning registered [ 2.038854] Btrfs loaded, zoned=yes, fsverity=no [ 2.038993] Key type encrypted registered [ 2.039006] AppArmor: AppArmor sha256 policy hashing enabled [ 2.039032] ima: No TPM chip found, activating TPM-bypass! [ 2.039050] ima: Allocated hash algorithm: sha1 [ 2.039084] ima: No architecture policies found [ 2.039161] evm: Initialising EVM extended attributes: [ 2.039167] evm: security.selinux [ 2.039173] evm: security.SMACK64 [ 2.039178] evm: security.SMACK64EXEC [ 2.039183] evm: security.SMACK64TRANSMUTE [ 2.039189] evm: security.SMACK64MMAP [ 2.039193] evm: security.apparmor [ 2.039198] evm: security.ima [ 2.039203] evm: security.capability [ 2.039208] evm: HMAC attrs: 0x1 [ 2.049816] sun8i-mixer 1100000.mixer: Adding to iommu group 0 [ 2.052467] sun4i-drm display-engine: Adding to iommu group 0 [ 2.068388] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff80008122b9c8) [ 2.068553] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800081230798) [ 2.068920] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff8000812285e8) [ 2.068981] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator [ 2.069195] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.069766] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.070027] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff80008122aa90) [ 2.070531] [drm] Initialized sun4i-drm 1.0.0 for display-engine on minor 0 [ 2.070600] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 2.071984] ehci-platform 5101000.usb: EHCI Host Controller [ 2.072009] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1 [ 2.072107] ehci-platform 5200000.usb: EHCI Host Controller [ 2.072127] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 2 [ 2.072403] ehci-platform 5101000.usb: irq 26, io mem 0x05101000 [ 2.072630] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 2.072852] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests (id=vbus) [ 2.073052] ohci-platform 5200400.usb: Generic Platform OHCI controller [ 2.073073] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 3 [ 2.073126] ehci-platform 5200000.usb: irq 27, io mem 0x05200000 [ 2.073181] ohci-platform 5200400.usb: irq 29, io mem 0x05200400 [ 2.080578] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 2.080830] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.080843] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.080853] usb usb1: Product: EHCI Host Controller [ 2.080861] usb usb1: Manufacturer: Linux 6.12.43-current-sunxi64 ehci_hcd [ 2.080869] usb usb1: SerialNumber: 5101000.usb [ 2.081350] hub 1-0:1.0: USB hub found [ 2.081390] hub 1-0:1.0: 1 port detected [ 2.092568] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00 [ 2.092781] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.092794] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.092803] usb usb2: Product: EHCI Host Controller [ 2.092811] usb usb2: Manufacturer: Linux 6.12.43-current-sunxi64 ehci_hcd [ 2.092819] usb usb2: SerialNumber: 5200000.usb [ 2.093199] hub 2-0:1.0: USB hub found [ 2.093234] hub 2-0:1.0: 1 port detected [ 2.132741] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 2.132754] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.132764] usb usb3: Product: Generic Platform OHCI controller [ 2.132772] usb usb3: Manufacturer: Linux 6.12.43-current-sunxi64 ohci_hcd [ 2.132780] usb usb3: SerialNumber: 5200400.usb [ 2.133154] hub 3-0:1.0: USB hub found [ 2.133191] hub 3-0:1.0: 1 port detected [ 2.272604] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 2.272627] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 4 [ 2.272712] ohci-platform 5101400.usb: irq 28, io mem 0x05101400 [ 2.272781] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver [ 2.272800] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5 [ 2.272974] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.272987] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.272997] usb usb5: Product: MUSB HDRC host driver [ 2.273004] usb usb5: Manufacturer: Linux 6.12.43-current-sunxi64 musb-hcd [ 2.273012] usb usb5: SerialNumber: musb-hdrc.4.auto [ 2.273372] hub 5-0:1.0: USB hub found [ 2.273409] hub 5-0:1.0: 1 port detected [ 2.276208] sun50i_cpufreq_nvmem: sun50i-cpufreq-nvmem: unknown speed bin 0x2100, using default bin 0 [ 2.276225] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 2.278224] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 2.278503] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver [ 2.279071] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator [ 2.279740] axp20x-i2c 2-0036: AXP20x variant AXP313a found [ 2.279899] axp20x-i2c 2-0036: AXP20X driver loaded [ 2.282150] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 2.290430] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 2.292140] printk: legacy console [ttyS0] disabled [ 2.292536] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 297, base_baud = 1500000) is a 16550A [ 2.292614] printk: legacy console [ttyS0] enabled [ 2.294231] 5000400.serial: ttyS1 at MMIO 0x5000400 (irq = 299, base_baud = 1500000) is a 16550A [ 2.294518] serial serial0: tty port ttyS1 registered [ 2.296119] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 2.296270] of_cfs_init [ 2.296364] of_cfs_init: OK [ 2.297020] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 2.297096] sunxi-mmc 4020000.mmc: Got CD GPIO [ 2.316651] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 2.320604] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.320895] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.336895] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 2.336928] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.336939] usb usb4: Product: Generic Platform OHCI controller [ 2.336948] usb usb4: Manufacturer: Linux 6.12.43-current-sunxi64 ohci_hcd [ 2.336957] usb usb4: SerialNumber: 5101400.usb [ 2.337575] hub 4-0:1.0: USB hub found [ 2.337617] hub 4-0:1.0: 1 port detected [ 2.360515] mmc2: host does not support reading read-only switch, assuming write-enable [ 2.362583] mmc2: new high speed SDHC card at address 1234 [ 2.363535] mmcblk2: mmc2:1234 SA08G 7.41 GiB [ 2.365608] clk: Disabling unused clocks [ 2.365758] PM: genpd: Disabling unused power domains [ 2.365773] ALSA device list: [ 2.365782] No soundcards found. [ 2.365860] mmcblk2: p1 [ 2.370525] Freeing unused kernel memory: 6336K [ 2.370724] Run /init as init process [ 2.370732] with arguments: [ 2.370739] /init [ 2.370747] with environment: [ 2.370753] HOME=/ [ 2.370759] TERM=linux [ 2.370766] splash=verbose [ 2.370772] ubootpart=0ab155bb-01 [ 2.370779] cgroup_enable=memory [ 2.413424] mmc1: new high speed SDIO card at address 0001 [ 2.560879] usb 3-1: new low-speed USB device number 2 using ohci-platform [ 2.575142] mmc0: new HS200 MMC card at address 0001 [ 2.576081] mmcblk0: mmc0:0001 HBG4e\x05 29.1 GiB [ 2.583030] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 [ 2.591132] mmcblk0boot0: mmc0:0001 HBG4e\x05 4.00 MiB [ 2.592422] mmcblk0boot1: mmc0:0001 HBG4e\x05 4.00 MiB [ 2.790700] usb 3-1: New USB device found, idVendor=04d9, idProduct=1603, bcdDevice= 3.10 [ 2.790736] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.790747] usb 3-1: Product: USB Keyboard [ 2.790756] usb 3-1: Manufacturer: [ 2.815134] input: USB Keyboard as /devices/platform/soc/5200400.usb/usb3/3-1/3-1:1.0/0003:04D9:1603.0001/input/input0 [ 2.951388] hid-generic 0003:04D9:1603.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-5200400.usb-1/input0 [ 2.977742] input: USB Keyboard System Control as /devices/platform/soc/5200400.usb/usb3/3-1/3-1:1.1/0003:04D9:1603.0002/input/input1 [ 3.033105] input: USB Keyboard Consumer Control as /devices/platform/soc/5200400.usb/usb3/3-1/3-1:1.1/0003:04D9:1603.0002/input/input2 [ 3.033450] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-5200400.usb-1/input1 [ 3.120639] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pa not found, using dummy regulator [ 3.120977] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found [ 3.120990] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found [ 3.121000] dwmac-sun8i 5030000.ethernet: IRQ sfty not found [ 3.121239] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator [ 3.121428] dwmac-sun8i 5030000.ethernet: PTP uses main clock [ 3.121460] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0) [ 3.124354] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported [ 3.124381] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported [ 3.124390] dwmac-sun8i 5030000.ethernet: COE Type 2 [ 3.124401] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported [ 3.124410] dwmac-sun8i 5030000.ethernet: Normal descriptors [ 3.124418] dwmac-sun8i 5030000.ethernet: Chain mode enabled [ 3.248941] dwmac-sun8i 5030000.ethernet end0: renamed from eth0 [ 3.942773] EXT4-fs (mmcblk2p1): mounted filesystem 19261dfd-7753-43cf-91f1-a7dbdbdd0887 ro with writeback data mode. Quota mode: none. [ 5.323298] systemd[1]: System time advanced to built-in epoch: Tue 2025-09-09 11:38:33 EEST [ 5.447285] systemd[1]: systemd 257.8-1~deb13u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE) [ 5.447354] systemd[1]: Detected architecture arm64. [ 5.486384] systemd[1]: Hostname set to <transpeed-8k618-t>. [ 5.916241] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported. [ 7.399541] systemd[1]: Queued start job for default target graphical.target. [ 7.434799] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [ 7.437298] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [ 7.439229] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 7.440504] systemd[1]: Created slice user.slice - User and Session Slice. [ 7.440929] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [ 7.441840] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [ 7.442011] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0... [ 7.442379] systemd[1]: Reached target slices.target - Slice Units. [ 7.442551] systemd[1]: Reached target swap.target - Swaps. [ 7.461296] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket. [ 7.462146] systemd[1]: Listening on syslog.socket - Syslog Socket. [ 7.469728] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption. [ 7.470205] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ 7.470599] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [ 7.471157] systemd[1]: Listening on systemd-journald.socket - Journal Sockets. [ 7.471409] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.471526] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.471908] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [ 7.472225] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ 7.479158] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System... [ 7.482972] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 7.487531] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock... [ 7.497139] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System... [ 7.505102] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System... [ 7.505865] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab). [ 7.520536] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 7.532501] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout... [ 7.581928] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes... [ 7.589504] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs... [ 7.605653] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 7.611595] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 7.621857] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse... [ 7.622855] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 7.640485] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 7.640848] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.641293] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.653299] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials... [ 7.669360] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 7.710166] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [ 7.711040] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 7.711725] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock. [ 7.712465] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 7.713611] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [ 7.715233] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 7.716229] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 7.718802] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 7.720701] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.721717] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 7.723473] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.724441] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 7.726393] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.727344] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 7.733566] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 7.733828] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 7.738599] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 7.749308] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully... [ 7.798847] fuse: init (API version 7.41) [ 7.806571] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 7.808955] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.809998] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 7.818016] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 7.823699] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 7.828257] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 7.865394] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 7.900042] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials. [ 7.929219] EXT4-fs (mmcblk2p1): re-mounted 19261dfd-7753-43cf-91f1-a7dbdbdd0887 r/w. [ 7.929754] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ 7.935589] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 7.948451] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 7.949557] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 7.954454] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed... [ 7.954775] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 8.017402] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully. [ 8.018427] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 8.026443] systemd[1]: Starting systemd-resolved.service - Network Name Resolution... [ 8.037198] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... [ 8.149007] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [ 8.155953] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files... [ 8.190439] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ 8.191125] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [ 8.414770] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 8.779701] systemd[1]: Mounting tmp.mount - /tmp... [ 8.839867] systemd[1]: Mounted tmp.mount - /tmp. [ 8.840639] systemd[1]: Reached target local-fs.target - Local File Systems. [ 9.494067] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management. [ 9.498723] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... [ 9.503545] systemd[1]: Starting console-setup.service - Set console font and keymap... [ 9.508838] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data... [ 10.225378] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats... [ 10.285135] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed. [ 10.287173] systemd[1]: Finished console-setup.service - Set console font and keymap. [ 10.287798] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [ 10.287974] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 10.327725] systemd[1]: Received SIGRTMIN+20 from PID 175 (plymouthd). [ 10.357503] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 285 (systemd-binfmt) [ 10.361790] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System... [ 10.421113] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data. [ 10.470159] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System. [ 10.493729] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats. [ 11.092158] zram: Added device: zram0 [ 11.092646] zram: Added device: zram1 [ 11.093079] zram: Added device: zram2 [ 11.166044] systemd[1]: Started systemd-resolved.service - Network Name Resolution. [ 11.166613] systemd[1]: Reached target nss-lookup.target - Host and Network Name Lookups. [ 11.168895] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files. [ 11.174146] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen... [ 11.353382] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0. [ 12.387841] ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture [ 12.387871] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22 [ 12.388125] sunxi-snd-mach soc:ahub_dam_mach: probe with driver sunxi-snd-mach failed with error -22 [ 12.410074] Registered IR keymap rc-empty [ 12.410228] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0 [ 12.410426] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter [ 12.410536] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input3 [ 12.411120] sunxi-ir 7040000.ir: initialized sunXi IR driver [ 12.457259] zram0: detected capacity change from 0 to 4014936 [ 12.564822] mc: Linux media interface: v0.10 [ 12.802723] panfrost 1800000.gpu: clock rate = 432000000 [ 12.802763] panfrost 1800000.gpu: bus_clock rate = 200000000 [ 12.803496] core: _opp_supported_by_regulators: OPP minuV: 1080000 maxuV: 1080000, not supported by regulator [ 12.803513] panfrost 1800000.gpu: _opp_add: OPP not supported by regulators (800000000) [ 12.805159] Adding 2007464k swap on /dev/zram0. Priority:5 extents:1 across:2007464k SS [ 12.805339] Bluetooth: Core ver 2.22 [ 12.805452] NET: Registered PF_BLUETOOTH protocol family [ 12.805459] Bluetooth: HCI device and connection manager initialized [ 12.805478] Bluetooth: HCI socket layer initialized [ 12.805488] Bluetooth: L2CAP socket layer initialized [ 12.805504] Bluetooth: SCO socket layer initialized [ 12.807411] panfrost 1800000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0 [ 12.807432] panfrost 1800000.gpu: features: 00000000,000027f7, issues: 00000000,00000400 [ 12.807442] panfrost 1800000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7 [ 12.807452] panfrost 1800000.gpu: shader_present=0x1 l2_present=0x1 [ 12.825143] [drm] Initialized panfrost 1.2.0 for 1800000.gpu on minor 1 [ 12.890218] videodev: Linux video capture interface: v2.00 [ 14.008422] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 14.078341] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen. [ 14.079001] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 14.079516] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch. [ 14.079695] systemd[1]: Reached target paths.target - Path Units. [ 14.202513] zram1: detected capacity change from 0 to 102400 [ 14.216373] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 14.217483] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 14.218219] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 14.232945] Bluetooth: HCI UART driver ver 2.3 [ 14.232981] Bluetooth: HCI UART protocol H4 registered [ 14.232991] Bluetooth: HCI UART protocol BCSP registered [ 14.233115] Bluetooth: HCI UART protocol LL registered [ 14.233127] Bluetooth: HCI UART protocol ATH3K registered [ 14.233184] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 14.233400] Bluetooth: HCI UART protocol Intel registered [ 14.233575] Bluetooth: HCI UART protocol Broadcom registered [ 14.233639] Bluetooth: HCI UART protocol QCA registered [ 14.233651] Bluetooth: HCI UART protocol AG6XX registered [ 14.233705] Bluetooth: HCI UART protocol Marvell registered [ 14.276639] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 14.280614] cedrus 1c0e000.video-codec: Adding to iommu group 0 [ 14.281908] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 14.396474] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 14.400639] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 14.405126] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 14.405424] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 14.405865] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 14.406125] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 14.406184] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 14.406400] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 14.406483] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 14.406533] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 14.408041] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config. [ 14.412941] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging... [ 14.467898] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status... [ 14.483092] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 14.483860] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 14.485428] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 14.486139] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 14.511995] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3 [ 14.523865] systemd[1]: Reached target bluetooth.target - Bluetooth Support. [ 14.524164] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 14.536326] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.transpeed,8k618-t.bin failed with error -2 [ 14.566286] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2 [ 14.572933] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status. [ 14.581364] Bluetooth: hci0: BCM: chip id 68 [ 14.583869] Bluetooth: hci0: BCM: features 0x0f [ 14.607309] Bluetooth: hci0: BCM4334B0 [ 14.607341] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000 [ 14.613262] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch [ 15.568597] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50 [ 15.646511] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging. [ 15.655285] systemd[1]: Starting systemd-journald.service - Journal Service... [ 17.765734] systemd-journald[449]: Collecting audit messages is disabled. [ 17.886448] systemd[1]: Started systemd-journald.service - Journal Service. [ 17.996517] systemd-journald[449]: Received client request to flush runtime journal. [ 19.097863] Bluetooth: hci0: BCM: features 0x0f [ 19.121506] Bluetooth: hci0: BCM4334B1 37.4 MHz ExtLNA Murata VM [ 19.121529] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1852 [ 25.444154] systemd-journald[449]: /var/log/journal/799574e4576441e8a38a6aa7819880e3/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating. [ 25.444216] systemd-journald[449]: Rotating system journal. [ 51.316081] RPC: Registered named UNIX socket transport module. [ 51.316105] RPC: Registered udp transport module. [ 51.316110] RPC: Registered tcp transport module. [ 51.316114] RPC: Registered tcp-with-tls transport module. [ 51.316118] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 66.481569] systemd-journald[449]: Received client request to relinquish /var/log/journal/799574e4576441e8a38a6aa7819880e3 access. [ 110.706220] dwmac-sun8i 5030000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 110.768166] dwmac-sun8i 5030000.ethernet end0: PHY [stmmac-0:00] driver [Allwinner AC200 EPHY] (irq=POLL) [ 110.768209] dwmac-sun8i 5030000.ethernet end0: No Safety Features support found [ 110.768219] dwmac-sun8i 5030000.ethernet end0: No MAC Management Counters available [ 110.768228] dwmac-sun8i 5030000.ethernet end0: PTP not supported by HW [ 110.768647] dwmac-sun8i 5030000.ethernet end0: configuring for phy/rmii link mode [ 112.806629] dwmac-sun8i 5030000.ethernet end0: Link is Up - 100Mbps/Full - flow control off
@Nick A I've played with my box - it seems like trouble was actually in .dtb file. armbian has .dtb named sun50i-h618-transpeed-8k618-t.dtb - but it's for different box revision, or even just wrong .dtb when I rolled back to right .dtb with fresh edge kernel file network starts to work OK. also, on your image I've got network interface flapping once per some seconds; on 6.15.4 all is OK.
I was successful in compiling mpv-0.3.9 + the 2 patches from PR14690. I downloaded the release mpv as a tar.gz, expanded it, and applied the 2 patches. One hunk failed but it wasnt needed A 720p h264 video played with 10% CPU: (note that the options are --hwdec=v4l2request --drm-drmprime-video-plane=primary --drm-draw-plane=overlay -v Next, I tried with a 1080p h264... in this case, I needed the extraargs=cma=256M line in armbianEnv.txt. Result, low CPU usage, but dropped frames (choppy video) I didn't need to install mpv, because I ran it from within the build directory Removing the --drm-drmprime-video-plane=primary --drm-draw-plane=overlay from the options didn't make any positive or negative difference I repeated the test with mpv-0.4.0 and the result was the same. I am using linux 6.15.4... tomorrow I will re-test with linux 6.16.8 and again with labwc (wayland) UPDATE: with labwc-0.8.3-1 (from Trixie repo), 720p playback is fine, and 1080p playback drops 220 frames over 10 seconds. However it seems that it activates an X11 renderer, and XWayland appears in the htop list. <-- only if started from SSH session, with "DISPLAY=:0" How can I ensure that pure wayland is used? <-- answer: start mpv from within a terminal in labwc, like foot mpv log: When I try mpv-0.3.9 (from the source folder, so I dont need to install it), I get the same result: v4l2request works perfectly in 720p, but choppy in 1080p
@emor acid can you post your full dmesg.
I experienced the same you did, but with an M2 (and some custom build kernel). The "quick" solutions: - switch to one of the main windowmanagers, say Gnome or Plasma (perhaps the Gnome or QT-tools works better, "not-tested!") - switch to Wayland (while the window-setup-tool did not work in lxqt/x11 it worked from the start with lxqt/wayland) The third option would be to re-implement the windows-setup-tools to fit your hardware, but I guess that won't be quick. The problem as I see it: X11 is getting on in years and while tools exist to solve the problem, the support is lacking. Especially when running a minimal X11-windowmanager with a "non-standard GPU", the accompanying tools are getting more and more obsolete. Mali support is "recent" (here I count both G52 Panfrost from 2020 and G610 Panthor support from 2023). From Panfrost on the drivers seem to have been developed with Wayland in mind, X11 being included only for compatibility. You might find X11 to be still more stable right now, for performance and functionality Wayland is a already step forward. I expect X11 to fall behind more and more on stability as well. For the RK3588 I found redshift and dual screen failing to work as intended. Redshift does nothing where it should change colors. I could not switch dual screens from mirroring to extended screens in X11, while with Wayland it works from the start with an extended screen. That leaves 2 options: the display-setting-tools are lacking or the implementation is of mesa/panthor/X11 is incomplete. So the question is what do you think the way to go for the user interface is: Wayland or X11? PS As for the M2 with dualscreen over DP1.2-altmode: support is there for 6.17 and a lot of patches. If you wait for 6.18 most important patches should be mainlined (the DTS-patches being the exception). At least, I think I'll skip 6.17 in favour of 6.18-rc1.
Thanks. I build kernel yesterday. Quite long building process. It's simple with your steps but only what worry me is a size of kernel image as I got 1.3GB kernel file at the end as I assume that kernel is build with all available options selected (but this is only my assumption). Is there any kernel config from current kernel which I could use to build new kernel to make it smaller ?
