  2. Well, with `meson-g12-pwm-gpiox-5-fan` something works, but very strangely. The fan turns on at 100% when I start the load and runs until the CPU temperature drops below 46°C. Then it stops working, there is no smooth fan speed control in between.
  3. an orangepi5-plus compilation succeeded just fine now, so this error is not deterministic
  5. split off the issue from the original into a separate thread Essentially the problem here is that one of the mirrors is apparently redirecting from https to http. This has been a problem in the past and was supposedly fixed, in fact more than once. Obviously, it's never been fixed properly for all cases or there was a regression.
  6. Brave browser supports arm64 and has a "New private window with Tor" option. Might be worth checking out.
  7. There is only amd64 download as far as I can see. Yes, browser compilation takes crazy amounts of memory and computing time.
  8. You fail to mention which OS and which release you are running. https://packages.ubuntu.com/noble-updates/torbrowser-launcher is not working for you? Frankly, I don't find 5 and a half hours of compilation time unbearable, but you could also look into using a Launchpad PPA to offload the compilation effort.
  9. I could not find any arm64/aarch64 MODERN, up to date, Tor browser binaries. Anything below current-stable would be considered insecure, and at a glance I couldn't find them anywhere. So I was able to compile Nightly for the latest updates as well It took 331 minutes, and failed 4 times along the way with 8GB RAM native on the device and 4GB ZFS to start. It did a SIGKILL9 on firefox-glean. Increased to 8gb, still failed until I increased ZFS to 16gb, and then even at a whopping 16gb it crashed next on GkRust for OOM/SIGKILL9 as well until increased ZFS to 32GB! 331 minutes later, it was succesful Just wondering, to save myself from future punishment, was there some easier source for this app? Thank you
  10. what filesystem your drive using? usually if its WIndows Filesystem, that's where you get some performance penalty and NTFS is the one being the worst of all. Last time I tried using a ext4 formatted usb3 flash drive and was able to read/write to drive at 11MB/sec over wired LAN, no tweaks on samba server were done other than setting up some shares.
  11. Yesterday
  12. fussing about duplicate post, yes, same problem, different but identical machine. I have several of these bpi-m5's in service here, And its happened several times while I have reached the age of 90 where short term memory is only weeks. This then. with your link to systemd stuff, is bad code you inherited, blindly. My solution to that was/is to make hostname immutable after editing it. Much simpler than reading thru half a gigabyte of purposely opaque docs looking for clues. With the advent of led backlighting for monitor screens, CRT screens no longer get burnt in. So one thing badly needed is a bright red, much bigger mouse pointer that moves at about 1/10 th of its present speed, and an easy way to totally disable screen and mouse blanking. On a 3d printer, they are both a hindrance, adding 10 to 30 seconds to taking action when a printer malfunctions. And because I use this OS heavily, I also donate a smallish bit of my SS income to your cause on a monthly basis. Thank you Igor.
  13. @Igor Thanks. The weird noise is resolved. It was HDMI cable.
  14. Have you tried the meson-g12-pwm-gpiox-5-fan overlay?
  15. Hi everyone, I'm trying to control an 5v PWM Fan using hardware PWM pins of Banana Pi M5. I'm not able to output any pwm signal on any pin. It looks like there is an pwm controller visible at `/proc/device-tree/soc/bus@ffd00000/pwm@19000`. File `/proc/device-tree/soc/bus@ffd00000/pwm@19000/status` has content `okay` and file `/proc/device-tree/soc/bus@ffd00000/pwm@19000/pinctrl-0` has content `&`. When i run script: echo 0 | tee /sys/class/pwm/pwmchip0/export echo 40000 | tee /sys/class/pwm/pwmchip0/pwm0/period echo 20000 | tee /sys/class/pwm/pwmchip0/pwm0/duty_cycle echo 1 | tee /sys/class/pwm/pwmchip0/pwm0/enable echo 1 | tee /sys/class/pwm/pwmchip1/export echo 40000 | tee /sys/class/pwm/pwmchip1/pwm1/period echo 20000 | tee /sys/class/pwm/pwmchip1/pwm1/duty_cycle echo 1 | tee /sys/class/pwm/pwmchip1/pwm1/enable (only those 2 pins of PWMs are free, script runs without any errors) i cannot detect any pwm signals on any of 40-pin connector. Additionally after that : #: cat /sys/kernel/debug/pinctrl/*/pinmux-pins | grep pwm pin 81 (GPIOX_16): ffd19000.pwm (GPIO UNCLAIMED) function pwm_e group pwm_e pin 13 (GPIOE_1): ff802000.pwm (GPIO UNCLAIMED) function pwm_ao_d group pwm_ao_d_e #: cat /sys/kernel/debug/pwm 0: platform/ff802000.pwm, 2 PWM devices pwm-0 (sysfs ): requested enabled period: 100000 ns duty: 50000 ns polarity: normal pwm-1 (regulator-vddcpu ): requested enabled period: 1250 ns duty: 100 ns polarity: normal 1: platform/ffd19000.pwm, 2 PWM devices pwm-0 (wifi32k ): requested period: 30518 ns duty: 15259 ns polarity: normal pwm-1 (sysfs ): requested enabled period: 100000 ns duty: 50000 ns polarity: normal So looks like pwm signals are not routed to IO pins. I tried to add overlay : /dts-v1/; /plugin/; / { compatible = "bananapi,m5", "amlogic,meson-sm1"; fragment@0 { target-path = <&pwm_ef>; _overlay__ { status = "okay"; pinctrl-0 = <&pwm_e_pins>; pinctrl-names = "default"; }; }; fragment@1 { target-path = "/"; __overlay__ { pwm_e_pins: pwm_e_pins { compatible = "pwm-gpio"; pinctrl-names = "default"; pinctrl-0 = <&pwm_e>; }; }; }; }; which i compiled with dtc and added to `/boot/overlay-user`, after that i added a line user_overlays=meson-m5-custom-pwm to `/boot/armbianEnv.txt` But it didn't worked. I'm not surprised because it was generated by AI, and i don't now anything about overlays. Is there anybody that can help me with writing this overlay ? Or maybe there is simpler solution ?
  16. 🧟‍♂️🌙☕🛌 Since introducing of systemd (by default in most Linux assemblies in past 10-15 years), its the systemd way: https://www.freedesktop.org/software/systemd/man/latest/hostnamectl.html This way is also handled if armbian-config is used. Also for other things, consider looking into systemd* how-to. Netplan - i understand you might dislike it - is just a wrapper - for systemd-networkd or Network Manager.
  17. Aliexpress randomly assembled electronics is expected to fail - you need to lower expectations, count on luck, read forum for clues, DIY. Little better are single board computers, then what is declared as supported, best what is platinum supported (for this use case FriendlyElec R3S would be perfect) following by Raspbbery Pi and x86 hardware. If you are looking for top first time experience buying a server, you should stick to https://www.supermicro.com/en/ I can assure you that Armbian works perfectly on any of servers they sell. But yes, price does not match.
  18. up all night, finally got it working. list of stuff I did: download latest 2505 bookworm-xfce and reburn the u-us card 3 times. copied 40 entry /etc/hosts file from working machine. edit /etc/hostname to change it to unique name amanda, then make it immutable as that did not survive a reboot. rm 10-* in etc/netplan, rename armbian.yaml to 10-armbian.yam editing it as needed, and edit /etc/nsswitch.conf to make network setup start as "hostname files dns" rebooting after each stage. So hostname now stays at amanda, and nsswitch.conf works as ordered. I can ping yahoo.com in addition to my other local machines and have now updated 208 pkgs. rebooted looks ok. Now I can get back to making a 20T lvm out of 5 4T SSD's, But first some breakfast and a shot of insulin, and a nap while the local weather settles, its poured piss out of a cowbarn boot most of the night. Thank you for the links, they were educational.
  19. I can confirm: https://paste.armbian.de/oxupahozud
  20. Not sure if the target board makes a difference. But FWIW, my compilations for rockpi-4b and orangepi5-plus exhibited the issue while the one for bananapim2plus did not.
  21. @Mike H This is a community forum, and your message is for everyone. Armbian maintainers are part of this community, but please keep in mind that support here is provided on a best‑effort basis by volunteers and maintainers who give their time when they can. In open‑source projects, especially those maintained by communities, work is prioritized based on available time, skills, and resources. Sometimes an issue might be addressed quickly; other times it may take months — or it may not be addressed at all if the effort required is too great compared to the benefit. This is a normal reality in community‑driven software development. The concept of sunk cost often plays a role in deciding whether to invest effort in fixing certain issues. It’s worth noting that even in large, well‑funded projects, some bugs remain unresolved for years. In our case, resources are far more limited — for example, Raspberry Pi OS has a budget exceeding €1M annually for one platform, while Armbian supports many platforms with a fraction of that funding, outside few boards we have some small maintaining budget, there is only a beer money, and far fewer people. Best-effort is the only promise that can be provided under such circumstances. We appreciate bug reports, even they have nothing to do with our work as we understand users often can't judge that, but we ask that no pressure be placed on contributors to resolve them on demand. In some cases, solving an issue can take weeks or even months of work, which is not something users can reasonably expect from volunteers. And there are thousands of bugs already in the to do list. Finally, please understand that part of the challenge we face is that some projects already monetize or re‑brand our work while presenting it as inexpensive and easy to maintain — when in reality, it’s not. This can create misunderstandings about the real cost and effort behind keeping a complex software stack running. Your report is welcome, but we ask for patience, understanding, and respect for the time and resources of those trying to help. Pressuring volunteers to prioritize some issue, or expecting them to personally fund the work, is neither reasonable nor effective way to fix bugs.
  22. armbian-config way is limited in its use - it's intended for quick start when networking is simple. When you need something more complex, its always the manual way: https://docs.armbian.com/User-Guide_Networking/ If you wanna look how Armbian deals with networking in the backstage: https://github.com/armbian/build/tree/main/extensions/network In case of desktop images (original, not self constructed), XFCE will have Network manager.
  23. You are already discussing this elsewhere. Please don't post several times about the same issue.
  24. netplan is a joke. It looks like it might work IF ipv6 was totally disabled. everything I've entered has been applied to /dev/br0. but shown while entering it as end0 This is totally broken. Can I still put this crap in /etc/networking/interfaces.d? Help please.
  25. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  26. Pointing out that you are not even willing to put your own words into a search engine is "condescending"? That takes 5 seconds or less when you claim to have put months and months into it. You are expecting others to do the work for you. I find that quite presumptuous. And no, we do not know there is a bug in Armbian. You haven't done enough research to know enough to claim this for certain. I will put the chances of that being the case at fity-fifty at best. You also have presented no logs whatsoever (even after being asked) to even give others the moderate chance to do this work for you (for free). If you came here to vent, OK, you have now vented. If you came here for a solution, then sorry to say, but you are not even doing the very minimum to get that done.
  27. Network setup in the latest bookworm+xfce's armbian config won't allow a network setup I've been using for 25 years. Its an all ipv4 static setup using hosts files. It apparetly asumes only valid ipv6 addresses but the nearest ipv6 enabled ISP is over 100 miles away from me in north central West Virginia USA.The idea is it will query the router for any name not found in the /etc/hosts file. Thhe switch trigger being a hardcopy /etc/resolv.conf. This is normally and instantly accomplished as dd-wrt caches previously looked up addresses. And if not found in dd-wrt's cache it relays the request to my ISP's dns server. BUT BUT BUT armbian-config refuses to accept valid ipv4 addresses by hashing them to apparently random errors, digits duplicated or left out When looking at the results no dhcp4 or 6 of is enabled as expected. So how do I fix this first boot problem? This is all on a banannapi-m5 I intend to make an amanda-3.5.4 based nas out of. Thanks for any help. The solved x tag is a lie as it won't post w/o it.
