iptables module missing from 6.18.10-current-meson64 kernel
bedna replied to Jeedom Cassivet's topic in Beginners
Also: # apt install -y iptables # iptables -v iptables v1.8.11 (nftables): no command specified https://wiki.debian.org/nftables AFAIK using iptables syntax should still work, but nft is what you probably should learn to use instead. https://wiki.nftables.org/wiki-nftables/index.php/Moving_from_iptables_to_nftables - Today
Add to /etc/rc.local and reboot. echo "1" > /sys/devices/system/cpu/cpufreq/boost && echo "performance" | tee /sys/devices/system/cpu/cpu[0-9]/cpufreq/scaling_governor &&
@Werner I understand, will wait for "Resolve" before marking this as Solution. Thank you for quick reply.
The max clock is most likely limited via opp table in the dts. H6 should clock up to 1.8ghz, yes, but there might be a reason why this board does not.
Hi, this might be prohibited until you made a few manually approved posting to be moved from Validating to Members group. This measure is necessary to keep the forum clean from spamers who try to spread their bs here on daily basis. So I suggest to stick around for a while, this should resolve itself.
I tried installing armbian on tx6 because I saw a .img file for the tanix tx6 to turn it as a Minecraft server but I quickly run into problems
This week in Armbian development saw significant enhancements across multiple areas, including expanded board support and improved hardware compatibility. Notable additions include new images and configurations for Qidi X-6, X-7, and Ariaboard Photonicat2 mainboards, as well as refined kernel patch maintenance and updates for various platforms. The build system received important fixes, such as resolving compilation errors and device tree issues, alongside improvements in Docker utilities and offline mode detection. Several refactoring efforts streamlined backend processes and enhanced user interface elements. The team also introduced automatic fallback mechanisms for Hetzner server types, optimizing runner scaling. Overall, these updates reinforce Armbian's commitment to stability, broader hardware support, and a smoother user experience. ChangesAdd automatic fallback to smaller Hetzner server types with runner count scaling. by @igorpecovnik in armbian/actions#15Add board and board vendror image for Ariaboard Photonicat2. by @HackingGate in armbian/armbian.github.io#255Add image for Qidi X-7 Mainboard. by @Shadowrom2020 in armbian/armbian.github.io#257Add some board image. by @retro98boy in armbian/armbian.github.io#258Add support for dialog via new wrapper functions. by @igorpecovnik in armbian/configng#762Add support for qidi x-* boards. by @Shadowrom2020 in armbian/build#9564Change unit tests badge link in documentation. by @igorpecovnik in armbian/documentation#885Drop patches that landed upstream and fix two. by @igorpecovnik in armbian/build#9544edge: bump 7.0 to rc5. by @EvilOlaf in armbian/build#9580Enable BCACHE on Raspberry Pi build. by @aulanov in armbian/build#9550feat: offline mode detection with local asset cache. by @SuperKali in armbian/imager#117feat: settings refactoring, DiskArbitration device detection, and filename parser improvements. by @SuperKali in armbian/imager#114fix race condition and NULL ptr deref in PCIe threaded probe. by @AlomeProg in armbian/linux-rockchip#458fix(docker): add trixie support for upstream docker-ce to fix HomeAssistant installation. by @igorpecovnik in armbian/configng#765fix: correct dialog argument order causing box option errors. by @igorpecovnik in armbian/configng#768fix: resolve Phytium stmmac compilation errors for kernel 6.19. by @igorpecovnik in armbian/build#9545fix: settings modal reset, custom image manufacturer, and board detection setting. by @SuperKali in armbian/imager#116Image for Qidi X-6 Mainboard. by @Shadowrom2020 in armbian/armbian.github.io#256kernel patch maintenance. by @EvilOlaf in armbian/build#9562meson64-6.18: rewrite kernel config. by @EvilOlaf in armbian/build#9581mksklipad50: fix devicetree opp voltage settings. by @torte71 in armbian/build#9569OrangePi-RV2/R2S: rename board config from wip to csc. by @sven-ola in armbian/build#9560Qidi X-6: fix defconfig patch. by @Shadowrom2020 in armbian/build#9567refactor: add comprehensive Docker wrapper utilities with progress display. by @igorpecovnik in armbian/configng#769refactor: deduplicate hooks, add CSS design tokens, clean up backend. by @SuperKali in armbian/imager#115rockchip64-7.0: mekotronics-r58x-pro: analog sound: use SuperKali's new clock. by @rpardini in armbian/build#9554rockchip64: rk3588: add I2S MCLK output gate clocks for audio codec support. by @SuperKali in armbian/build#9548rockchip64: rk3588: update I2S MCLK gate patches to match upstream v3 and add u-boot clock IDs. by @SuperKali in armbian/build#9568sm8250: Fix application of Retroid Pocket 5/mini device trees. by @kay-lambdadelta in armbian/build#9572SpacemiT: Update ATFSOURCE, BOOTSOURCE and SD card support.. by @pyavitz in armbian/build#9552sunxi-6.18: remove stray commit from patch. by @EvilOlaf in armbian/build#9556sunxi: bump edge to 6.19.y, current to 6.18.y and legacy to 6.12.y. by @EvilOlaf in armbian/build#9381Update odroidxu4-current to 6.6.129. by @belegdol in armbian/build#9558Update VERSION. by @EvilOlaf in armbian/build#9553View the full article
Hi guys? are there any cli/minimal Armbian (triexie) images with current kernel for Opi RV2?
Hello, can you please say, where i can find: Armbian_community_25.11.0-trunk.413_Aml-s9xx-box_plucky_edge_6.18.0-rc3.img thank you.
SuzSinclair replied to jock's topic in Rockchip CPU Boxes
Subject: X88MAX RK3328 - Cannot boot from SD/USB, need help installing Armbian Hello Armbian Community, I'm trying to install Armbian on my X88 RK3328 TV box but facing multiple issues. Need your expert help! Device Information: Model: X88MAX.p2.0.01.d4 SoC: Rockchip RK3328 Android Version: Android 9 (SDK 28) Board: Blue PCB (Hugsun design similar to T9) Storage: 4GB RAM + eMMC Buttons: Power button only (no visible reset button) What I've Tried: 1. SD Card Boot: Downloaded: Armbian_community_26.2.0-trunk.606_Rk3318-box_trixie_current_6.18.18_minimal.img.xz Downloaded: multitool_rk3318-3328.img Flashed to Netac SD card using BalenaEtcher (verified) SD card is detected in Android environment Problem: Box always boots Android, ignores SD card completely 2. USB Boot: Flashed Multitool to USB flash drive Problem: Same result - boots Android, ignores USB 3. Reset Button Method: Tried holding reset button (inside AV port) while powering on Problem: No change, still boots Android 4. Rooting Attempts: Tried KingRoot - stuck on "checking state" forever Device confirmed NOT ROOTED (Root Checker app) Problem: Cannot root to install from Android 5. Maskrom Mode: Have AndroidTool v2.38 ready Problem: PC shows "No Devices Found" when trying to enter Maskrom Current Status: ✅ SD card slot works (Android detects it) ✅ Multitool files accessible on SD card ✅ Have all necessary images downloaded ❌ Cannot boot from SD or USB ❌ Cannot root Android ❌ Cannot enter Maskrom mode My Goal: Install pure Armbian (not Android + Linux apps) for better performance and native Linux experience. Questions: Does anyone have X88 RK3328 working with Armbian? If yes, what method did you use? Is there a specific Armbian build for X88 boards? The generic Rk3318-box image doesn't boot. How to enter Maskrom mode on X88? PC shows "No Devices Found" - am I missing something? Can I convert Armbian .img to Rockchip firmware format for USB Burning Tool? Any X88-specific instructions or device tree files I should use? What I Have Ready: ✅ Armbian image (Rk3318-box minimal) ✅ Multitool image ✅ AndroidTool v2.38 ✅ USB-A to USB-A cable ✅ Willing to backup original Android first Any help or X88-specific guidance would be greatly appreciated! Thanks in advance! 🙏 Device: X88MAX.p2.0.01.d4 SoC: RK3328 (Chip Tag: 33 32 32 48, Flag: RK322H) Storage: Samsung eMMC 64GB FlashID: 45 4D 4D 43 20 Status: Successfully in LOADER mode via RKDevTool v2.86 Android: Backed up and ready Problem: - SD/USB boot ignored by bootloader - Android not rootable (KingRoot fails) - Need Armbian in Rockchip firmware format What I Have: - Device in LOADER mode ✓ - Full Android backup ✓ - RKDevTool v2.86 working ✓ - Armbian_community_26.2.0-trunk.606_Rk3318-box_trixie_current_6.18.18_minimal.img.xz What I Need: - parameter.txt for X88 RK3328 - Armbian partitions in Rockchip format - Or .update file for X88 Tag: @jock Anyone successfully flashed Armbian on X88 RK3328? -
In the Welcome message it suggested I change the avatar to personalize my Profile. I cannot find a way to do that in this Forum. I have one in mind:
eselarm replied to Jeedom Cassivet's topic in Beginners
Why you do this (on a normal modern Trixie kernel, actually even 1 year newer)? This is what I have (runs rockchip64 7.0-rc3 kernel): root@ranc:~# ls -al /sbin/iptables /etc/alternatives/iptables lrwxrwxrwx 1 root root 22 Nov 1 2023 /etc/alternatives/iptables -> /usr/sbin/iptables-nft lrwxrwxrwx 1 root root 26 Jan 16 2023 /sbin/iptables -> /etc/alternatives/iptables On other Aarch64 computer, it dates back to 2019 already, that is a standard Debian installation, always in-place upgraded since Buster or so. The Linux kernel does things natively as NetFilter, the iptables commands are mapped. Legacy is even older and I guess the old kernel API has been removed. But do research yourself if you want to know, at least 'man iptables-legacy' -
After the update/upgrade, all CPUs are now installed nproc 4 This didn't fix my Bluetooth (maybe it's some individual bug in my system?) but since Bluetooth works correctly in the new images for OrangePi 3 LTS, I'm marking this thread as resolved... I'll probably install the latest image soon, although it will be time-consuming. ........................... orangepi3-lts:~# dmesg | grep "CPU" [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.005157] smp: Bringing up secondary CPUs ... [ 0.007070] Detected VIPT I-cache on CPU1 [ 0.007260] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.009368] Detected VIPT I-cache on CPU2 [ 0.009541] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.011117] Detected VIPT I-cache on CPU3 [ 0.011261] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.011373] smp: Brought up 1 node, 4 CPUs [ 0.011398] CPU: All CPU(s) started at EL2 [ 0.011443] CPU features: detected: 32-bit EL0 Support [ 0.011449] CPU features: detected: 32-bit EL1 Support [ 0.011458] CPU features: detected: CRC32 instructions [ 0.011470] CPU features: detected: PMUv3 [ 0.260754] ledtrig-cpu: registered to indicate activity on CPUs [ 0.414642] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 0.457342] WARNING: CPU: 3 PID: 71 at drivers/iommu/iommu.c:612 __iommu_probe_device+0x1a8/0x4a0 [ 0.457375] CPU: 3 UID: 0 PID: 71 Comm: kworker/u16:4 Not tainted 6.18.19-current-sunxi64 #2 PREEMPT Ps. I don't know if I announced the CPU solution too early? Maybe there's a problem with the processor clock speed? .............. cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# cpu Temperature: 40 °C CPU-0 Frequency: 1608 Mhz CPU-1 Frequency: 1608 Mhz CPU-2 Frequency: 1608 Mhz CPU-3 Frequency: 1608 Mhz root@orangepi3-lts:~# cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# root@orangepi3-lts:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq 1608000 root@orangepi3-lts:~# cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor performance performance performance performance ............... shouldn't it be : 1810000 ... ?
Anyone got the dedicated Fan header working correctly? It won't spin at all. Enabled the fanctrl overlay. changed pwm rate,the fan won't budge.. Tried stress the CPU but this only cause shutdown
PanVK’s new framebuffer abstraction for Mali GPUs removes OpenGL-specific constraints, unlocking more flexible tiled rendering features in Vulkan. View the full article
Hi, i have amlogic s805 tv box from mxq, how do i run armbian onecloud? bc none of this helped me.
Jeedom Cassivet replied to Jeedom Cassivet's topic in Beginners
Hi, Here what I do 1°) Flash the minimal - IOT image (trixie) for Odroid N2+ on my EMMc 2°) setup Root password and user 3°) Set up locale 4°) use armbian-config to switch on kernel 6.19.0 5°) Reboot - After Reboot I can see this : v26.2.1 for Odroid N2 running Armbian Linux 6.19.0-edge-meson64 6°) use armbian-config to add linux header 7°) reboot 8°) use these commands: # grep -r "iptables" /lib/modules/. grep: /lib/modules/./6.19.0-edge-meson64/kernel/net/ipv4/netfilter/ipt_rpfilter.ko : fichiers binaires correspondent grep: /lib/modules/./6.19.0-edge-meson64/kernel/net/bridge/br_netfilter.ko : fichiers binaires correspondent # grep -r "ip_tables" /lib/modules/. -- nothing # find /lib/modules/ -name ip* lot of filkes but no ip_tables.ko 9°) use armbian-upgrade 10°) reboot 11°) retry commands grep et find: same result 12°) Try to launch # iptables -L command not found 13°) Install iptables # apt install -y iptables # iptables -v iptables v1.8.11 (nftables): no command specified # iptables -L Chain INPUT (policy ACCEPT) target prot opt source destination Chain FORWARD (policy ACCEPT) target prot opt source destination Chain OUTPUT (policy ACCEPT) target prot opt source destination # update-alternatives --set iptables /usr/sbin/iptables-legacy update-alternatives: utilisation de « /usr/sbin/iptables-legacy » pour fournir « /usr/sbin/iptables » (iptables) en mode manuel # update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy update-alternatives: utilisation de « /usr/sbin/ip6tables-legacy » pour fournir « /usr/sbin/ip6tables » (ip6tables) en mode manuel # iptables -L modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.19.0-edge-meson64 iptables v1.8.11 (legacy): can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. 14°) Reboot 15°) Try # iptables -L modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.19.0-edge-meson64 iptables v1.8.11 (legacy): can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. Do I made something wrong ? Thanks -
ArmUser replied to Junkman's topic in NanoPi R4S
I installed the patch files with "Pb143" in the name on Friday, but unfortunately there was no improvement. Here are the logs: https://paste.armbian.com/dovedafali Can you tell me if I can test something with this? If so, what exactly do I need to do? -
Igor replied to Jeedom Cassivet's topic in Beginners
Did you perhaps upgrade kernel and forgot to reboot? -
Werner replied to Jeedom Cassivet's topic in Beginners
Module name is "ip_tables" -
Thanks for your answer. I very sorry to ask you one more things please. How can I check if module is present. In modules files in "/lib/modules/6.18.10-current-meson64" ? I tried to do this : # cd /lib/modules/6.18.10-current-meson64 # grep -r "iptables" . Answer grep: ./net/ipv4/netfilter/ipt_rpfilter.ko : fichiers binaires correspondent grep: ./net/bridge/br_netfilter.ko : fichiers binaires correspondent I not an expert PS : I'am on Minimal / IOT version. Maybe it's the reason ? Thanks -
https://github.com/armbian/build/blob/b8eab09ef561f2d03956098d26351d323a3b2d7b/config/kernel/linux-meson64-current.config#L355 Check your /lib/modules directory if it is present. It should be.
