@sven-ola https://lore.kernel.org/spacemit/20260310161853.3900605-1-gaohan@iscas.ac.cn/T/#t Sometime soon-ish I'll be doing another PR with early SD card and CPU freq scaling support. The above link should at least get you boot from eMMC or NVMe.
The question is: does the auto-generated version available for download with a legacy kernel include the hack to make the GPU work in Wayland, and if not, how should I compile it? Thanks
zm112008 replied to fensoft's topic in Rockchip CPU Boxes
when using your fork, it worked https://github.com/fensoft/rk3528-tvbox -
How to use OrangePi 5 Plus's NPU for Image Generation?
usual user replied to Johson's topic in Beginners
I am currently at 7.0.0-rc1. I can upload my jump-start image so you can check if my kernel build works with your device. If you like what you see, it is only a 'prepare-jump-start ${target-mount-point}' away to install the kernel package alongside your existing system. I know about it, but since it is just another not mainline solution with another dependency mess, I am not particularly interested. -
Good afternoon, I can't compile the cores for this TV box. https://paste.armbian.com/ziyasupeka -
I agree with you. Neural network works well on NPU. I tried to load tiny llm model, but it's still too large for NPU. The bottleneck is the sram in NPU, not computing capacity. And I found an interesting project https://github.com/NotPunchnox/rkllama
Which armhf version should I choose?
Humboldt replied to Humboldt's topic in Software, Applications, Userspace
Thanks for the replies. But I've decided on Linux Mainline on ARM Chromebooks (Veyron): https://github.com/velvet-os/imagebuilder/releases/tag/251115-02 which at least works from the SD card. I'm still working on the installation. 😉 -
Oh damn, wish I would have read this before I tried to install (26.2 with vendor kernel build on the 9th) from SD to Nvme... How can I reflash MTD if I only have a MacBook available? Note to self and the next one hitting that wall: Going to maskrom mode kinda fixed it, after that I started again from a mSD and from that running ArmBian I flashed the same img to the Nvme on the board. Another reboot and it was started from the SSD 😉
This week’s Armbian development saw a wide range of improvements and fixes across the project’s build framework, kernel support, and device compatibility. Notable changes include the transition from POSIX to Bash syntax for enhanced script reliability, expanded support for new hardware such as the Norco-EMB-3531 board, and the addition of Vulkan and improved 3D package descriptions. Several device-specific updates were made, including kernel enhancements for sm8250, mainline support for SpacemiT, and fixes for wireless and HDMI functionality on various boards. The team also introduced new features like a cache manager modal in the imager and improved marking for container-based software. Multiple bug fixes addressed issues with OS image duplication, patch timestamps, and device quirks. Security was bolstered with hardened GitHub Actions, ensuring a more robust development pipeline. Changes(#9400 P1a) Replace POSIX [ ] with bash [[ ]] across build framework. by @iav in armbian/build#9462Add manual execution and daily cron schedule for MOTD generation. by @igorpecovnik in armbian/armbian.github.io#249Add norco-emb-3531 board and norco vendor image. by @retro98boy in armbian/armbian.github.io#244add Vulkan support and expand 3D package descriptions. by @igorpecovnik in armbian/build#9494Added config improvements and fixes to ayn odin2. by @Squishy123 in armbian/build#9316bump 7.0 to rc2. by @EvilOlaf in armbian/build#9475dwc2: explicitly force host mode for USB_DR_MODE_HOST. by @igorpecovnik in armbian/build#9486feat: add cache manager modal with per-image management. by @SuperKali in armbian/imager#109feat: mark container-based software in menu and docs. by @igorpecovnik in armbian/configng#761fix(gitignore): ignore pycache at all depths (#7863). by @iav in armbian/build#9490fix(images): adapt module to new armbian-images.json structure. by @igorpecovnik in armbian/configng#756fix(manage_zsh): abort shell change if zsh package install fails. by @ajorpheus in armbian/configng#759fix: resolve OS image list duplication when switching filters. by @SuperKali in armbian/imager#110Fix: SakuraPi RK3308B WLAN broken. by @TheSnowfield in armbian/build#9478i915: fix Dell XPS 13 7390 device ID in quirk patches. by @igorpecovnik in armbian/build#9485Improve sm8250 6.19 edge kernel. by @retro98boy in armbian/build#9434meson64: bump edge to 7.0-rc1. by @EvilOlaf in armbian/build#9459meson: freeze current kernel at 6.12.28 and fix HDMI PHY frequency limit. by @igorpecovnik in armbian/build#9465nanopi-zero2: enable mainline kernel support and PCIe for M.2 WiFi. by @rubycomm in armbian/build#9453OrangePi 3B: Add device tree overlays for OrangePi 3B with I2C, PWM, SPI support. by @kskshaf in armbian/build#9460OrangePi-RV2: Fix wireless access point mode by using the correct FW. by @sven-ola in armbian/build#9504orangepi5: rewrite uboot patches against v2026.04-rc3. by @EvilOlaf in armbian/build#9457patching: fix #9028 timestamp when multiple patches touch same file. by @iav in armbian/build#9489pkg_install/pkg_remove: properly propagate apt-get exit codes. by @igorpecovnik in armbian/configng#760Removed un-needed patch for SM8550-6.18; patch has already been updat…. by @Squishy123 in armbian/build#9487rk3568: add 51.2MHz PLL rate for HDMI. by @skorobkov in armbian/build#9477rock-5b-plus: add current kernel to build targets. by @igorpecovnik in armbian/build#9464rock-5t: add current kernel to build targets. by @igorpecovnik in armbian/build#9463Rockchip64 fix patches due to upstream changes in 6.19.6 and 6.18.16. by @EvilOlaf in armbian/build#9483rockchip: Disable specific patches in 6.19 series. by @igorpecovnik in armbian/build#9493rockchip: Enable Wireguard/TUN module in vendor kernel. by @vidplace7 in armbian/build#9492Spacemit legacy loadpatch. by @sven-ola in armbian/build#9496SpacemiT: Add linux-7.0.y "mainline" support. by @pyavitz in armbian/build#9458spacemit: remove old and unused patch set. by @sven-ola in armbian/build#9497unset QEMU_CPU for aml_image_packer. by @QwaSeeK in armbian/build#9417Update odroidxu4-current to 6.6.128. by @belegdol in armbian/build#9491[StepSecurity] ci: Harden GitHub Actions. by @step-security-bot in armbian/build#9356View the full article
Hi all, I kinda set myself in a corner: Last year in October I installed the UEFI image in SPI on my OrangePi5 Plus, then I installed the uefi armbian image on the Nvme ssd. I did all of that after a system failure during my 3 month absence from where I've got that OPi5 setup. As I couldn't get it back to work I went and tried with the Uefi Image... But it seems that this was a major mistake: I could never get my frigate container back to running as there's no NPU's detected! Just now I took the leap of faith and reinstalled uboot into the SPI and flashed a freshly loaded "Armbian_25.11.1_Orangepi5-plus_trixie_current_6.12.58_minimal.img.xz"... And still there's no NPU: I can't see a thing about a NPU: mircsicz@orangepi5-plus:~$ sudo dmesg|grep rocket mircsicz@orangepi5-plus:~$ sudo dmesg|grep NPU mircsicz@orangepi5-plus:~$ sudo dmesg|grep GPU mircsicz@orangepi5-plus:~$ sudo dmesg|grep gpu [ 6.133753] panthor fb000000.gpu: [drm] clock rate = 198000000 [ 6.136216] panthor fb000000.gpu: [drm] Mali-G610 id 0xa867 major 0x0 minor 0x0 status 0x5 [ 6.136222] panthor fb000000.gpu: [drm] Features: L2:0x7120306 Tiler:0x809 Mem:0x301 MMU:0x2830 AS:0xff [ 6.136226] panthor fb000000.gpu: [drm] shader_present=0x50005 l2_present=0x1 tiler_present=0x1 [ 6.160653] panthor fb000000.gpu: [drm] Firmware protected mode entry not be supported, ignoring [ 6.160711] panthor fb000000.gpu: [drm] Firmware git sha: 814b47b551159067b67a37c4e9adda458ad9d852 [ 6.160868] panthor fb000000.gpu: [drm] CSF FW using interface v1.1.0, Features 0x0 Instrumentation features 0x71 [ 6.161137] [drm] Initialized panthor 1.5.0 for fb000000.gpu on minor 1 mircsicz@orangepi5-plus:~$ uname -a Linux orangepi5-plus 6.18.0-rc6-edge-rockchip64 #1 SMP PREEMPT Sun Nov 16 22:25:38 UTC 2025 aarch64 GNU/Linux Nor with the npu-probe.sh script: # Auto-generated NPU detection record # Generated at: Mon Mar 9 07:32:45 PM EST 2026 [platform] comatible="xunlong,orangepi-5-plus,rockchip,rk3588," model="Xunlong Orange Pi 5 Plus," family="unknown" soc_id="unknown" arch="aarch64" kernel="6.18.0-rc6-edge-rockchip64" [modules] rknpu="" rocket="" [devices] no_detected_npu=1 devices_not_support=[ "/dev/dri/renderD128", # Driver: panthor ] [libraries] no_delegate=1 vendor_libs=[] So I came here hoping one of you guys will be able to gi'me a hint... After flashing a recent dev build of v26.2 with vendor Kernel to another SD I finally can see the NPU again: # Auto-generated NPU detection record # Generated at: Mon Mar 9 08:20:56 PM EST 2026 [platform] comatible="rockchip,rk3588-orangepi-5-plus,rockchip,rk3588," model="Orange Pi 5 Plus," family="unknown" soc_id="unknown" arch="aarch64" kernel="6.1.115-vendor-rk35xx" [modules] rknpu="/sys/module/rknpu" rocket="" [devices] npu_device="/dev/dri/renderD129" # Driver: RKNPU devices_not_support=[ "/dev/dri/renderD128", # Driver: rockchip-drm ] [libraries] no_delegate=1 vendor_libs=[] Also added my entry to the Github mentioned above 😉 So now I need to ask @usual user what specific kernel are you running? It seems to me that with the kernels available on the repo's only 6.1.115 allows me to use the NPU...
Update — Working fix available I've got eMMC detection working on my Radxa Zero 3W with Armbian Trixie (vendor kernel 6.1.115, SD card boot). The fix uses a device tree overlay to inject the missing voltage regulators, pinctrl references, and eMMC capabilities into the base DTB, combined with a small systemd service that rebinds the SDHCI driver to work around a deferred probe timing issue. After applying, the eMMC is detected as expected: mmc0: new HS200 MMC card at address 0001 mmcblk0: mmc0:0001 8GTF4R 7.28 GiB armbian-install works normally after that to migrate to eMMC boot. The rebind service is conditionally skipped when booting from eMMC so it doesn't interfere. I've attached a zip with all the files. The README.md inside has the full details — root cause analysis, what was tried and failed (including full DTB recompile), how the fix works, installation/verification/revert steps, and known limitations (the pinctrl phandle values are specific to this kernel build). I still working on a version that does not need the rebind service for sd cards. but for now you need the rebind on the sd card to get it to find the EMMC so you can install. emmc-fix.zip
Update — eMMC now detected (workaround found) After significant debugging, I have identified and worked around the issue. Here's what I found: What the shipped DTB is missing for the eMMC controller (/mmc@fe310000): vmmc-supply / vqmmc-supply — voltage regulator references pinctrl-0 / pinctrl-names — pin muxing for the 8-bit eMMC data bus, clock, command, and data strobe lines cap-mmc-highspeed, mmc-hs200-1_8v, no-sd, no-sdio — eMMC capability flags Interestingly, the PMU IO domains (syscon@fdc20000/io-domains) are already correctly configured with vccio2 = 1.8V, and the pinctrl groups (emmc-bus8, emmc-clk, emmc-cmd, emmc-datastrobe) exist under /pinctrl/emmc/. The board-level wiring is all there in the DTB — it's just not connected to the eMMC controller node. Root cause: The Armbian Trixie vendor kernel (6.1.115) ships only rk3566-radxa-zero3.dtb (generic Zero 3), not the 3W-specific rk3566-radxa-zero-3w.dtb that the upstream Linux kernel has. The upstream DTS includes all of the above for the 3W model. Additional finding — deferred probe timing issue: Even after patching all missing properties via a device tree overlay, the eMMC still doesn't appear on first boot. The SDHCI driver (sdhci-dwcmshc) probes before the overlay's regulators are registered, receives dummy regulators instead of deferring, and initializes the controller without real power. A manual unbind/rebind of the driver after boot causes immediate detection: mmc0: new HS200 MMC card at address 0001 mmcblk0: mmc0:0001 8GTF4R 7.28 GiB I have a working fix (overlay + early-boot driver rebind) that I testing before publishing. The proper long-term solution would be for Armbian to ship the rk3566-radxa-zero-3w.dtb from the upstream kernel, or merge its board-level eMMC configuration into the existing rk3566-radxa-zero3.dtb.
Hi folks, I was looking to activate the NPU on my beagley-AI chip, running armbian, and I couldn't find how. This chip as a NPU (AM67A) on the SOC from TexasInstruments (https://api.pageplace.de/preview/DT0400.9783895766572_A50990365/preview-9783895766572_A50990365.pdf). The loading of the NPU seems to have failed: mesg | grep remoteproc [ 8.461511] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode [ 8.461728] remoteproc remoteproc0: 7e000000.dsp is available [ 8.461868] k3-dsp-rproc 7e000000.dsp: register pm nitifiers in remoteproc mode [ 8.464448] k3-dsp-rproc 7e200000.dsp: configured DSP for remoteproc mode [ 8.465124] remoteproc remoteproc0: Direct firmware load for j722s-c71_0-fw failed with error -2 [ 8.465164] remoteproc remoteproc0: powering up 7e000000.dsp [ 8.465271] remoteproc remoteproc0: Direct firmware load for j722s-c71_0-fw failed with error -2 [ 8.465285] remoteproc remoteproc0: request_firmware failed: -2 [ 8.480524] remoteproc remoteproc1: 7e200000.dsp is available [ 8.480658] k3-dsp-rproc 7e200000.dsp: register pm nitifiers in remoteproc mode [ 8.482329] remoteproc remoteproc1: Direct firmware load for j722s-c71_1-fw failed with error -2 [ 8.482375] remoteproc remoteproc1: powering up 7e200000.dsp [ 8.482488] remoteproc remoteproc1: Direct firmware load for j722s-c71_1-fw failed with error -2 [ 8.482501] remoteproc remoteproc1: request_firmware failed: -2 [ 8.964763] platform 79000000.r5f: configured R5F for remoteproc mode [ 9.047514] remoteproc remoteproc2: 79000000.r5f is available [ 9.048055] remoteproc remoteproc2: Direct firmware load for j722s-mcu-r5f0_0-fw failed with error -2 [ 9.048099] remoteproc remoteproc2: powering up 79000000.r5f [ 9.048222] remoteproc remoteproc2: Direct firmware load for j722s-mcu-r5f0_0-fw failed with error -2 [ 9.048241] remoteproc remoteproc2: request_firmware failed: -2 [ 9.234391] remoteproc remoteproc3: 78000000.r5f is available [ 9.234578] remoteproc remoteproc3: attaching to 78000000.r5f [ 9.402138] remoteproc remoteproc3: remote processor 78000000.r5f is now attached [ 9.505240] platform 78400000.r5f: configured R5F for remoteproc mode [ 9.547946] remoteproc remoteproc4: 78400000.r5f is available [ 9.548359] remoteproc remoteproc4: Direct firmware load for j722s-main-r5f0_0-fw failed with error -2 [ 9.548400] remoteproc remoteproc4: powering up 78400000.r5f [ 9.548505] remoteproc remoteproc4: Direct firmware load for j722s-main-r5f0_0-fw failed with error -2 [ 9.548521] remoteproc remoteproc4: request_firmware failed: -2 [ 15.281722] Modules linked in: algif_aead rpmsg_ctrl rpmsg_char cc33xx mac80211 libarc4 snd_soc_simple_card cc33xx_sdio snd_soc_simple_card_utils crct10dif_ce panel_simple pci_endpoint_test e5010_jpeg_enc cpufreq_dt pvrsrvkm(O) pwm_fan at24 rti_wdt cfg80211 ti_k3_r5_remoteproc btti_uart bluetooth snd_soc_davinci_mcasp snd_soc_ti_udma wave5 rpi_panel_attiny_regulator snd_soc_ti_edma snd_soc_hdmi_codec snd_soc_ti_sdma videobuf2_dma_contig v4l2_mem2mem videobuf2_memops videobuf2_v4l2 videobuf2_common snd_soc_core snd_pcm_dmaengine tc358762 snd_pcm videodev ti_k3_dsp_remoteproc ti_k3_common mc snd_timer snd omap_mailbox optee_rng efi_pstore nfnetlink [ 15.285991] Modules linked in: algif_aead rpmsg_ctrl rpmsg_char cc33xx mac80211 libarc4 snd_soc_simple_card cc33xx_sdio snd_soc_simple_card_utils crct10dif_ce panel_simple pci_endpoint_test e5010_jpeg_enc cpufreq_dt pvrsrvkm(O) pwm_fan at24 rti_wdt cfg80211 ti_k3_r5_remoteproc btti_uart bluetooth snd_soc_davinci_mcasp snd_soc_ti_udma wave5 rpi_panel_attiny_regulator snd_soc_ti_edma snd_soc_hdmi_codec snd_soc_ti_sdma videobuf2_dma_contig v4l2_mem2mem videobuf2_memops videobuf2_v4l2 videobuf2_common snd_soc_core snd_pcm_dmaengine tc358762 snd_pcm videodev ti_k3_dsp_remoteproc ti_k3_common mc snd_timer snd omap_mailbox optee_rng efi_pstore nfnetlink The usual lspci doesn't contain much: lspci 00:00.0 PCI bridge: Texas Instruments Device b010 How should I proceed to make it work? Thanks!
I also saw that both apt and beta repo's do not contain recent rockchip64 kernels at the moment. There is only a recent generic arm64 one. So it is not only my rock3a, also my nanopi-r6c would be affected, but I use own/other/vendor kernels as well, so specific 6.18.8 is not an issue for me. I use extlinux or grub to select a certain kernel (6.19 flavor on nanopi-r6c for example). For my rock3a, I need vendor kernel, but if you use mainline based, you could use standard Debian backports kernel: https://packages.debian.org/trixie-backports/linux-image-arm64 You need to get the .dtb manually and I just assume most features are supported when the rock3a has mainline U-Boot in SPI. You need of course add that to sources.list and specifically select it. You could also use Armbian build framwork to build a 6.18.x yourself, you will also get a header files package then. For Debian14 I see there is: /usr/lib/linux-image-6.18.15+deb14-arm64/rockchip/rk3568-rock-3a.dtb But as indicated, this is total DIY, I have not tested it. I only know that on rock5b I could run standard distro since quite some months, but use 6.1.115 vendor one as I need all RK3588 HW to work.
pquiring replied to Peter Quiring's topic in Libre Sweet Potato
Ok, after doing more tests the issue was the boot switch on the board. It must be switched to boot from SD/eMMC and not SPI (BIOS). Then reboot works fine. -
Werner replied to Igor's topic in Software, Applications, Userspace
ha extension is not a part of the framework. Copy from here https://github.com/armbian/os/tree/main/userpatches/extensions -
If you’re thinking about running Armbian on the OnePlus 8T, basic functionality like calls, SMS, and mobile data will really depend on how well the device drivers are supported in the current build. From what most community discussions suggest, Wi-Fi and some hardware features may work, but cellular, camera, and other components can still be hit-or-miss compared to more mature options like Sailfish OS or Ubuntu Touch on officially supported devices. It’s a good idea to check active developer threads and user reports before installing.
Hi @maxsub, two annotations. Firstly, it's not the Wifi driver but the firmware. Thus echo "options bcmdhd firmware_path=brcm/ nvram_path=brcm/" > /etc/modprobe.d/orangepirv2.conf will get you going. And secondly no, there is no GPU change currently. GPU not working in "current" but may work with dirty tricks using "legacy". That's why it may pay to do some maintenance on the ancient 6.6 kernel.
zm112008 replied to Igor's topic in Software, Applications, Userspace
Hello, I'm getting an error when building the kernel. -
Ah I didn't know about that. I just created a systemd service that runs cpupower at boot.
## Description After a fresh installation of Armbian for Rockchip64 (Rock 3A), the system ships with `linux-image-current-rockchip64` version **26.2.1** (kernel 6.18.8), but the corresponding `linux-headers-current-rockchip64` package for version 26.2.1 is **not available** in the public APT repositories. This prevents installation of kernel headers required for DKMS modules, out-of-tree drivers, or any kernel module compilation. ## Steps to Reproduce 1. Flash the latest Armbian image for `rock-3a` (branch: `current`) from the official download page. 2. Boot the device and connect to the network. 3. Run `apt update` with any standard mirror (e.g., `mirrors.tuna.tsinghua.edu.cn`, `mirror.yandex.ru`). 4. Check installed kernel version: ```bash uname -r # Output: 6.18.8-current-rockchip64 ``` 5. Check available headers: ```bash apt policy linux-headers-current-rockchip64 ``` ## Actual Behavior - Installed image packages: ``` linux-image-current-rockchip64 26.2.1 [installed,local] linux-dtb-current-rockchip64 26.2.1 [installed,local] armbian-bsp-cli-rock-3a-current 26.2.1 [installed] ``` - `apt policy` output for headers: ``` linux-headers-current-rockchip64: Installed: (none) Candidate: 25.11.2 Version table: 25.11.2 500 500 http://<mirror>/armbian noble/main arm64 Packages ... (no 26.2.1 available) ``` ## Expected Behavior - The `linux-headers-current-rockchip64` package version **26.2.1** should be available in the `current` branch repository, matching the kernel shipped in the image. - Alternatively, the image should ship with packages that are already published and synchronized in the public repository. ## Impact - Users cannot install DKMS modules (ZFS, VirtualBox, WiFi drivers, etc.). - Development workflows requiring kernel headers are blocked. - Confusion for users performing a "clean install" who expect a consistent system. ## System Information - **Board:** Radxa Rock 3A - **Armbian version:** 26.2.1 (from image filename/release) - **Kernel:** 6.18.8-current-rockchip64 - **APT branch:** `current` - **Distribution:** Ubuntu Noble (24.04) - **Mirrors tested:** - `http://mirrors.tuna.tsinghua.edu.cn/armbian` - `http://mirror.yandex.ru/mirrors/armbian/apt` - `http://apt.armbian.com` (redirector) ## Possible Causes (hypothesis) 1. **Publishing race condition:** The image was built after `linux-image-26.2.1` was compiled but before `linux-headers-26.2.1` was published to the public repository. 2. **Branch mislabeling:** Version 26.2.1 may have been moved to `edge` after the image was built, but the image metadata was not updated. 3. **Mirror sync delay:** The master repository has the package, but mirrors have not yet synchronized (though multiple mirrors were tested over several days).
@Morales Morales
Morales Morales replied to sicxnull's topic in Allwinner CPU Boxes
Hi, sorry to interrupt, but could you tell me how to do hardware acceleration? I have an Allwinner H313 v5.1 - Last week
OrangePi 5 Pro need help booting into nvme
Water Sprayer replied to Fabricio Martínez Tamayo's topic in Rockchip
Read post on October 27 2024 Worked for me but with a couple extra steps burn .iso cfcard boot into device dd mmblk to nvme edit UUID for nvme -- Request new UUID for NVME (when dd I had the same UUID for cf card and nvme) edit orangpiEnv.txt in the armbian-config /System/Kernel/Edit Boot Env and apply the new UUID to the rootdev="New UUID" Edit fstab to add this line: /dev/mmcblk1p1 /boot vfat defaults 0 2 itd -
Excellent. Thank you so much. I will try the newer brcm driver today. So the GPU change is now in main?
