Upcoming Events
Volunteering positions
Test Automation Engineer
Position: Software integration test engineerNumber of places: 16Applicants: 8
Chat | Social Media
#armbian at
irc.libera.chat or irc.oftc.net
Matrix or Discord
Mastodon | 𝕏 -
Popular Now
Activity Stream
8
Kernel 6.12.20 Banana Pi M2 zero USB doesn't work
Thank you c0rnelius, this was the solution ! Now the flashdrive is listed again Regards Bernd -
4
Same problem: Bus 001 Device 004: ID 14b0:0206 StarTech.com Ltd. 008-2DR166 I've blocked kernel updates via /etc/apt/preferences: Package: base-files Pin: version * Pin-Priority: -1 Package: armbian-bsp-cli-odroidhc4-current Pin: version * Pin-Priority: -1 Package: armbian-firmware Pin: version * Pin-Priority: -1 Package: linux-dtb-current-meson64 Pin: version * Pin-Priority: -1 Package: linux-image-current-meson64 Pin: version * Pin-Priority: -1 Package: linux-u-boot-odroidhc4-current Pin: version * Pin-Priority: -1 -
2
Ugoos AM9 s905x5 ARMBIAN build
Ugoos AM9 DTB extracted from stock firmware,if it helps someone. AM9dtb.zip -
2
1
Armbian on Odroid N2+ 4 GB with eMMC does not boot from eMMC.
https://debug.armbian.de
Member Statistics
