rvalle
  1. I agree, yes. It is very nice and Agile. I can see the new kernel release .51 in beta apt repo. Will test it in the environment I saw the problems. R.
  2. @Igor I am trying to understand the publishing method. How are patches turned into updates? I guess updates are pushed from armbian-firmware repo, or? But I cant see the relationship between the builder and the firmware repos.... You mentions updates go out right away. how does it work?
  3. Nice! Sent from my 2201116SG using Tapatalk
  4. Sorry, have never done this... Will check how you did. Sent from my 2201116SG using Tapatalk
  5. @Igor this recent fix seems like it: https://lore.kernel.org/all/E1sbJvd-001rGD-E3@rmk-PC.armlinux.org.uk/#r apparently the driver was decoding the duplex mode incorrectly.
  6. @Igor , thanks for your comment: I am getting some variation, but perhaps all of them are degraded anyway. While I wait for the upstream fix, is it possible to build armbian on the last working kernel version? How would that go?
  7. Hi! I am looking into OdroidM1 network performance with kernel 6.6.47-current-rockchip64 ( 24.8.1 ) For some reason network performance is x10 faster (upstream) in bookworm and noble, when compared to jammy. Downstream performance is fine, delivering the same performance in jammy and the other distributions. Since all of them are using the same kernel, I assume that there must be some configuration that jammy is missing, or? Any idea about what could be going on?
  8. rvalle replied to Igor's topic in Odroid M1
    Ok, I tested with armbian 24.8.1/6.6.47 and it seems to be normal now. R.
  9. rvalle replied to Igor's topic in Odroid M1
    Hi @rpardini I am putthing an M1 in production for a MAAS server, the M.2 and ram make it ideal for LAB deployment. I found a problem Network downstream is very fast, but upstream below 100Kb/s. It should be getting 7.5Mb/s... as a RPI4, or the M1 with an USB ethernet adapter. My M1 is on 6.6.39, did you notice this before? I will try to test with the latest verion.... R.
  10. I think the m1s is an outstanding target. Very affordable and powerful. I own one, and I am available to test. I would not know where to start in terms of adding a new target to Armbian, but I can help with testing.
