FredK
  1. As you might see in my signature I decided to retain the Helios4 withdrawing the goodbye message above. @laibsch Actual problem: I didn't succeed in configuring Wake-on-LAN on 26.2.1. What I did was to replace "eth0" by "end1" in /lib/systemd/system/helios4-wol.service Triggering the suspend mode by pm-suspend Decompilation of armada-388-helios4.dtb didn't contain the device tree patch mentioned in https://wiki.kobol.io/helios4/files/wol/helios4-dts-add-wake-on-lan-support.patch Any clue what's missing? @Igor armbian-config does not find any .dtb files in /boot/dtb ("Device Tree Editor") /boot/dtb is a symlink to the directory dtb-6.6.124-current-mvebu.
  2. After more than six successful years with Helios4, I have to say goodbye to this platform and the highly valued, helpful, and knowledgeable Armbian forum. With 32-bit, it’s no longer feasible to continue using it in the future. I have installed the 4 8TB hard drives from the NAS into an Odroid H4+ (Intel, 64-bit), installed OMV8, and on top of that, Nextcloud-AIO Hub 26 Winter and AdGuardHome. Thank you very much for your support over the past few years. btw. The Helios4 hardware (excluding the hard drives) is still available.
  3. @wolf7250 > Is it possible this has been resolved now and I won't need to do anything? I think so, because I was just able to perform a package update without any problems. > Or will I likely need to run the commands that Igor listed in the post that you linked? The background of my post was to encourage you to upgrade your OMV6 to OMV7 (after a full backup) and if the same (minor) problems arise, the solution is well-known.
  4. @wolf7250fyi: I upgraded my Helios4 from OMV6 to OMV7 RC1 in February 2024 already. Upgrade went smoothly. But after that further OMV updates were not possible, solution found at https://forum.armbian.com/topic/23465-apt-get-update-fails-with-public-key-errors/?do=findComment&comment=178626
  5. > ... straightforward and smooth. Same in 25.8.2
  6. ... straightforward and smooth.
  7. @Igor > There are few other things that would be nice to get working - I notice WOL service erroring out, fan support is unknown. Regarding "fan support": Fan was working correctly after installing fancontrol, see https://forum.armbian.com/topic/44379-fancontrol-bookworm-solved/#findComment-209055 (Thread is in Standard support->Other families->Helios 4)
  8. @helios4user12 > I updated the sd card with the provided image via dd. Will this be a one time thing? Yes. In the meantime there were further updates and my Helios4 is still going strong.
  9. @Igor After @Mangix's post I was able to fix my installation patching the bootloader. I'm aware that Helios4 is a dead-end and I plan to switch to a 64bit-SBC providing 4 or 5 SATA-ports (but I don't find a suitable board up to now).
  10. @Mangix Thank you, that was simple. @Dee2022 What I did: Download of the 1st SolidRun image (... sd.kwb) Copy the image to SDcard containing unbootable Armbian 25.2 (on my Linux desktop using dd, SDcard available here at /dev/sdf) sudo dd if=u-boot-helios-4-sd.kwb of=/dev/sdf bs=512 seek=1 status=noxfer sudo sync Boot Helios4. Voilà.
  11. @Igor Is a new update to 25.2 for Helios4 planned of the kernel binaries ? If so, when can this be expected? If not, what can I do? The post of @Josua-SR is marked as solution. But I have no idea what to do with the *.kwb files from SolidRun. In particular I never made a custom build.
  12. Same here: "No boot after upgrade to Armbian 25.2.2". Same message: Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid The very "unfriendly" behaviour was the unattended-upgrade. Therefore I had no chance first to make an update of my 24.11 system with Linux 6.6.63-current-mvebu (see signature). I had to use for recovery the backup from 24.8 immediately before 24.11 in the pipeline. The recovered system is now Armbian 24.8 with Linux 6.6.47-current-mvebu. Any chance to get 24.11 again?
  13. @pegamonstro I'm using a very similar configuration (see signature) but as a part of OMV. Last February I performed the upgrade to bookworm and OMV7 without any severe problem worth mentioning. mdadm and /proc/mdstat were present. The multiple device /dev/md0 is now present as /dev/md127. Perhaps it would help to install OMV7 to see whether your RAID5 can be recovered using OMV storage management.
