jbergler
3620 profile views
  1. I pulled that from the postinst of the previous debian package `ar x whatever.deb` and then untar the control.tar.gz file to get it. Since you're booting without issues, I wonder if your boot.ini has some other config than me? I have this part that feels relevant # legacy and mainline kernel diff if ext4load mmc ${devno}:1 0x00000000 "/boot/.next" || fatload mmc ${devno}:1 0x00000000 ".next" || ext4load mmc ${devno}:1 0x00000000 ".next"; then echo "Found mainline kernel configuration" setenv uartconsole "ttyAML0,115200n8" setenv kernelimage "uImage" else echo "Found legacy kernel configuration" setenv uartconsole "ttyS0,115200n8" setenv kernelimage "zImage" fi
  2. @hzyitc I wonder if this commit might be related: https://github.com/armbian/build/commit/76ce4c3a3ddb8f93686598808f6d1687232f9ddb removed patch/kernel/archive/meson-6.1/generate-uImage-instand-of-zImage.patch
  3. Can confirm I'm also seeing this. I'm able to recover by installing the 23.02.2 linux-image-current-meson64 and linux-dtb-current-meson64 packages from /var/cache/apt/archives. From what I can tell it's installing the modules for 6.1.50 in /lib/modules but is somehow still booting 6.1.11 /boot/uImage isn't getting updated $ strings /boot/uImage | grep "Linux version" Linux version 6.1.11-meson64 (root@29682b33de96) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #23.02.2 SMP PREEMPT Linux version 6.1.11-meson64 (root@29682b33de96) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #23.02.2 SMP PREEMPT Sat Feb 18 00:07:55 UTC 2023 I can confirm that running the following command manually gets the device back into a working state $ mkimage -A arm64 -O linux -T kernel -C none -a 0x1080000 -e 0x1080000 -n Linux -d /boot/vmlinuz-6.1.50-current-meson64 /boot/uImage
