- ODROID N2-PETITBOOT
- Trixie on ZeroPi SBC
ZeroPi booting with 25.5.0-trunk.256, but not newer images
The raised U-Boot version here is the culprit: https://github.com/armbian/build/commit/b8844c9 Maybe done by accident, since the commit/PR message does not mention the ZeroPi at all, or that it has been successfully tested on that board. Removing those two lines BOOTBRANCH="tag:v2025.04" BOOTPATCHDIR="v2025-sunxi" , reverting to U-Boot v2024.01 and respective patch dir, solves it for us. Of course, if someone finds time, it would be interesting to find out which missing patches or changes in upstream U-Boot are causing the issue. What I see in our logs is that the last starting and never finishing service is one which calls "udevadm settle", hence waits for udev rules to be processed, endlessly. The NanoPi NEO image boots on the board, but using the NanoPi NEO device tree on the ZeroPi image does not boot, which left only the bootloader as culprit. Maybe it puts some device into a bad state which causes the kernel/udev hang. Duplicate topic:
regulatory.db failing to load
CRDA is deprecated, not needed since Linux 4.15, hence the package removed with Debian Bookworm. Problem is the default regulatory database on Debian works with Debian kernel only, not with Armbian kernel. But wireless-regdb provides the upstream database as well, so you only need to switch: sudo update-alternatives --set regulatory.db /lib/firmware/regulatory.db-upstream
Kernel oops after zfs module and 6.1.84-vendor-rk35xx
It does not seem to be the ZFS module, but the kernel or headers themselves. In attempt to rule it out, I installed r8168-dkms, and forced the result to override the one shipped with the kernel package: dkms install --force r8168/8.051.02 It segfaults as well (and same kernel oops): # modprobe r8168 Segmentation fault A set of linux-*-vendor-rk35xx packages freshly built with Armbian build system does not solve the issue, which makes sense, as it is still Linux 6.1.84.
Debian Trixie brick after kernel update
In the meantime, the difference between the two initramfs images lsinitramfs revealed is conf/conf.d/zz-resume-auto. This is generated by mkinitramfs in case there is a RESUME variable set, which is expected to be a path or UUID to a swap partition, for suspend-to-disk functionality. Searching for it in DuckDuckGo gives kernel panic reports as 3 of 5 first results, though mostly due to a syntax error in this script, which I would expect to be fixed, or non-existing swap partition UUID. On the host (outside the initramfs), there is no other initramfs-tools config than the default, which does not define RESUME, and there is (has never been) a swap partition in our or Armbian images, but at best a swap file on the root filesystem. So I wonder why this script is generated. Since I could not find any reason in initramfs or kernel maintainer/postinst scripts or configs, I guess the kernel itself somehow must ask/trigger initramfs-tools to generate it. It however can not contain anything correct, but either nothing or false content, as there is no swap partition. Sadly the user who helped investigating initially set up the system freshly now, hence cannot further help, checking the content of this script and whether it can be prevented via RESUME=none in initramfs-tools config. I can further investigate myself from January 17th on. However, while this script, and the kernel panic in search results seem very suspicious, it might be the wrong track. But so far it is the only trace I was able to find ๐.
Failing log: https://0x0.st/8i-h.txt Compared to successful boot with 6.6.43-current-odroidxu4: https://0x0.st/8ioK.txt Notable differences: [ 1.861869] Trying to unpack rootfs image as initramfs... [ 1.862068] rootfs image is not initramfs (invalid magic at start of compressed archive); looks like an initrd The 2nd line is not present in successful boot. Initramfs compression is done with zstd, default since Bookworm, and of course the Armbian kernel builds support it: https://github.com/armbian/build/blob/main/config/kernel/linux-odroidxu4-current.config#L198-L204 [ 4.879383] Disabling rootwait; root= is invalid. [ 4.883718] RAMDISK: Couldn't find valid RAM disk image starting at 0. [ 4.891991] /dev/root: Can't open blockdev [ 4.894661] VFS: Cannot open root device "UUID=a3af1683-ebad-4def-b14b-3bdb314411d2" or unknown-block(0,0): error -6 It seems to not support the root=UUID entry, which is something the initramfs is supposed to provide (support for UUIDs I mean). So it indeed looks like something with the initrd/uInitrd is wrong. It has grown in size from 8888221 to 9439519 but otherwise seems ok (checksums). initramfs-tools did not get an update and configs are the same, same with zstd. This was faced on Bookworm btw, so seems to be independent of the Debian version. I have physical access to an XU4 only in two weeks. Will see whether I can get some content check/comparison of the initrd from our user(s), and some logs of the kernel upgrade/initramfs generation. EDIT: Addresses for kernel, initramfs and dtb 0x40008000 0x42000000 0x44000000 are still fine with large margin. I wonder whether initrd_high "0xffffffff" might be a problem, as this requires support by the kernel as well.
OPI5Plus - 32GB version issue
Since a board with 16G RAM practically has a little less than 16 GiB RAM, probably mem=16G limits it a little too less to prevent the crash 100% reliably, while mem=15G would do. I don't know how exactly those limits are applied, and at which point exactly the power usage of the RAM raises above the critical point (in case really this is the reason for the crashes), so this is just a guess which can be tested.
Either, you need to add it to the "extraargs=" (optionally "extraboardargs=") line in /boot/armbianEnv.txt, in case create those lines, if missing: extraargs=mem=16G Or, when adding it to /boot/boot.cmd directly, you need to generate /boot/boot.scr from it: mkimage -C none -A arm64 -T script -d /boot/boot.cmd /boot/boot.scr The initramfs does not need to be regenerated in any case.
Rock 4 SE not booting
We found the same issue. It does boot with the dedicated rock-4se target, hence pretty surely an issue with the updated DDR blob. The Armbian repo ships functional U-Boot packages already: https://apt.armbian.com/pool/main/l/linux-u-boot-rock-4se-current/ But WiFi does not work. We tried with rk3399-rock-4se.dtb as well as rk3399-rock-pi-4b.dtb (as used in armbianEnv.txt with rock-4se target). Still trying to figure out what is missing: The correct brcmfmac driver loads. With ROCK 4 SE device tree, it tries to load the brcm/brcmfmac43455-sdio.radxa,rock-4se.bin, else brcm/brcmfmac43455-sdio.radxa,rockpi4b.bin, but actually it uses brcm/brcmfmac43455-sdio without the device-specific appendix anyway. Also creating symlinks for the device-specific suffix mutes the warning, but does not fix WiFi: The adapter is just not showing up in e.g. `ip link`. Does someone know why the ROCK 4B device tree is explicitly used for the ROCK 4 SE target? For the U-Boot config, there is a note that upstream U-Boot ROCK 4 SE target is/was broken, but no hint why the 4B device tree is used. I thought that some patches might patch the 4B device tree only, but as far as we tested, both device trees generally work, but with none of them onboard WiFi is working on the ROCK 4 SE.
