amazingfate
Other groups
Contributor/Maintainer
4 Followers
  1. I don't have IR device to test. While in kernel driver code there is pm_ops defined: https://github.com/armbian/linux-rockchip/blob/rk-6.1-rkr5.1/drivers/input/remotectl/rockchip_pwm_remotectl.c#L1063-L1066
  2. This build has disabled ffmpeg, I don't know it is possible to build with it for wayland client. I recommend x11 client because it is the most usable client with the most features. FreeRDP developers is developing a new sdl client for all platforms: linux, mac, wayland, x11, but that is still at an early stage. If you run xfreerdp, make sure to use gfx:AVC444 so that server sends h264 stream to you, then freerdp will use ffmpeg to decode it. You can check /proc/mpp_service/ to see if mpp hardware decoder is used. But don't expect the cpu will be extremely low, freerdp is decoding two avc420 streams and then combine them into one yuv444 frame, and then use cpu to convert yuv444 to rgb, then render it to x11, hardware decoder can only off-load few of the cpu load.
  3. onleplus 8t is running mainline kernel so don't expect it can work as an android phone. At the moment cellular and camera is not working. Dsiplay, touchscreen, wifi and bluetooth work.
  4. These errors are fine because moonlight will try all the hw accel APIs like vaapi, vdpau and vulkan, but on rockchip platform we only need rkmpp decoder, as you can see in the log it is detected,
  5. Armbian doesn't release this old LTS release now, but you can build one from github.com/armbian/build Yes, flatpak version is using ffmpeg in its own sandbox without rkmpp support, if you build the deb locally, it will get linked with ffmpeg on system which has rkmpp support.
  6. There is no moonlight-qt packaged in this ppa for noble, you can build from source: https://salsa.debian.org/amazingfate/moonlight-qt
  7. If you are talking about lag with discord webpage, vpu accel won't help because there is no video played in discord. You can check chromium's gpu status at chrome://gpu, see if the gpu driver is working. My ppa only packages chromium for noble, ubuntu 25.04 is not supported. While chromium in my ppa only add patches to let chromium use vpu when playing videos, this should not help improving discord webpage performance.
  8. Hi, There are differences between the bookworm and noble images: - bookworm is running vendor 6.1.99 kernel which is from rockchip's sdk, while noble is running mainline 6.12.13. The SDK kernel may have issues detecting screen resolution, you may wait for a new version 6.1.115 to see if the issue is fixed. - bookworm should be running without gpu driver, you can check it by command "dpkg -l|grep libgl1-mesa-dri", if the version is lower than 24.1, the gpu is not drived, you can try bookworm image built with mesa-vpu extension for example the cinnamon one: https://dl.armbian.com/bananapim7/Bookworm_current_cinnamon-backported-mesa - You are running both images with xfce desktop, so the scaling issue may be desktop environment related, usually wayland session(such as gnome wayland) has better support on HiDPI screens.
  9. I have created a fix pr: https://github.com/radxa-pkg/aic8800/pull/27 You can download debs from workflow artifacts: https://github.com/radxa-pkg/aic8800/actions/runs/13725535037
  10. Please try this fix: https://github.com/armbian/linux-rockchip/pull/328
  11. This commit should be in the source tree if you are using the latest code. I have no idea why the issue happens again. I will check it later.
  12. This is a dkms related issue when BTF is enable. This commit should have fixed it: https://github.com/armbian/linux-rockchip/commit/7294c3d056ca52ba312f1b7cdc5cd2273f7d9766
  13. After 20min of fio test, nvme disk is still fine $ sudo fio --name=randwrite --ioengine=sync --rw=write --bs=4k --numjobs=1 --size=1G --runtime=1200s --time_based --directory=/mnt [sudo] password for jfliu: randwrite: (g=0): rw=write, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=sync, iodepth=1 fio-3.36 Starting 1 process Jobs: 1 (f=1): [W(1)][93.4%][w=93.4MiB/s][w=23.9k IOPS][eta 01m:19s] Jobs: 1 (f=1): [W(1)][100.0%][eta 00m:00s] randwrite: (groupid=0, jobs=1): err= 0: pid=5569: Wed Dec 11 10:26:57 2024 write: IOPS=49.7k, BW=194MiB/s (203MB/s)(227GiB/1200478msec); 0 zone resets clat (nsec): min=1166, max=3770.1M, avg=18646.17, stdev=2441229.11 lat (nsec): min=1458, max=3770.1M, avg=18735.33, stdev=2441230.02 clat percentiles (nsec): | 1.00th=[ 1464], 5.00th=[ 1752], 10.00th=[ 2040], | 20.00th=[ 2040], 30.00th=[ 2320], 40.00th=[ 2640], | 50.00th=[ 2640], 60.00th=[ 2928], 70.00th=[ 3216], | 80.00th=[ 3216], 90.00th=[ 4080], 95.00th=[ 4640], | 99.00th=[ 7904], 99.50th=[ 10560], 99.90th=[8716288], | 99.95th=[9109504], 99.99th=[9240576] bw ( KiB/s): min= 24, max=1543457, per=100.00%, avg=227861.36, stdev=262064.21, samples=2093 iops : min= 6, max=385864, avg=56965.30, stdev=65516.07, samples=2093 lat (usec) : 2=7.53%, 4=80.62%, 10=11.27%, 20=0.41%, 50=0.03% lat (usec) : 100=0.01%, 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01% lat (msec) : 2=0.01%, 4=0.01%, 10=0.13%, 20=0.01%, 50=0.01% lat (msec) : 100=0.01%, 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01% lat (msec) : 2000=0.01%, >=2000=0.01% cpu : usr=3.12%, sys=17.15%, ctx=251826, majf=0, minf=12 IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0% submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% issued rwts: total=0,59630438,0,0 short=0,0,0,0 dropped=0,0,0,0 latency : target=0, window=0, percentile=100.00%, depth=1 Run status group 0 (all jobs): WRITE: bw=194MiB/s (203MB/s), 194MiB/s-194MiB/s (203MB/s-203MB/s), io=227GiB (244GB), run=1200478-1200478msec Disk stats (read/write): nvme0n1: ios=0/265014, sectors=0/414735560, merge=0/734, ticks=0/1115350653, in_queue=1115646197, util=98.45%
  14. I'm having a v1.1 board. Now I boot a noble cli image with 6.1.84 vendor kernel. 120s fio test is fine: $ sudo fio --name=randwrite --ioengine=sync --rw=write --bs=4k --numjobs=1 --size=1G --runtime=120s --time_based --directory=/mnt randwrite: (g=0): rw=write, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=sync, iodepth=1 fio-3.36 Starting 1 process Jobs: 1 (f=1): [W(1)][100.0%][w=1079MiB/s][w=276k IOPS][eta 00m:00s] randwrite: (groupid=0, jobs=1): err= 0: pid=4531: Wed Dec 11 01:49:08 2024 write: IOPS=229k, BW=895MiB/s (939MB/s)(105GiB/120116msec); 0 zone resets clat (nsec): min=1166, max=1465.6M, avg=3015.61, stdev=345679.23 lat (nsec): min=1458, max=1465.6M, avg=3105.60, stdev=345687.63 clat percentiles (nsec): | 1.00th=[ 1752], 5.00th=[ 1752], 10.00th=[ 1752], 20.00th=[ 2040], | 30.00th=[ 2040], 40.00th=[ 2040], 50.00th=[ 2040], 60.00th=[ 2320], | 70.00th=[ 3216], 80.00th=[ 3216], 90.00th=[ 3504], 95.00th=[ 4080], | 99.00th=[ 6112], 99.50th=[ 7584], 99.90th=[ 11072], 99.95th=[ 13376], | 99.99th=[749568] bw ( KiB/s): min=49304, max=1457152, per=100.00%, avg=929145.40, stdev=313692.78, samples=236 iops : min=12326, max=364288, avg=232286.35, stdev=78423.29, samples=236 lat (usec) : 2=15.55%, 4=79.07%, 10=5.21%, 20=0.15%, 50=0.01% lat (usec) : 100=0.01%, 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01% lat (msec) : 2=0.01%, 4=0.01%, 10=0.01%, 20=0.01%, 50=0.01% lat (msec) : 100=0.01%, 2000=0.01% cpu : usr=15.40%, sys=77.45%, ctx=52410, majf=0, minf=22 IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0% submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% issued rwts: total=0,27525121,0,0 short=0,0,0,0 dropped=0,0,0,0 latency : target=0, window=0, percentile=100.00%, depth=1 Run status group 0 (all jobs): WRITE: bw=895MiB/s (939MB/s), 895MiB/s-895MiB/s (939MB/s-939MB/s), io=105GiB (113GB), run=120116-120116msec Disk stats (read/write): nvme0n1: ios=1/113583, sectors=8/216264040, merge=0/248, ticks=9/45093762, in_queue=45095689, util=90.05% I'm testing with a 256G NVME SSD.
  15. I'm sorry that the image I downloaed from https://www.armbian.com/armsom-sige7/ is running mainline kernel 6.12.1. I did not check the 6.1 vendor kernel. My board is at home and I don't remember the board version. I will test with 6.1 kernel again when I get home today. BTW what kind of NVME SSD you are using?
