chaitan3
9 -
chaitan3 replied to XXXBold's topic in Orange Pi 5
I'm using Ubuntu 24.04 noble armbian distribution, the branch I used for ffmpeg is https://code.ffmpeg.org/Kwiboo/FFmpeg/src/branch/v4l2request-v3 The ffmpeg included in the distribution does not matter, but regardless it is version 6.1.1. The mpv is built against the locally compiled ffmpeg with libplacebo from https://code.videolan.org/videolan/libplacebo.git -
I have tested the following PR: https://github.com/mpv-player/mpv/pull/14690 It needs compilation of a custom ffmpeg (linked in PR) + mpv (with this PR). My findings are reported here: https://github.com/mpv-player/mpv/pull/14690#issuecomment-4159253319 Overall it is working, haven't tested Kodi yet. -
@Efe Çetin I am using Orange Pi 5b, and I am not able to use the USB Type-C port or the USB 2.0 on Armbian edge kernel 6.19. The 2 USB 3.0 ports do work properly. Below is the relevant usb related output from dmesg. Any idea on if this is an issue specific to Orangepi 5b? From the dtsi it seems 5 and 5b largely share the common code related to type-c. I am looking forward to being able to use my Type-C hub on this board and in the future have display out. [ 0.000000] Kernel command line: root=UUID=829dfbd2-5b37-4927-a185-af2d592d8118 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=b255b69e-8e14-4261-aebc-56249e9516c1 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cma=256M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory [ 0.064272] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /usb@fc000000 [ 0.064928] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /phy@fed80000 [ 0.064966] /usb@fc000000: Fixed dependency cycle(s) with /phy@fed80000 [ 0.064994] /phy@fed80000: Fixed dependency cycle(s) with /i2c@fec80000/usb-typec@22/connector [ 0.080439] usbcore: registered new interface driver usbfs [ 0.080460] usbcore: registered new interface driver hub [ 0.080476] usbcore: registered new device driver usb [ 0.310308] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.19 [ 0.310319] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.310325] usb usb1: Product: xHCI Host Controller [ 0.310329] usb usb1: Manufacturer: Linux 6.19.10-edge-rockchip64 xhci-hcd [ 0.310334] usb usb1: SerialNumber: xhci-hcd.3.auto [ 0.310885] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 0.310942] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.19 [ 0.310949] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.310953] usb usb2: Product: xHCI Host Controller [ 0.310958] usb usb2: Manufacturer: Linux 6.19.10-edge-rockchip64 xhci-hcd [ 0.310962] usb usb2: SerialNumber: xhci-hcd.3.auto [ 0.311435] usbcore: registered new interface driver usb-storage [ 0.311658] ehci-platform fc880000.usb: EHCI Host Controller [ 0.311672] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 3 [ 0.311678] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 0.311725] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 0.311752] ehci-platform fc880000.usb: irq 60, io mem 0xfc880000 [ 0.311870] ohci-platform fc8c0000.usb: irq 63, io mem 0xfc8c0000 [ 0.311880] ehci-platform fc800000.usb: EHCI Host Controller [ 0.311894] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 0.311914] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 5 [ 0.311933] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 6 [ 0.312063] ehci-platform fc800000.usb: irq 61, io mem 0xfc800000 [ 0.312094] ohci-platform fc840000.usb: irq 62, io mem 0xfc840000 [ 0.315120] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /phy@fed80000 [ 0.315157] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /usb@fc000000 [ 0.323135] usbcore: registered new interface driver usbhid [ 0.323139] usbhid: USB HID core driver [ 0.326360] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 0.326663] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.19 [ 0.326682] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.326696] usb usb3: Product: EHCI Host Controller [ 0.326707] usb usb3: Manufacturer: Linux 6.19.10-edge-rockchip64 ehci_hcd [ 0.326719] usb usb3: SerialNumber: fc880000.usb [ 0.338294] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 0.338591] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.19 [ 0.338610] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.338624] usb usb5: Product: EHCI Host Controller [ 0.338636] usb usb5: Manufacturer: Linux 6.19.10-edge-rockchip64 ehci_hcd [ 0.338647] usb usb5: SerialNumber: fc800000.usb [ 0.370528] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.19 [ 0.370551] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.370565] usb usb4: Product: Generic Platform OHCI controller [ 0.370577] usb usb4: Manufacturer: Linux 6.19.10-edge-rockchip64 ohci_hcd [ 0.370588] usb usb4: SerialNumber: fc8c0000.usb [ 0.372081] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.19 [ 0.372093] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.372099] usb usb6: Product: Generic Platform OHCI controller [ 0.372104] usb usb6: Manufacturer: Linux 6.19.10-edge-rockchip64 ohci_hcd [ 0.372108] usb usb6: SerialNumber: fc840000.usb [ 0.586348] usb 5-1: new high-speed USB device number 2 using ehci-platform [ 0.732000] usb 5-1: New USB device found, idVendor=0bda, idProduct=c820, bcdDevice= 2.00 [ 0.732030] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 0.732044] usb 5-1: Product: 802.11ac NIC [ 0.732055] usb 5-1: Manufacturer: Realtek [ 0.732066] usb 5-1: SerialNumber: 123456 [ 0.882361] usb 4-1: new full-speed USB device number 2 using ohci-platform [ 1.101467] usb 4-1: New USB device found, idVendor=08bb, idProduct=2902, bcdDevice= 1.00 [ 1.101498] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1.101511] usb 4-1: Product: USB PnP Sound Device [ 1.101523] usb 4-1: Manufacturer: C-Media Electronics Inc. [ 1.108324] input: C-Media Electronics Inc. USB PnP Sound Device as /devices/platform/fc8c0000.usb/usb4/4-1/4-1:1.2/0003:08BB:2902.0001/input/input0 [ 1.163106] hid-generic 0003:08BB:2902.0001: input,hidraw0: USB HID v1.00 Device [C-Media Electronics Inc. USB PnP Sound Device] on usb-fc8c0000.usb-1/input2 [ 6.294737] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget. [ 6.609966] usbcore: registered new interface driver btusb [ 6.711216] usbcore: registered new interface driver snd-usb-audio [ 7.100868] usbcore: registered new interface driver rtw88_8821cu A full dmesg is also attached. dmesg.log
- 36 replies
- Orange Pi 5
- Orange Pi 5B
(and 1 more)
Tagged with:
chaitan3 replied to KhanhDTP's topic in Orange Pi 5
@KhanhDTPHow to choose which dxvk version to use for which game from your dxvk stripped github actions? Are there a set of versions that are known to be more stable? Also, what is the GPU clock bug, I am on kernel 6.19 using mesa 26.1-git. -
Is HEVC 10-bit supported by the rkvdec2 mainline driver with the V4L2 request driver? I have compiled the ffmpeg and mpv with v4l2 PRs on Ubuntu 24.04 noble with Armbian 26.2.1 edge kernel 6.19. I have H264, HEVC 8-bit and AV1 working. Only HEVC 10-bit and VP9 (which is coming soon) are not working with patched mpv using vo=gpu-next and hwdec=v4l2request-copy.
Hi, just want to follow up that I'm seeing the same issues as @WimRoose above. On latest mainline 6.13 or 6.14, there is no output about the wifi module in lspci. Consequently, there is no wifi device. This followiing pull request supposedly added support last year, but it does not seem to be working. https://github.com/armbian/build/pull/6486 @BatVankoare you able to bring up wifi on the mainline edge kernel on Orangepi 5B?
Please ignore. Seems to be working now, was missing the following flags: --use-gl=egl --ignore-gpu-blacklist --enable-gpu-rasterization --enable-zero-copy
Hi, I'm seeing the following error in Chromium when trying to play youtube, the video loading screen never opens the video. I have installed chromium-browser (+libv4l-rkmpp, +ffmpeg, +rockchip-multimedia-config) from the ppa: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/rockchip-multimedia My OS version is Armbian 23.08 Jammy. When using FFplay the rkmpp hardware decoder is able to correctly decode h264 and hevc content, so there does not seem to be a problem with rkmpp. Any thoughts on what could be wrong? I found another guy who had the same issue, but there was no resolution: https://github.com/armbian/build/issues/5384 Failed to query video capabilities: Inappropriate ioctl for device Failed to query video capabilities: Inappropriate ioctl for device Failed to query video capabilities: Inappropriate ioctl for device Failed to query video capabilities: Inappropriate ioctl for device [7199:7199:0929/200251.817665:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.818176:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=0 texture_id=180 [7199:7199:0929/200251.818517:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.818876:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=1 texture_id=181 [7199:7199:0929/200251.819135:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.819298:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=2 texture_id=182 [7199:7199:0929/200251.819505:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.819676:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=3 texture_id=183 [7199:7199:0929/200251.819929:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.820091:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=4 texture_id=184 [7199:7199:0929/200251.837653:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.837912:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=5 texture_id=185 [7199:7199:0929/200251.838197:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.838384:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=6 texture_id=186 [7199:7199:0929/200251.838653:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.838815:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=7 texture_id=187 [7199:7199:0929/200251.839051:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.839206:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=8 texture_id=188 [7199:7199:0929/200251.839443:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported. [7199:7199:0929/200251.839600:ERROR:v4l2_video_decode_accelerator.cc(525)] could not create EGLImageKHR, index=9 texture_id=189 [7199:7199:0929/200251.839815:ERROR:gl_display.cc(520)] EGL Driver message (Error) eglCreateImageKHR: EGL_KHR_image not supported.
