3 hours ago3 hr HelloBuilding an new image with KERNEL_CVE_PATCHES="yes" and the build fails with rejected when including two patches (attached in log files due to formatting). Is it common to run into these kind of problems with cve patches? Any custom workarounds to only ignore the failing patches?Testing a new build again with KERNEL_CVE_PATCHES="no" next, with the following but running into other errors :./compile.sh CLEAN_LEVEL=sources,cache,debs,make rm: cannot remove '/armbian/cache/sources/linux-kernel-worktree': Device or resource busy rm: cannot remove '/armbian/cache/sources/u-boot-worktree': Device or resource busy [|] Error 1 occurred in main shell [ at /armbian/lib/functions/general/cleaning.sh:43Thankspatch-failed.log.gz Edited 3 hours ago3 hr by Raul
