hmartin
Profile Information
  • Gender
    Not Telling
4290 profile views
  1. I carved u-boot out of the Jammy image from Google Drive (Orangepizero3_1.0.0_ubuntu_jammy_server_linux6.1.31.7z) and applied it to the bookworm image (along with copying the dtb, as instructed) and now it's booting. I updated the GitHub issue with my test results. I'll attach it here so that people don't have to download a 575MB image from Google Drive just to carve it (gunzip it first). u-boot-jammy.bin.gz
  2. Yes, I've followed the instructions: $ sudo mount /dev/sda1 /mnt/ $ sudo cp sun50i-h616-orangepi-zero3-4gb.dtb /mnt/boot/dtb/allwinner/sun50i-h616-orangepi-zero3.dtb $ sudo dd bs=1k seek=8 if=u-boot-sunxi-with-spl-opizero3-4gb.bin of=/dev/sda 631+1 records in 631+1 records out 646523 bytes (647 kB, 631 KiB) copied, 0.156442 s, 4.1 MB/s Unfortunately, it does not boot beyond "Trying to boot from MMC1" which makes me believe that there is probably an issue with the u-boot/SPL for the 4GB board.
  3. @ag123 can you post the full bootlog for the armbian release from GitHub (23.08)? I tried both bookworm and jammy with several micro SD cards (including name brands like Samsung) and my board (4GB model) never gets further than the following: U-Boot SPL 2021.07-armbian (Jul 12 2023 - 10:04:49 +0000) DRAM: 4096 MiB Trying to boot from MMC1 * Armbian_23.08.0-trunk_Orangepizero3_bookworm_current_6.1.31-1GB-2GB.img.xz (sha256: 6c58ad6122fd62769e1063164df3cdf004af9d498f69db3f1c86094cc749a375) * Armbian_23.08.0-trunk_Orangepizero3_jammy_current_6.1.31-1GB-2GB.img.xz (sha256: 7a794393ef8a5fedc73c4cc977cc5f29660ba106f17d0a6c2322a926f88e91fe) And yes, I did copy the 4GB dtb and u-boot as instructed. I know this forum is not the place to ask for support for unofficial Armbian forks, but I'm just curious if you encountered any such issues. If I remove the micro SD card entirely, the board boots some kind of Android from the SPI: U-Boot SPL 2021.07-orangepi (Jul 15 2023 - 15:02:23 +0800) DRAM: 4096 MiB Trying to boot from MMC1 [53]HELLO! BOOT0 is starting! [56]BOOT0 commit : 3ae35eb [59]set pll start [61]periph0 has been enabled [64]set pll end [67]unknow PMU [69]unknow PMU [73]PMU: AXP1530 [77]dram return write ok [80]board init ok [81]DRAM BOOT DRIVE INFO: V0.651 [85]the chip id is 0x2000 [87]chip id check OK [98]DRAM_VCC set to 1100 mv [101]DRAM CLK =792 MHZ [103]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [114]Actual DRAM SIZE =4096 M [117]DRAM SIZE =4096 MBytes, para1 = 310a, para2 = 10001000, dram_tpr13 = 2006c61 [130]DRAM simple test OK. [133]rtc standby flag is 0x0, super standby flag is 0x0 [138]dram size =4096 [141]Use rtc to store dram tuning para [146]spinor id is: 5e 40 18, read cmd: 0b [150]Succeed in reading toc file head. [154]The size of toc is 9c000. [317]Entry_name = u-boot [322]Entry_name = monitor [326]Entry_name = dtb [330]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):05d6c57 NOTICE: BL3-1: Built : 13:35:35, 2021-10-28 NOTICE: BL3-1 commit: 8 NOTICE: cpuidle init version V2.0 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3<FF> U-Boot 2018.05 (Jul 10 2023 - 10:32:18 +0800) Allwinner Technology [00.408]CPU: Allwinner Family [00.411]Model: sun50iw9 I2C: ready [00.415]DRAM: 2 GiB [00.419]Relocation Offset is: 75f5d000 [00.439]secure enable bit: 0 [00.441]pmu_axp152_probe pmic_bus_read fail [00.445]PMU: AXP1530 [00.451]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.457]gic: sec monitor mode [00.462]flash init start [00.464]workmode = 0,storage type = 3 SF: Detected zb25vq128as with page size 256 Bytes, erase size 64 KiB, total 16 MiB [00.481]sunxi flash init ok [00.485]Loading Environment from SUNXI_FLASH... OK [00.514]get secure storage map err [00.517]sunxi secure storage is not supported [00.521]usb burn from boot delay time 0 weak:otg_phy_config [00.535]usb prepare ok [53]HELLO! BOOT0 is starting! [56]BOOT0 commit : 3ae35eb [59]set pll start [61]periph0 has been enabled [64]set pll end [67]unknow PMU [69]unknow PMU [73]PMU: AXP1530 [77]dram return write ok [80]board init ok [81]DRAM BOOT DRIVE INFO: V0.651 [85]the chip id is 0x2000 [87]chip id check OK [98]DRAM_VCC set to 1100 mv [100]DRAM CLK =792 MHZ [103]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [114]Actual DRAM SIZE =4096 M [117]DRAM SIZE =4096 MBytes, para1 = 310a, para2 = 10001000, dram_tpr13 = 2006c61 [130]DRAM simple test OK. [133]rtc standby flag is 0x0, super standby flag is 0x0 [138]dram size =4096 [141]Use rtc to store dram tuning para [146]spinor id is: 5e 40 18, read cmd: 0b [150]Succeed in reading toc file head. [154]The size of toc is 9c000. [312]Entry_name = u-boot [317]Entry_name = monitor [321]Entry_name = dtb [325]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):05d6c57 NOTICE: BL3-1: Built : 13:35:35, 2021-10-28 NOTICE: BL3-1 commit: 8 NOTICE: cpuidle init version V2.0 ERROR: Error initializing runtime service tspd_fast NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3<FF> U-Boot 2018.05 (Jul 10 2023 - 10:32:18 +0800) Allwinner Technology [00.403]CPU: Allwinner Family [00.406]Model: sun50iw9 I2C: ready [00.410]DRAM: 2 GiB [00.413]Relocation Offset is: 75f5d000 [00.434]secure enable bit: 0 [00.436]pmu_axp152_probe pmic_bus_read fail [00.440]PMU: AXP1530 [00.445]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz [00.452]gic: sec monitor mode [00.457]flash init start [00.459]workmode = 0,storage type = 3 SF: Detected zb25vq128as with page size 256 Bytes, erase size 64 KiB, total 16 MiB [00.476]sunxi flash init ok [00.480]Loading Environment from SUNXI_FLASH... OK [00.509]get secure storage map err [00.512]sunxi secure storage is not supported [00.516]usb burn from boot delay time 0 weak:otg_phy_config [00.530]usb prepare ok [01.333]overtime [01.337]do_burn_from_boot usb : no usb exist [01.341]get secure storage map err [01.344]secure storage init fail [01.349]update dts [01.353]update part info [01.357]update bootcmd [01.359]No ethernet found. Hit any key to stop autoboot: 0 Android's image name: sun50i_arm64 [04.895]Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.9.170 (orangepi@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #15 SMP PREEMPT Thu Jun 29 17:36:03 CST 2023 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] bootconsole [earlycon0] enabled On the HDMI output I have an error that it can't find initramfs, which is probably expected since there's no SD card present.
