Crst Posted March 29, 2019 Posted March 29, 2019 INFOS: Armbian Bionic mainline kernel 4.19.20 System: OrangePi Pc Monitor, full HD (1920*1080), over HDMI. SOLUTION, ROTATE SCREEN: My rotation Settings that i try: 1. xrandr (not permanently, only for this session) 2. echo n > /sys/class/graphics/fbcon/rotate_all n=0,1,2,3 (permanently solution) See: http://linux-sunxi.org/Display <-Point:Rotation PROBLEM: Screen rotation problem: On every boot the rotation is correctly applied BUT: Turn Monitor off an then on again, the rotation is NOT applied. PROBLEM SINCE : Quarterly update cycle, until november 2018 everything works fine and i did not have this problem. QUESTION: Is this still the right way rotate the screen, or is there a different/new way. Whats happend, that the Screen is not rotated after switching on again, how to solve it?
062621AM Posted April 4, 2019 Posted April 4, 2019 Try this: /etc/X11/xorg.conf.d/01-armbian-defaults.conf Section "Monitor" Identifier "HDMI-1" Option "Rotate" "normal" EndSection normal(0)/right(90)/inverted(180)/left(270) Reference: https://www.x.org/archive/current/doc/man/man5/xorg.conf.5.xhtml
Crst Posted April 4, 2019 Author Posted April 4, 2019 Hey thanks, I added the rotation option to the X11 config but the problem still exists... Here a Screenshot what xrand say before and after turning the Screen off and on. Someone another solution ?
