pkfox Posted April 12, 2019 Posted April 12, 2019 I received one of these https://www.servercase.co.uk/shop/server-cases/rackmount-case-accessories/accessories-spare-parts/supermicro-cse-m14tqc-cse-m14tqc/ today to go with the Nanopi M4 SATa hat, it has a male Molex for input power, the SATA hat has a male Molex power outlet so I need a female to female Molex connector which I can't find anywhere - any ideas guys ?
pfry Posted April 12, 2019 Posted April 12, 2019 Found one: https://www.infinitecables.com/power-cables/internal-pc-power-cables/12-inch-lp4-female-to-lp4-female-internal-power-cable/ The linked site is unfamiliar, so caveat emptor. Search term (e.g.) was "lp4 cable f-f"; you may find other parts/sources. I'd verify the pinout before application. If you're careful (or you have the factory tool) you can dismount the contacts from the housing(s) and re-order them. Naturally, you can build your own as well.
pkfox Posted April 12, 2019 Author Posted April 12, 2019 9 minutes ago, pfry said: Found one: https://www.infinitecables.com/power-cables/internal-pc-power-cables/12-inch-lp4-female-to-lp4-female-internal-power-cable/ The linked site is unfamiliar, so caveat emptor. Search term (e.g.) was "lp4 cable f-f"; you may find other parts/sources. I'd verify the pinout before application. If you're careful (or you have the factory tool) you can dismount the contacts from the housing(s) and re-order them. Naturally, you can build your own as well. Dat's da bunny but I'm in the UK !
pkfox Posted April 12, 2019 Author Posted April 12, 2019 21 minutes ago, pfry said: Found one: https://www.infinitecables.com/power-cables/internal-pc-power-cables/12-inch-lp4-female-to-lp4-female-internal-power-cable/ The linked site is unfamiliar, so caveat emptor. Search term (e.g.) was "lp4 cable f-f"; you may find other parts/sources. I'd verify the pinout before application. If you're careful (or you have the factory tool) you can dismount the contacts from the housing(s) and re-order them. Naturally, you can build your own as well. Doesn't look like they ship to the UK either - thanks for trying
