Pine H64 model A - emmc boot stuck - sunxi-mmc 4022000.mmc: data error, sending stop command
U-Boot SPL 2019.01-armbian (Apr 08 2019 - 01:44:37 +0200)
DRAM: 4096 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.1(debug):8a08e27
NOTICE:  BL31: Built : 00:11:54, Apr  5 2019
NOTICE:  BL31: Detected Allwinner H6 SoC (1728)
NOTICE:  BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64
INFO:    ARM GICv2 driver initialized
NOTICE:  PMIC: Probing AXP805
NOTICE:  PMIC: AXP805 detected
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing!
WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing!
WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing!
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2019.01-armbian (Apr 08 2019 - 01:44:37 +0200) Allwinner Technology
CPU:   Allwinner H6 (SUN50I)
Model: Pine H64
DRAM:  3 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
Loading Environment from FAT... Unable to use mmc 1:1... In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   No ethernet found.
starting USB...
No controllers found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3042 bytes read in 27 ms (109.4 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
165 bytes read in 23 ms (6.8 KiB/s)
26173 bytes read in 91 ms (280.3 KiB/s)
4161 bytes read in 104 ms (39.1 KiB/s)
Applying kernel provided DT fixup script (sun50i-h6-fixup.scr)
## Executing script at 44000000
8711420 bytes read in 911 ms (9.1 MiB/s)
14436360 bytes read in 1492 ms (9.2 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    8711356 Bytes = 8.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 497b1000, end 49fffcbc ... OK
   reserving fdt memory region: addr=4fa00000 size=6c000
   Loading Device Tree to 0000000049742000, end 00000000497b0fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.0.7-sunxi64 (root@nightly) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.78.190413 SMP Sat Apr 13 01:24:27 CEST 2019
[    0.000000] Machine model: Pine H64
[    0.000000] cma: Reserved 128 MiB at 0x00000000f8000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf79d9840-0xf79dafff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0xa8/0x3f0 with crng_init=0
[    0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52952 r8192 d28968 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 774144
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=ebfa02c2-3f5d-4b27-bb44-1efd898b9c6f rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 panic=10 consoleblank=0 loglevel=7 ubootpart=3ec23de2-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=memory swapaccount=1
[    0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes
[    0.000000] printk: log_buf_len min size: 16384 bytes
[    0.000000] printk: log_buf_len: 32768 bytes
[    0.000000] printk: early log buf free: 13808(84%)
[    0.000000] Memory: 2935272K/3145728K available (10238K kernel code, 722K rwdata, 2504K rodata, 576K init, 288K bss, 79384K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000217] Console: colour dummy device 80x25
[    0.000553] printk: console [tty1] enabled
[    0.000625] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000646] pid_max: default: 32768 minimum: 301
[    0.000734] LSM: Security Framework initializing
[    0.000751] AppArmor: AppArmor disabled by boot time parameter
[    0.002318] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.003113] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.003170] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003222] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.004461] ASID allocator initialised with 32768 entries
[    0.004540] rcu: Hierarchical SRCU implementation.
[    0.005051] smp: Bringing up secondary CPUs ...
[    0.005739] Detected VIPT I-cache on CPU1
[    0.005788] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.006370] Detected VIPT I-cache on CPU2
[    0.006398] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.006960] Detected VIPT I-cache on CPU3
[    0.006987] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.007050] smp: Brought up 1 node, 4 CPUs
[    0.007102] SMP: Total of 4 processors activated.
[    0.007113] CPU features: detected: 32-bit EL0 Support
[    0.007124] CPU features: detected: CRC32 instructions
[    0.007371] CPU: All CPU(s) started at EL2
[    0.007393] alternatives: patching kernel code
[    0.008954] devtmpfs: initialized
[    0.013510] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.013560] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.017717] xor: measuring software checksum speed
[    0.056091]    8regs     :  1750.000 MB/sec
[    0.096130]    32regs    :  2151.000 MB/sec
[    0.136174]    arm64_neon:  1907.000 MB/sec
[    0.136185] xor: using function: 32regs (2151.000 MB/sec)
[    0.136249] pinctrl core: initialized pinctrl subsystem
[    0.136976] NET: Registered protocol family 16
[    0.137437] audit: initializing netlink subsys (disabled)
[    0.137584] audit: type=2000 audit(0.136:1): state=initialized audit_enabled=0 res=1
[    0.138029] cpuidle: using governor menu
[    0.138264] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.138282] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.139376] DMA: preallocated 256 KiB pool for atomic allocations
[    0.139468] Serial: AMBA PL011 UART driver
[    0.149330] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.149356] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.149369] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.149381] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.149822] cryptd: max_cpu_qlen set to 1000
[    0.216341] raid6: neonx8   gen()  1254 MB/s
[    0.284427] raid6: neonx8   xor()  1169 MB/s
[    0.352541] raid6: neonx4   gen()  1157 MB/s
[    0.420582] raid6: neonx4   xor()  1103 MB/s
[    0.488732] raid6: neonx2   gen()   887 MB/s
[    0.556760] raid6: neonx2   xor()   924 MB/s
[    0.624888] raid6: neonx1   gen()   553 MB/s
[    0.692966] raid6: neonx1   xor()   654 MB/s
[    0.761112] raid6: int64x8  gen()   749 MB/s
[    0.829153] raid6: int64x8  xor()   572 MB/s
[    0.897257] raid6: int64x4  gen()   792 MB/s
[    0.965358] raid6: int64x4  xor()   583 MB/s
[    1.033505] raid6: int64x2  gen()   517 MB/s
[    1.101545] raid6: int64x2  xor()   460 MB/s
[    1.169663] raid6: int64x1  gen()   337 MB/s
[    1.237700] raid6: int64x1  xor()   339 MB/s
[    1.237711] raid6: using algorithm neonx8 gen() 1254 MB/s
[    1.237720] raid6: .... xor() 1169 MB/s, rmw enabled
[    1.237730] raid6: using neon recovery algorithm
[    1.238696] SCSI subsystem initialized
[    1.238860] usbcore: registered new interface driver usbfs
[    1.238904] usbcore: registered new interface driver hub
[    1.238971] usbcore: registered new device driver usb
[    1.239201] pps_core: LinuxPPS API ver. 1 registered
[    1.239213] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.239240] PTP clock support registered
[    1.240232] clocksource: Switched to clocksource arch_sys_counter
[    1.240365] VFS: Disk quotas dquot_6.6.0
[    1.240427] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.245916] NET: Registered protocol family 2
[    1.246431] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[    1.246548] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.246906] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.247417] TCP: Hash tables configured (established 32768 bind 32768)
[    1.247551] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.247666] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.247900] NET: Registered protocol family 1
[    1.248327] RPC: Registered named UNIX socket transport module.
[    1.248340] RPC: Registered udp transport module.
[    1.248350] RPC: Registered tcp transport module.
[    1.248359] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.248577] Unpacking initramfs...
[    1.685538] Freeing initrd memory: 8504K
[    1.836446] Initialise system trusted keyrings
[    1.836621] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    1.841274] zbud: loaded
[    1.842544] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.843194] NFS: Registering the id_resolver key type
[    1.843223] Key type id_resolver registered
[    1.843232] Key type id_legacy registered
[    1.843248] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.843260] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.844039] 9p: Installing v9fs 9p2000 file system support
[    1.973624] NET: Registered protocol family 38
[    1.976426] Key type asymmetric registered
[    1.976448] Asymmetric key parser 'x509' registered
[    1.976512] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    1.976697] io scheduler mq-deadline registered
[    1.976710] io scheduler kyber registered
[    1.976862] io scheduler bfq registered
[    1.977130] sun50i-de2-bus 1000000.display-engine: Error couldn't map SRAM to device
[    1.977707] sun4i-usb-phy 5100400.phy: Couldn't get regulator usb0_vbus... Deferring probe
[    1.978024] sun50i-usb3-phy 5210000.phy: failed to get phy clock
[    1.981505] sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    1.988477] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.991290] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.995246] loop: module loaded
[    1.996215] libphy: Fixed MDIO Bus: probed
[    1.997736] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.997753] ehci-platform: EHCI generic platform driver
[    1.997902] ehci-platform 5101000.usb: EHCI Host Controller
[    1.997942] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
[    1.998235] ehci-platform 5101000.usb: irq 18, io mem 0x05101000
[    2.012241] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[    2.012438] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00
[    2.012457] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.012472] usb usb1: Product: EHCI Host Controller
[    2.012484] usb usb1: Manufacturer: Linux 5.0.7-sunxi64 ehci_hcd
[    2.012497] usb usb1: SerialNumber: 5101000.usb
[    2.012939] hub 1-0:1.0: USB hub found
[    2.012977] hub 1-0:1.0: 1 port detected
[    2.013478] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.013506] ohci-platform: OHCI generic platform driver
[    2.013640] ohci-platform 5101400.usb: Generic Platform OHCI controller
[    2.013665] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
[    2.013900] ohci-platform 5101400.usb: irq 19, io mem 0x05101400
[    2.076546] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.00
[    2.076565] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.076580] usb usb2: Product: Generic Platform OHCI controller
[    2.076593] usb usb2: Manufacturer: Linux 5.0.7-sunxi64 ohci_hcd
[    2.076606] usb usb2: SerialNumber: 5101400.usb
[    2.076990] hub 2-0:1.0: USB hub found
[    2.077034] hub 2-0:1.0: 1 port detected
[    2.077777] usbcore: registered new interface driver usb-storage
[    2.078187] mousedev: PS/2 mouse device common for all mice
[    2.078613] sun6i-rtc 7000000.rtc: registered as rtc0
[    2.078627] sun6i-rtc 7000000.rtc: RTC enabled
[    2.078690] i2c /dev entries driver
[    2.078874] sun50i-h6-r-pinctrl 7022000.pinctrl: 7022000.pinctrl supply vcc-pl not found, using dummy regulator
[    2.078941] sun50i-h6-r-pinctrl 7022000.pinctrl: Linked as a consumer to regulator.0
[    2.079399] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[    2.084709] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input0
[    2.085832] dcdca: supplied by regulator-dummy
[    2.086864] dcdcc: supplied by regulator-dummy
[    2.087453] dcdcd: supplied by regulator-dummy
[    2.087925] vdd-sys: Bringing 900000uV into 960000-960000uV
[    2.088386] dcdce: supplied by regulator-dummy
[    2.088965] aldo1: supplied by regulator-dummy
[    2.089542] aldo2: supplied by regulator-dummy
[    2.090013] vcc-ac200: Bringing 700000uV into 3300000-3300000uV
[    2.090457] aldo3: supplied by regulator-dummy
[    2.090907] vcc-3v3-1: Bringing 700000uV into 3300000-3300000uV
[    2.091658] bldo1: supplied by regulator-dummy
[    2.092650] bldo2: supplied by regulator-dummy
[    2.093250] bldo3: supplied by regulator-dummy
[    2.093697] vcc-wifi-io: Bringing 700000uV into 1800000-1800000uV
[    2.094445] bldo4: supplied by regulator-dummy
[    2.095046] cldo1: supplied by regulator-dummy
[    2.095648] cldo2: supplied by regulator-dummy
[    2.096099] vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
[    2.096864] cldo3: supplied by regulator-dummy
[    2.097315] vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
[    2.098072] sw: supplied by regulator-dummy
[    2.098237] axp20x-i2c 0-0036: AXP20X driver loaded
[    2.098956] sun50i-h6-r-pinctrl 7022000.pinctrl: 7022000.pinctrl supply vcc-pm not found, using dummy regulator
[    2.099179] sdhci: Secure Digital Host Controller Interface driver
[    2.099190] sdhci: Copyright(c) Pierre Ossman
[    2.099221] Synopsys Designware Multimedia Card Interface Driver
[    2.099715] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.100332] ledtrig-cpu: registered to indicate activity on CPUs
[    2.100612] hidraw: raw HID events driver (C) Jiri Kosina
[    2.100709] usbcore: registered new interface driver usbhid
[    2.100720] usbhid: USB HID core driver
[    2.101896] NET: Registered protocol family 10
[    2.122205] Segment Routing with IPv6
[    2.122311] NET: Registered protocol family 17
[    2.122485] 8021q: 802.1Q VLAN Support v1.8
[    2.122645] 9pnet: Installing 9P2000 support
[    2.122708] Key type dns_resolver registered
[    2.123319] registered taskstats version 1
[    2.123330] Loading compiled-in X.509 certificates
[    2.123414] zswap: loaded using pool lzo/zbud
[    2.124468] Btrfs loaded, crc32c=crc32c-generic
[    2.132812] Key type encrypted registered
[    2.141659] sun4i-usb-phy 5100400.phy: Linked as a consumer to regulator.18
[    2.142065] phy phy-5210000.phy.2: Linked as a consumer to regulator.18
[    2.146273] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    2.146547] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-ph not found, using dummy regulator
[    2.146622] sun50i-h6-pinctrl 300b000.pinctrl: Linked as a consumer to regulator.0
[    2.146978] printk: console [ttyS0] disabled
[    2.167755] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 15, base_baud = 1500000) is a 16550A
[    3.523441] printk: console [ttyS0] enabled
[    3.529347] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff000010b27968)
[    3.537053] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff000010b2bb50)
[    3.545126] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff000010b24450)
[    3.553550] sun8i-dw-hdmi 6000000.hdmi: 6000000.hdmi supply hvcc not found, using dummy regulator
[    3.562468] sun8i-dw-hdmi 6000000.hdmi: Linked as a consumer to regulator.0
[    3.569623] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[    3.579698] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.587432] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff000010b26d20)
[    3.594923] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.601539] [drm] No driver support for vblank timestamp query.
[    3.607712] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    3.615499] [drm] Cannot find any crtc or sizes
[    3.620514] [drm] Cannot find any crtc or sizes
[    3.732493] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    3.738005] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
[    3.746122] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010
[    3.755562] xhci-hcd xhci-hcd.2.auto: irq 20, io mem 0x05200000
[    3.761778] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00
[    3.770052] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.777280] usb usb3: Product: xHCI Host Controller
[    3.782165] usb usb3: Manufacturer: Linux 5.0.7-sunxi64 xhci-hcd
[    3.788176] usb usb3: SerialNumber: xhci-hcd.2.auto
[    3.793456] hub 3-0:1.0: USB hub found
[    3.797243] hub 3-0:1.0: 1 port detected
[    3.801418] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    3.806921] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4
[    3.814591] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0  SuperSpeed
[    3.821269] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.829481] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.00
[    3.837755] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.844983] usb usb4: Product: xHCI Host Controller
[    3.849868] usb usb4: Manufacturer: Linux 5.0.7-sunxi64 xhci-hcd
[    3.855880] usb usb4: SerialNumber: xhci-hcd.2.auto
[    3.861084] hub 4-0:1.0: USB hub found
[    3.864866] hub 4-0:1.0: 1 port detected
[    3.869483] ehci-platform 5311000.usb: EHCI Host Controller
[    3.875081] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 5
[    3.883152] ehci-platform 5311000.usb: irq 21, io mem 0x05311000
[    3.904247] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[    3.910494] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00
[    3.918769] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.925999] usb usb5: Product: EHCI Host Controller
[    3.930884] usb usb5: Manufacturer: Linux 5.0.7-sunxi64 ehci_hcd
[    3.936897] usb usb5: SerialNumber: 5311000.usb
[    3.941785] hub 5-0:1.0: USB hub found
[    3.945569] hub 5-0:1.0: 1 port detected
[    3.950068] ohci-platform 5311400.usb: Generic Platform OHCI controller
[    3.956707] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6
[    3.964662] ohci-platform 5311400.usb: irq 22, io mem 0x05311400
[    4.032502] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.00
[    4.040777] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.048006] usb usb6: Product: Generic Platform OHCI controller
[    4.053933] usb usb6: Manufacturer: Linux 5.0.7-sunxi64 ohci_hcd
[    4.059944] usb usb6: SerialNumber: 5311400.usb
[    4.064842] hub 6-0:1.0: USB hub found
[    4.068691] hub 6-0:1.0: 1 port detected
[    4.073372] usb_phy_generic usb_phy_generic.3.auto: usb_phy_generic.3.auto supply vcc not found, using dummy regulator
[    4.084148] usb_phy_generic usb_phy_generic.3.auto: Linked as a consumer to regulator.0
[    4.092422] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
[    4.098181] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 7
[    4.106177] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00
[    4.114455] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.121685] usb usb7: Product: MUSB HDRC host driver
[    4.126657] usb usb7: Manufacturer: Linux 5.0.7-sunxi64 musb-hcd
[    4.132669] usb usb7: SerialNumber: musb-hdrc.4.auto
[    4.138302] hub 7-0:1.0: USB hub found
[    4.142094] hub 7-0:1.0: 1 port detected
[    4.146906] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pf not found, using dummy regulator
[    4.157036] sunxi-mmc 4020000.mmc: Linked as a consumer to regulator.14
[    4.164240] sunxi-mmc 4020000.mmc: Got CD GPIO
[    4.194041] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    4.203554] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pg not found, using dummy regulator
[    4.213654] sunxi-mmc 4021000.mmc: Linked as a consumer to regulator.15
[    4.220336] sunxi-mmc 4021000.mmc: Linked as a consumer to regulator.11
[    4.227513] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[    4.266788] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.276590] mmc0: Problem switching card into high-speed mode!
[    4.282516] mmc0: new SDHC card at address 0001
[    4.287236] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    4.294557] mmcblk0: mmc0:0001 SD 29.1 GiB
[    4.298922] usb 5-1: new high-speed USB device number 2 using ehci-platform
[    4.307381]  mmcblk0: p1
[    4.312427] random: fast init done
[    4.460245] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    4.469819] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pc not found, using dummy regulator
[    4.479943] sunxi-mmc 4022000.mmc: Linked as a consumer to regulator.14
[    4.486608] sunxi-mmc 4022000.mmc: Linked as a consumer to regulator.11
[    4.500271] usb 3-1: New USB device found, idVendor=148f, idProduct=3070, bcdDevice= 1.01
[    4.508471] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.515615] usb 3-1: Product: 802.11 n WLAN
[    4.519810] usb 3-1: Manufacturer: Ralink
[    4.523828] usb 3-1: SerialNumber: 1.0
[    4.540270] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    4.549450] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-01T00:00:09 UTC (9)
[    4.557507] of_cfs_init
[    4.560034] of_cfs_init: OK
[    4.563017] vcc3v3: disabling
[    4.565996] vcc1v8: disabling
[    4.568978] vdd-gpu: disabling
[    4.572697] Freeing unused kernel memory: 576K
[    4.588281] Run /init as init process
[    4.664320] mmc2: new DDR MMC card at address 0001
[    4.670421] mmcblk2: mmc2:0001 NCard  14.5 GiB
[    4.675813] mmcblk2boot0: mmc2:0001 NCard  partition 1 4.00 MiB
[    4.682544] mmcblk2boot1: mmc2:0001 NCard  partition 2 4.00 MiB
[    4.689552]  mmcblk2: p1
[    4.720051] sunxi-mmc 4022000.mmc: data error, sending stop command
[    4.726460] sunxi-mmc 4022000.mmc: send stop command failed
[    4.732785] sunxi-mmc 4022000.mmc: data error, sending stop command
[    5.736234] sunxi-mmc 4022000.mmc: send stop command failed
Pine H64 model A fails to boot with emmc being plugged in.
"sunxi-mmc 4022000.mmc: data error, sending stop command"
followed by
"sunxi-mmc 4022000.mmc: send stop command failed"
On 8/23/2019 at 8:48 PM, hexdump said:
@kissste - there is a good chance, that this patch will fix your problem too - for me it fixed the emmc problems - see
tx6 i can not boot or reboot, this solution to fix it, but i know to do this, pls guide me to patch for eMMC from this comment below
On 8/23/2019 at 1:25 AM, jernej said:
@hexdump Can you test this patch for eMMC? https://pastebin.com/XeUbuWGG (kindly provided by Alexis3D from #linux-sunxi).
thx.
Edited by tongexhispeed@gmail.com
edit link
can you tell me step by step how you use the patch to solve error mmc tx6,,because i have same froblem with you
@hikmat - you'll have to build your own kernel and apply the patch from
maybe @balbes150 can include it into his arm64 kernel (in case he does not have it included yet) - did you try to boot any of his arm64 images?
best wishes - hexdump
