kgoerbig Posted April 16, 2019 Share Posted April 16, 2019 I have a Orange PI PC Plus that isn't booting either from sd or emmc. I had really messed up some configuration, so I erased emmc. After I erased EMMC, I started to get this boot screen. https://photos.app.goo.gl/EbJX43eSATyqTEau8 If I insert a sd card in with the latest Armbian, I get no boot screen, or activity at all. In fact, even if I format the card, and insert it into the OP+ it gets no boot activity. It is only after that I remove the card that it can then boot from usb flash. I ended up writing the latest orangepiplus image to a usb flash drive, and am able to get it to boot via a flash drive. I did backup my microsd install a few months ago with clonezilla. When I boot via USB, and run armbian-config there are no options for EMMC now. Basically, I need a little instruction of how to to get the OP+ to boot from micro sd again. https://photos.app.goo.gl/1WZDoYZLuPMnYhLC9 root@orangepipcplus:~# blkid /dev/mmcblk1p1: LABEL="emmc" UUID="19962a0d-5650-4f65-849d-8ecbafdfe67c" TYPE="ext4" PARTUUID="34dc0819-01" /dev/zram0: LABEL="log2ram" UUID="eec54a38-cb53-4031-b1b4-f606ca2bd7a8" TYPE="ext4" /dev/mmcblk1: PTUUID="34dc0819" PTTYPE="dos" /dev/sda1: UUID="d8699223-136d-4b8c-a25f-94e77a5b6ab3" TYPE="ext4" PARTUUID="a139e8b2-01" /dev/zram1: UUID="54a87408-738f-4f75-820a-1f51f87a3202" TYPE="swap" /dev/zram2: UUID="df462624-f671-4951-a0cd-ab0a9eafb089" TYPE="swap" /dev/zram3: UUID="0940ee89-bc6e-47ca-a587-67e2144ce3e5" TYPE="swap" /dev/zram4: UUID="7dc622a1-55af-4efb-a77b-9f81358ebbb7" TYPE="swap" Link to comment Share on other sites More sharing options...
Tido Posted April 16, 2019 Share Posted April 16, 2019 Did you read this and give it a try? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb Link to comment Share on other sites More sharing options...
