DoubleHP Posted April 27, 2019 Posted April 27, 2019 What's the difference between gtf and cvt ? # gtf 800 480 60 # 800x480 @ 60.00 Hz (GTF) hsync: 29.82 kHz; pclk: 29.58 MHz Modeline "800x480_60.00" 29.58 800 816 896 992 480 481 484 497 -HSync +Vsync cvt 800 480 60 # 800x480 59.48 Hz (CVT) hsync: 29.74 kHz; pclk: 29.50 MHz Modeline "800x480_60.00" 29.50 800 824 896 992 480 483 493 500 -hsync +vsync # xrandr --newmode "800x480_50.00" 24.50 800 824 896 992 480 483 493 497 -hsync +vsync xrandr: Failed to get size of gamma for output default root@orangepione:~# xrandr --addmode "default" 800x480_50.00 xrandr: Failed to get size of gamma for output default xrandr: cannot find mode "800x480_50.00" # xrandr xrandr: Failed to get size of gamma for output default Screen 0: minimum 1280 x 720, current 1280 x 720, maximum 1280 x 720 default connected 1280x720+0+0 0mm x 0mm 1280x720 0.00* How to addmode 800x480 ? BOARD_NAME="Orange Pi One" Image: Armbian_5.75_Orangepione_Ubuntu_xenial_default_3.4.113_desktop.7z I have a correct image using a 3.5" HDMI LCD (without using GPIO/SPI at all); but when I plug a 5" or 19", they say "no signal". I am surprised by two facts: - pi unable to probe monitors correctly over HDMI - 5" LCD designed for rPi unable to accept a modline the opi sends (a modline that is 100% acceptable for the 3.5").
DoubleHP Posted May 3, 2019 Author Posted May 3, 2019 I have completely reinstalled the system. Beh ... I don't understand the difference. image: Armbian_5.75_Orangepione_Debian_stretch_next_4.19.20.7z BOARD_NAME="Orange Pi One" BOARDFAMILY=sun8i VERSION=5.75 PRETTY_NAME="Debian GNU/Linux 9 (stretch)" NAME="Debian GNU/Linux" VERSION_ID="9" VERSION="9 (stretch)" ID=debian Linux opi55 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:02:47 CET 2019 armv7l GNU/Linux # aptitude install rcconf sqlite3 sed awk bc munin-node netcat bc socat facter xinit xserver-xor g-video-all xserver-xorg-video-fbdev xinit xserver-xorg-video-all xserver-xorg-video-fbdev aterm xterm wmaker eterm xfonts-base xserver-xorg x11-utils x11-xserver-utils xinput-calibrator xinput dillo munin-plugins-extra zip # startx & # export DISPLAY=":0.0" # cvt 800 480 50 # 800x480 49.69 Hz (CVT) hsync: 24.70 kHz; pclk: 24.50 MHz Modeline "800x480_50.00" 24.50 800 824 896 992 480 483 493 497 -hsync +vsync # xrandr --addmode "HDMI-1" 800x480_50.00 # cvt 800 480 60 # 800x480 59.48 Hz (CVT) hsync: 29.74 kHz; pclk: 29.50 MHz Modeline "800x480_60.00" 29.50 800 824 896 992 480 483 493 500 -hsync +vsync # xrandr --newmode "800x480_60.00" 29.50 800 824 896 992 480 483 493 500 -hsync +vsync # xrandr Screen 0: minimum 320 x 200, current 1280 x 720, maximum 8192 x 8192 HDMI-1 connected primary 1280x720+0+0 (normal left inverted right x axis y axis) 697mm x 392mm 1280x720 60.00*+ 50.00 59.94 1920x1080 60.00 50.00 59.94 1920x1080i 60.00 50.00 59.94 1280x1024 75.02 1440x900 74.98 59.90 1024x768 75.03 70.07 60.00 800x600 72.19 75.00 60.32 56.25 720x576 50.00 720x480 60.00 59.94 640x480 75.00 72.81 60.00 59.94 720x400 70.08 800x480_50.00 49.69 800x480_60.00 (0x6d) 29.500MHz -HSync +VSync h: width 800 start 824 end 896 total 992 skew 0 clock 29.74KHz v: height 480 start 483 end 493 total 500 clock 59.48Hz # xrandr --addmode "HDMI-1" 800x480_60.00 # xrandr -s 800x480_50.00 # xrandr --output HDMI-1 --mode 800x480_60.00 Both last commands work ... do not return error. With the 3.5" LCD, in all 3 cases, I have an image (not fitting edges, but that's offtopic). And now my 19" monitor also works, but with a trick: - run xrandr to have an eye at things - unplug old monitor - run xrandr to have an eye at things, and check that less resolutions are listed (the only ones left are the current one, and the two manually added ones) - plug monitor; it may not produce any image - ask xrandr again to show supported resolutions - run xrandr -s to set any resolution, even the current one, and then, an image will appear. 5" LCD also worked immediately. So, the main difference I can see between the two attemps is the image used, and kernel. 3.4 vs 4.19
Igor Posted May 4, 2019 Posted May 4, 2019 On 5/3/2019 at 10:27 PM, DoubleHP said: 3.4 vs 4.19 Expand Support in modern kernel was made virtually from scratch. There is little in common between 3.4.y and 4.19.y 1
