Hello Guys ,
I have ordered Micro SD Card Breakout for Exporting UART and JTAG Pins to get serial output on the SD card port without making any welding on the box.
I have test it and it seems to work. The problem is that the output is some king of unreadable characters.
I don't know whether it is a config issue or something else ?
Does any one have used the UART over SD port ?
did you try differen Baud rate's?
In telecommunication and electronics, baud is a common measure of symbol rate, one of the components that determine the speed of communication over a data channel.
You didn't provided links about such breakout ...
I presume you had to load specific driver ?
  • Werner locked this topic
