pkfox Posted May 6, 2019 Posted May 6, 2019 Hi all, I'm trying to get Bluetooth working with the M4 ( installed it via armbian-config ) but on checking the status I see this Quote /etc/init.d/bluetooth status ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: inactive (dead) Condition: start condition failed at Mon 2019-05-06 08:09:12 BST; 14min ago └─ ConditionPathIsDirectory=/sys/class/bluetooth was not met Docs: man:bluetoothd(8)
Tido Posted May 6, 2019 Posted May 6, 2019 I see, and what did you do to investigate it, where, why does it get stuck? Did you also try the image for NanoPi M4 - FriendlyElec?
pkfox Posted May 7, 2019 Author Posted May 7, 2019 18 hours ago, Tido said: I see, and what did you do to investigate it, where, why does it get stuck? Did you also try the image for NanoPi M4 - FriendlyElec? As this is the Armbian forum why would I try another distro ? it's failing because /sys/class/bluetoth doesn't exist but I don't know why
Tido Posted May 7, 2019 Posted May 7, 2019 to narrow the cause... Well, you would see if it works what modules are installed/loaded, which kernel, try switching the DeviceTree (dtb). And finally come back with your findings, to support development.
