Chaton Pascal Posted May 11, 2019 Posted May 11, 2019 Hi, Perhaps it is documented elsewhere but I could not find a direct solution after googling few minutes. My u-boot partition was stuck at the same version on the nightly. I needed to fix the reboot issue. I've tried few things like apt upgrade or direct dpkg -i... Anyway, this is what I did on a EMMC installation (/dev/mmcblk2) after I've built and download my own version of the package: dpkg -i ./linux-u-boot-dev-orangepi3_5.86_arm64.deb cd /usr/lib/linux-u-boot-dev-orangepi3_5.86_arm64 cat sunxi-spl.bin u-boot.itb > u-boot-sunxi-with-spl.bin dd if=u-boot-sunxi-with-spl.bin of=/dev/mmcblk2 bs=1024 seek=8 reboot I'm my case I had to unplug it and replug... (broken reboot). The new version is now installed : U-Boot 2019.04-armbian (May 11 2019 - 08:05:18 -0400) Reboot works, and now it has a fixed mac addr (new feature).
Igor Posted May 11, 2019 Posted May 11, 2019 All boards have the same procedure for updating u-boot, but we are behind with updating documentation ... armbian-config -> system -> install to eMMC/USB/... -> "Update U-boot" 2
