What i have so far:
1 sd card, with Armbian Bionic image, flashed with Etcher
2 Orange Pi PC connected to PC through usb to serial converter
And my problem is:
Orange pi pc tries to boot for few times and stuck
log from putty:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.05.12 12:00:43 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot SPL 2019.04-armbian (May 04 2019 - 02:06:03 +0200)
DRAM: 1024 MiB
Trying to boot from MMC1
U-Boot 2019.04-armbian (May 04 2019 - 02:06:03 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC
DRAM:  1 GiB
MMC:   mmc@1c0f000: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
230454 bytes read in 12 ms (18.3 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
USB6:   USB EHCI 1.00
USB7:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
scanning bus 5 for devices... 1 USB Device(s) found
scanning bus 6 for devices... 1 USB Device(s) found
scanning bus 7 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3585 bytes read in 1 ms (3.4 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
152 bytes read in 1 ms (148.4 KiB/s)
7989481 bytes read in 385 ms (19.8 MiB/s)
7489576 bytes read in 361 ms (19.8 MiB/s)
29890 bytes read in 9 ms (3.2 MiB/s)
4155 bytes read in 6 ms (675.8 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    7989417 Bytes = 7.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
EHCI failed to shut down host controller.
   Loading Ramdisk to 49861000, end 49fff8a9 ... OK
   Loading Device Tree to 497f1000, end 49860fff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.38-sunxi (root@nightly) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.83 SMP Fri May 3 23:33:25 CEST 2019
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Xunlong Orange Pi PC
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 128 MiB at 0x75c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] random: get_random_bytes called from start_kernel+0x8d/0x3c6 with crng_init=0
[    0.000000] percpu: Embedded 18 pages/cpu s41548 r8192 d23988 u73728
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
[    0.000000] Kernel command line: root=UUID=792dc3df-48f8-4101-9640-3a9c73ec438b rootwait rootfstype=ext4  hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=7 ubootpart=dfcbd449-01 ubootsource=mmc usb-storage.quirks=   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 1048576 bytes of page_ext
[    0.000000] Memory: 883148K/1048576K available (9216K kernel code, 1004K rwdata, 2576K rodata, 1024K init, 331K bss, 34356K reserved, 131072K cma-reserved, 131060K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   (1005 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 332 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 39959 entries in 79 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000017] Switching to timer-based delay loop, resolution 41ns
[    0.000176] Console: colour dummy device 80x30
[    0.000651] console [tty0] enabled
[    0.000705] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000733] pid_max: default: 32768 minimum: 301
[    0.000935] Security Framework initialized
[    0.000957] AppArmor: AppArmor disabled by boot time parameter
[    0.001039] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001062] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001898] CPU: Testing write buffer coherency: ok
[    0.002330] CPU0: update cpu_capacity 1024
[    0.002352] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002831] Setting up static identity map for 0x40100000 - 0x40100054
[    0.002992] rcu: Hierarchical SRCU implementation.
[    0.003718] smp: Bringing up secondary CPUs ...
[    0.014480] CPU1: update cpu_capacity 1024
[    0.014486] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.025271] CPU2: update cpu_capacity 1024
[    0.025276] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.035990] CPU3: update cpu_capacity 1024
[    0.035995] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.036088] smp: Brought up 1 node, 4 CPUs
[    0.036173] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.036188] CPU: All CPU(s) started in HYP mode.
[    0.036200] CPU: Virtualization extensions available.
[    0.037374] devtmpfs: initialized
[    0.043851] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.044080] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.044116] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.048803] xor: measuring software checksum speed
[    0.087949]    arm4regs  :  1255.000 MB/sec
[    0.128010]    8regs     :   748.000 MB/sec
[    0.168072]    32regs    :   766.000 MB/sec
[    0.208133]    neon      :  1270.000 MB/sec
[    0.208147] xor: using function: neon (1270.000 MB/sec)
[    0.208221] pinctrl core: initialized pinctrl subsystem
[    0.209139] NET: Registered protocol family 16
[    0.211505] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.211990] audit: initializing netlink subsys (disabled)
[    0.212185] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[    0.212688] cpuidle: using governor ladder
[    0.212732] cpuidle: using governor menu
[    0.213225] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.213248] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.296639] raid6: int32x1  gen()   189 MB/s
[    0.364561] raid6: int32x1  xor()   160 MB/s
[    0.432591] raid6: int32x2  gen()   255 MB/s
[    0.500658] raid6: int32x2  xor()   194 MB/s
[    0.568805] raid6: int32x4  gen()   258 MB/s
[    0.636935] raid6: int32x4  xor()   193 MB/s
[    0.704932] raid6: int32x8  gen()   247 MB/s
[    0.773158] raid6: int32x8  xor()   172 MB/s
[    0.841186] raid6: neonx1   gen()   495 MB/s
[    0.909233] raid6: neonx1   xor()   460 MB/s
[    0.977380] raid6: neonx2   gen()   664 MB/s
[    1.045464] raid6: neonx2   xor()   594 MB/s
[    1.113587] raid6: neonx4   gen()   798 MB/s
[    1.181645] raid6: neonx4   xor()   669 MB/s
[    1.249731] raid6: neonx8   gen()   716 MB/s
[    1.317833] raid6: neonx8   xor()   606 MB/s
[    1.317848] raid6: using algorithm neonx4 gen() 798 MB/s
[    1.317861] raid6: .... xor() 669 MB/s, rmw enabled
[    1.317875] raid6: using neon recovery algorithm
[    1.319243] SCSI subsystem initialized
[    1.319663] usbcore: registered new interface driver usbfs
[    1.319718] usbcore: registered new interface driver hub
[    1.319800] usbcore: registered new device driver usb
[    1.319984] media: Linux media interface: v0.10
[    1.320028] videodev: Linux video capture interface: v2.00
[    1.320204] pps_core: LinuxPPS API ver. 1 registered
[    1.320221] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.320255] PTP clock support registered
[    1.321790] clocksource: Switched to clocksource arch_sys_counter
[    1.424912] VFS: Disk quotas dquot_6.6.0
[    1.425014] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.432567] NET: Registered protocol family 2
[    1.433287] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    1.433337] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.433438] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    1.433562] TCP: Hash tables configured (established 8192 bind 8192)
[    1.433684] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.433756] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.434054] NET: Registered protocol family 1
[    1.434541] RPC: Registered named UNIX socket transport module.
[    1.434563] RPC: Registered udp transport module.
[    1.434576] RPC: Registered tcp transport module.
[    1.434589] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.434842] Trying to unpack rootfs image as initramfs...
[    1.887420] Freeing initrd memory: 7804K
[    1.889166] Initialise system trusted keyrings
[    1.889417] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.895121] zbud: loaded
[    1.897191] NFS: Registering the id_resolver key type
[    1.897234] Key type id_resolver registered
[    1.897247] Key type id_legacy registered
[    1.897269] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.897285] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.898452] JFS: nTxBlock = 7984, nTxLock = 63876
[    1.907241] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    1.914828] Key type asymmetric registered
[    1.914862] Asymmetric key parser 'x509' registered
[    1.914937] bounce: pool size: 64 pages
[    1.915002] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.915185] io scheduler noop registered
[    1.915204] io scheduler deadline registered
[    1.915421] io scheduler cfq registered (default)
[    1.915441] io scheduler mq-deadline registered
[    1.915455] io scheduler kyber registered
[    1.915597] io scheduler bfq registered
[    1.916711] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    1.920600] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    1.922206] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    1.970597] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.992940] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A
[    2.881215] console [ttyS0] enabled
[    2.908035] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a85d08)
[    2.915201] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a83454)
[    2.922936] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
[    2.931878] sun8i-dw-hdmi 1ee0000.hdmi: Linked as a consumer to regulator.0
[    2.939600] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    2.949462] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.957217] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8578c)
[    2.964029] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.970655] [drm] No driver support for vblank timestamp query.
[    2.976637] [drm] Cannot find any crtc or sizes
[    2.981616] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    2.992265] brd: module loaded
[    3.000758] loop: module loaded
[    3.006254] libphy: Fixed MDIO Bus: probed
[    3.010930] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    3.016735] dwmac-sun8i 1c30000.ethernet: No regulator found
[    3.022737] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[    3.032174] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    3.039414] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    3.046652] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    3.051631] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    3.058431] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    3.064102] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    3.069898] libphy: stmmac: probed
[    3.073738] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    3.079946] libphy: mdio_mux: probed
[    3.083555] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    3.089926] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    3.101286] libphy: mdio_mux: probed
[    3.105817] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.112361] ehci-platform: EHCI generic platform driver
[    3.117800] ehci-platform 1c1a000.usb: EHCI Host Controller
[    3.123411] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    3.131854] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    3.153807] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    3.160188] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.168486] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.175724] usb usb1: Product: EHCI Host Controller
[    3.180613] usb usb1: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.186632] usb usb1: SerialNumber: 1c1a000.usb
[    3.191743] hub 1-0:1.0: USB hub found
[    3.195567] hub 1-0:1.0: 1 port detected
[    3.200358] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.206585] ohci-platform: OHCI generic platform driver
[    3.211988] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    3.218633] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    3.226550] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    3.294035] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.302328] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.309567] usb usb2: Product: Generic Platform OHCI controller
[    3.315499] usb usb2: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    3.321517] usb usb2: SerialNumber: 1c1a400.usb
[    3.326499] hub 2-0:1.0: USB hub found
[    3.330314] hub 2-0:1.0: 1 port detected
[    3.335405] usbcore: registered new interface driver usb-storage
[    3.342181] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    3.348998] sun6i-rtc 1f00000.rtc: RTC enabled
[    3.353651] i2c /dev entries driver
[    3.359111] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    3.367714] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
[    3.374740] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    3.379476] ledtrig-cpu: registered to indicate activity on CPUs
[    3.385570] hidraw: raw HID events driver (C) Jiri Kosina
[    3.391096] usbcore: registered new interface driver usbhid
[    3.396686] usbhid: USB HID core driver
[    3.404505] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    3.406827] Initializing XFRM netlink socket
[    3.416419] NET: Registered protocol family 10
[    3.438421] Segment Routing with IPv6
[    3.442235] NET: Registered protocol family 17
[    3.446719] NET: Registered protocol family 15
[    3.451242] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.464269] 8021q: 802.1Q VLAN Support v1.8
[    3.468761] Key type dns_resolver registered
[    3.473473] Registering SWP/SWPB emulation handler
[    3.478835] registered taskstats version 1
[    3.482969] Loading compiled-in X.509 certificates
[    3.487874] zswap: loaded using pool lzo/zbud
[    3.494034] Btrfs loaded, crc32c=crc32c-generic
[    3.502557] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.506892] Key type encrypted registered
[    3.514467] mmc0: new high speed SDHC card at address aaaa
[    3.521536] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[    3.523739] sun4i-usb-phy 1c19400.phy: Linked as a consumer to regulator.4
[    3.534018] ehci-platform 1c1b000.usb: EHCI Host Controller
[    3.534684]  mmcblk0: p1
[    3.539645] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    3.550387] ehci-platform 1c1b000.usb: irq 28, io mem 0x01c1b000
[    3.569793] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    3.576107] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.584393] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.591628] usb usb3: Product: EHCI Host Controller
[    3.596520] usb usb3: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.602538] usb usb3: SerialNumber: 1c1b000.usb
[    3.607596] hub 3-0:1.0: USB hub found
[    3.611414] hub 3-0:1.0: 1 port detected
[    3.616147] ehci-platform 1c1c000.usb: EHCI Host Controller
[    3.621785] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[    3.629756] ehci-platform 1c1c000.usb: irq 30, io mem 0x01c1c000
[    3.649807] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    3.656106] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.664394] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.671632] usb usb4: Product: EHCI Host Controller
[    3.676523] usb usb4: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.682541] usb usb4: SerialNumber: 1c1c000.usb
[    3.687516] hub 4-0:1.0: USB hub found
[    3.691316] hub 4-0:1.0: 1 port detected
[    3.695960] ehci-platform 1c1d000.usb: EHCI Host Controller
[    3.701575] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[    3.709518] ehci-platform 1c1d000.usb: irq 32, io mem 0x01c1d000
[    3.729805] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    3.736082] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.744368] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.751605] usb usb5: Product: EHCI Host Controller
[    3.756496] usb usb5: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.762514] usb usb5: SerialNumber: 1c1d000.usb
[    3.767509] hub 5-0:1.0: USB hub found
[    3.771324] hub 5-0:1.0: 1 port detected
[    3.775955] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    3.782608] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    3.790540] ohci-platform 1c1b400.usb: irq 29, io mem 0x01c1b400
[    3.858004] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.866292] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.873527] usb usb6: Product: Generic Platform OHCI controller
[    3.879460] usb usb6: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    3.885478] usb usb6: SerialNumber: 1c1b400.usb
[    3.890763] hub 6-0:1.0: USB hub found
[    3.894573] hub 6-0:1.0: 1 port detected
[    3.899212] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    3.905870] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    3.913809] ohci-platform 1c1c400.usb: irq 31, io mem 0x01c1c400
[    3.981981] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.990269] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.997508] usb usb7: Product: Generic Platform OHCI controller
[    4.003442] usb usb7: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    4.009461] usb usb7: SerialNumber: 1c1c400.usb
[    4.014229] [drm] Cannot find any crtc or sizes
[    4.018986] hub 7-0:1.0: USB hub found
[    4.022795] hub 7-0:1.0: 1 port detected
[    4.027418] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    4.034084] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    4.042004] ohci-platform 1c1d400.usb: irq 33, io mem 0x01c1d400
[    4.109981] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    4.118268] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.125504] usb usb8: Product: Generic Platform OHCI controller
[    4.131437] usb usb8: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    4.137455] usb usb8: SerialNumber: 1c1d400.usb
[    4.142432] hub 8-0:1.0: USB hub found
[    4.146238] hub 8-0:1.0: 1 port detected
[    4.150914] usb_phy_generic usb_phy_generic.2.auto: usb_phy_generic.2.auto supply vcc not found, using dummy regulator
[    4.161715] usb_phy_generic usb_phy_generic.2.auto: Linked as a consumer to regulator.0
[    4.170047] musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
[    4.175823] musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 9
[    4.183878] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    4.192172] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.199410] usb usb9: Product: MUSB HDRC host driver
[    4.204388] usb usb9: Manufacturer: Linux 4.19.38-sunxi musb-hcd
[    4.210406] usb usb9: SerialNumber: musb-hdrc.3.auto
[    4.215783] hub 9-0:1.0: USB hub found
[    4.219597] hub 9-0:1.0: 1 port detected
[    4.224515] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01 00:00:18 UTC (18)
[    4.232729] of_cfs_init
[    4.235278] of_cfs_init: OK
[    4.238238] vcc3v0: disabling
[    4.241212] vcc5v0: disabling
[    4.244194] usb0-vbus: disabling
[    4.251124] Freeing unused kernel memory: 1024K
[    4.265981] Run /init as init process
Loading, please wait...
starting version 237
done.
Begin: Will now check root file system ... fsck from util-linux 2.31.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: recovering journal
[    5.453145] random: fast init done
/dev/mmcblk0p1: clean, 35989/56896 files, 192523/227328 blocks
done.
[    5.503611] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
done.
[    6.069742] systemd[1]: System time before build time, advancing clock.
[    6.117366] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    6.139147] systemd[1]: Detected architecture arm.
Welcome to [1mUbuntu 18.04.2 LTS[0m!
[    6.166696] systemd[1]: Set hostname to <orangepipc>.
[    6.721752] random: systemd: uninitialized urandom read (16 bytes read)
[    6.729130] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[[0;32m  OK  [0m] Set up automount Arbitrary Executab…rmats File System Automount Point.
[    6.757965] random: systemd: uninitialized urandom read (16 bytes read)
[    6.764681] systemd[1]: Reached target Swap.
[[0;32m  OK  [0m] Reached target Swap.
[    6.781904] random: systemd: uninitialized urandom read (16 bytes read)
[    6.789475] systemd[1]: Created slice User and Session Slice.
[[0;32m  OK  [0m] Created slice User and Session Slice.
[    6.806177] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[[0;32m  OK  [0m] Started Dispatch Password Requests to Console Directory Watch.
[    6.830048] systemd[1]: Started ntp-systemd-netif.path.
[[0;32m  OK  [0m] Started ntp-systemd-netif.path.
[    6.845972] systemd[1]: Reached target Remote File Systems.
[[0;32m  OK  [0m] Reached target Remote File Systems.
[    6.862693] systemd[1]: Created slice System Slice.
[[0;32m  OK  [0m] Created slice System Slice.
[[0;32m  OK  [0m] Listening on Journal Socket (/dev/log).
[[0;32m  OK  [0m] Listening on fsck to fsckd communication Socket.
[[0;32m  OK  [0m] Listening on Journal Audit Socket.
[[0;32m  OK  [0m] Created slice system-serial\x2dgetty.slice.
[[0;32m  OK  [0m] Reached target Slices.
[[0;32m  OK  [0m] Listening on Syslog Socket.
[[0;32m  OK  [0m] Listening on /dev/initctl Compatibility Named Pipe.
[[0;32m  OK  [0m] Reached target System Time Synchronized.
[[0;32m  OK  [0m] Listening on Journal Socket.
         Starting Journal Service...
         Mounting POSIX Message Queue File System...
         Starting Nameserver information manager...
         Starting Create list of required st…ce nodes for the current kernel...
         Starting Load Kernel Modules...
         Starting Set the console keyboard layout...
         Mounting Kernel Debug File System...
[[0;32m  OK  [0m] Started Forward Password Requests to Wall Directory Watch.
[[0;32m  OK  [0m] Reached target Local Encrypted Volumes.
         Starting Remount Root and Kernel File Systems...
         Starting Restore / save the current clock...
[[0;32m  OK  [0m] Listening on udev Kernel Socket.
[    7.196592] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[[0;32m  OK  [0m] Listening on udev Control Socket.
         Starting udev Coldplug all Devices...
[[0;32m  OK  [0m] Started Journal Service.
[[0;32m  OK  [0m] Mounted POSIX Message Queue File System.
[[0;32m  OK  [0m] Started Create list of required sta…vice nodes for the current kernel.
[[0;32m  OK  [0m] Started Load Kernel Modules.
[[0;32m  OK  [0m] Mounted Kernel Debug File System.
[[0;32m  OK  [0m] Started Remount Root and Kernel File Systems.
[[0;32m  OK  [0m] Started Restore / save the current clock.
[[0;32m  OK  [0m] Started Nameserver information manager.
[[0;32m  OK  [0m] Reached target Network (Pre).
         Starting Load/Save Random Seed...
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
[[0;32m  OK  [0m] Started Set the console keyboard layout.
[[0;32m  OK  [0m] Started Load/Save Random Seed.
[[0;32m  OK  [0m] Started Apply Kernel Variables.
[[0;32m  OK  [0m] Mounted Kernel Configuration File System.
[[0;32m  OK  [0m] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[[0;32m  OK  [0m] Reached target Local File Systems (Pre).
         Mounting /tmp...
[[0;32m  OK  [0m] Mounted /tmp.
[[0;32m  OK  [0m] Reached target Local File Systems.
         Starting Set console font and keymap...
         Starting Raise network interfaces...
         Starting Armbian ZRAM config...
[[0;32m  OK  [0m] Started udev Kernel Device Manager.
[[0;32m  OK  [0m] Started Flush Journal to Persistent Storage.
[[0;32m  OK  [0m] Started Set console font and keymap.
         Starting Create Volatile Files and Directories...
[[0;32m  OK  [0m] Started udev Coldplug all Devices.
[[0;32m  OK  [0m] Started Create Volatile Files and Directories.
DRAM: 1024 MiB
DRAM:  1 GiB
MMC:   mmc@1c0f000: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
USB6:   USB EHCI 1.00
USB7:   USB OHCI 1.0
Scanning mmc 0:1...
29890 bytes read in 8 ms (3.6 MiB/s)
   Image Name:   uInitrd
Starting kernel ...
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000175] Console: colour dummy device 80x30
[    0.000638] console [tty0] enabled
[    0.000692] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000719] pid_max: default: 32768 minimum: 301
[    0.000922] Security Framework initialized
[    0.000946] AppArmor: AppArmor disabled by boot time parameter
[    0.001029] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001052] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001883] CPU: Testing write buffer coherency: ok
[    0.002307] CPU0: update cpu_capacity 1024
[    0.002329] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002807] Setting up static identity map for 0x40100000 - 0x40100054
[    0.002975] rcu: Hierarchical SRCU implementation.
[    0.003713] smp: Bringing up secondary CPUs ...
[    0.014481] CPU1: update cpu_capacity 1024
[    0.014487] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.025268] CPU2: update cpu_capacity 1024
[    0.025273] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.035987] CPU3: update cpu_capacity 1024
[    0.035993] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.036086] smp: Brought up 1 node, 4 CPUs
[    0.036171] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.036186] CPU: All CPU(s) started in HYP mode.
[    0.036197] CPU: Virtualization extensions available.
[    0.037377] devtmpfs: initialized
[    0.043854] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.044084] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.044118] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.048784] xor: measuring software checksum speed
[    0.087947]    arm4regs  :  1255.000 MB/sec
[    0.128007]    8regs     :   748.000 MB/sec
[    0.168068]    32regs    :   766.000 MB/sec
[    0.208130]    neon      :  1270.000 MB/sec
[    0.208144] xor: using function: neon (1270.000 MB/sec)
[    0.208217] pinctrl core: initialized pinctrl subsystem
[    0.209140] NET: Registered protocol family 16
[    0.211934] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.212450] audit: initializing netlink subsys (disabled)
[    0.212619] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[    0.213121] cpuidle: using governor ladder
[    0.213168] cpuidle: using governor menu
[    0.213660] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.213685] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.364543] raid6: int32x1  xor()   160 MB/s
[    0.432593] raid6: int32x2  gen()   255 MB/s
[    0.500646] raid6: int32x2  xor()   194 MB/s
[    0.568795] raid6: int32x4  gen()   258 MB/s
[    0.636923] raid6: int32x4  xor()   193 MB/s
[    0.704936] raid6: int32x8  gen()   247 MB/s
[    0.773152] raid6: int32x8  xor()   172 MB/s
[    0.841195] raid6: neonx1   gen()   495 MB/s
[    0.909213] raid6: neonx1   xor()   460 MB/s
[    0.977382] raid6: neonx2   gen()   664 MB/s
[    1.045429] raid6: neonx2   xor()   594 MB/s
[    1.113582] raid6: neonx4   gen()   798 MB/s
[    1.181647] raid6: neonx4   xor()   669 MB/s
[    1.249723] raid6: neonx8   gen()   716 MB/s
[    1.317829] raid6: neonx8   xor()   606 MB/s
[    1.317844] raid6: using algorithm neonx4 gen() 798 MB/s
[    1.317857] raid6: .... xor() 669 MB/s, rmw enabled
[    1.317870] raid6: using neon recovery algorithm
[    1.319241] SCSI subsystem initialized
[    1.319665] usbcore: registered new interface driver usbfs
[    1.319721] usbcore: registered new interface driver hub
[    1.319799] usbcore: registered new device driver usb
[    1.319981] media: Linux media interface: v0.10
[    1.320025] videodev: Linux video capture interface: v2.00
[    1.320201] pps_core: LinuxPPS API ver. 1 registered
[    1.320218] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.320253] PTP clock support registered
[    1.321781] clocksource: Switched to clocksource arch_sys_counter
[    1.424870] VFS: Disk quotas dquot_6.6.0
[    1.424968] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.432555] NET: Registered protocol family 2
[    1.433270] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    1.433319] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.433419] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    1.433542] TCP: Hash tables configured (established 8192 bind 8192)
[    1.433665] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.433737] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.434029] NET: Registered protocol family 1
[    1.434518] RPC: Registered named UNIX socket transport module.
[    1.434541] RPC: Registered udp transport module.
[    1.434554] RPC: Registered tcp transport module.
[    1.434567] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.434819] Trying to unpack rootfs image as initramfs...
[    1.887537] Freeing initrd memory: 7804K
[    1.889282] Initialise system trusted keyrings
[    1.889527] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.895237] zbud: loaded
[    1.897312] NFS: Registering the id_resolver key type
[    1.897358] Key type id_resolver registered
[    1.897372] Key type id_legacy registered
[    1.897393] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.897409] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.898578] JFS: nTxBlock = 7984, nTxLock = 63876
[    1.907371] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    1.914695] Key type asymmetric registered
[    1.914730] Asymmetric key parser 'x509' registered
[    1.914796] bounce: pool size: 64 pages
[    1.914861] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.915028] io scheduler noop registered
[    1.915046] io scheduler deadline registered
[    1.915252] io scheduler cfq registered (default)
[    1.915272] io scheduler mq-deadline registered
[    1.915285] io scheduler kyber registered
[    1.915413] io scheduler bfq registered
[    1.916541] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    1.920508] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    1.922060] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    1.969933] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.992284] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A
[    2.880540] console [ttyS0] enabled
[    2.907374] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a85d08)
[    2.914534] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a83454)
[    2.922269] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
[    2.931216] sun8i-dw-hdmi 1ee0000.hdmi: Linked as a consumer to regulator.0
[    2.938959] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    2.948820] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.956576] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8578c)
[    2.963389] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.970015] [drm] No driver support for vblank timestamp query.
[    2.975991] [drm] Cannot find any crtc or sizes
[    2.980964] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    2.991599] brd: module loaded
[    3.000049] loop: module loaded
[    3.005505] libphy: Fixed MDIO Bus: probed
[    3.010222] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    3.016026] dwmac-sun8i 1c30000.ethernet: No regulator found
[    3.022019] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[    3.031449] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    3.038686] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    3.045919] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    3.050897] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    3.057693] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    3.063361] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    3.069150] libphy: stmmac: probed
[    3.073030] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    3.079233] libphy: mdio_mux: probed
[    3.082844] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    3.089210] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    3.100588] libphy: mdio_mux: probed
[    3.105098] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.111647] ehci-platform: EHCI generic platform driver
[    3.117059] ehci-platform 1c1a000.usb: EHCI Host Controller
[    3.122671] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    3.131155] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    3.149796] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    3.156158] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.164459] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.171697] usb usb1: Product: EHCI Host Controller
[    3.176589] usb usb1: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.182608] usb usb1: SerialNumber: 1c1a000.usb
[    3.187740] hub 1-0:1.0: USB hub found
[    3.191568] hub 1-0:1.0: 1 port detected
[    3.196335] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.202576] ohci-platform: OHCI generic platform driver
[    3.207971] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    3.214617] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    3.222537] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    3.290051] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.298345] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.305584] usb usb2: Product: Generic Platform OHCI controller
[    3.311516] usb usb2: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    3.317533] usb usb2: SerialNumber: 1c1a400.usb
[    3.322546] hub 2-0:1.0: USB hub found
[    3.326378] hub 2-0:1.0: 1 port detected
[    3.331512] usbcore: registered new interface driver usb-storage
[    3.338314] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    3.345135] sun6i-rtc 1f00000.rtc: RTC enabled
[    3.349811] i2c /dev entries driver
[    3.355265] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    3.363878] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
[    3.370915] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    3.375643] ledtrig-cpu: registered to indicate activity on CPUs
[    3.381739] hidraw: raw HID events driver (C) Jiri Kosina
[    3.387281] usbcore: registered new interface driver usbhid
[    3.392874] usbhid: USB HID core driver
[    3.400677] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    3.402990] Initializing XFRM netlink socket
[    3.412641] NET: Registered protocol family 10
[    3.434207] Segment Routing with IPv6
[    3.438024] NET: Registered protocol family 17
[    3.442513] NET: Registered protocol family 15
[    3.447026] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.460037] 8021q: 802.1Q VLAN Support v1.8
[    3.464514] Key type dns_resolver registered
[    3.469205] Registering SWP/SWPB emulation handler
[    3.474592] registered taskstats version 1
[    3.478729] Loading compiled-in X.509 certificates
[    3.483638] zswap: loaded using pool lzo/zbud
[    3.489881] Btrfs loaded, crc32c=crc32c-generic
[    3.502728] Key type encrypted registered
[    3.514748] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.523795] sun4i-usb-phy 1c19400.phy: Linked as a consumer to regulator.4
[    3.531662] ehci-platform 1c1b000.usb: EHCI Host Controller
[    3.537287] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    3.545320] mmc0: new high speed SDHC card at address aaaa
[    3.551999] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[    3.557034] ehci-platform 1c1b000.usb: irq 28, io mem 0x01c1b000
[    3.564497]  mmcblk0: p1
[    3.577790] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    3.584117] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.592415] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.599653] usb usb3: Product: EHCI Host Controller
[    3.604546] usb usb3: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.610565] usb usb3: SerialNumber: 1c1b000.usb
[    3.615569] hub 3-0:1.0: USB hub found
[    3.619375] hub 3-0:1.0: 1 port detected
[    3.624159] ehci-platform 1c1c000.usb: EHCI Host Controller
[    3.629794] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[    3.637908] ehci-platform 1c1c000.usb: irq 30, io mem 0x01c1c000
[    3.657793] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    3.664094] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.672381] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.679618] usb usb4: Product: EHCI Host Controller
[    3.684510] usb usb4: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.690529] usb usb4: SerialNumber: 1c1c000.usb
[    3.695516] hub 4-0:1.0: USB hub found
[    3.699321] hub 4-0:1.0: 1 port detected
[    3.703967] ehci-platform 1c1d000.usb: EHCI Host Controller
[    3.709592] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[    3.717543] ehci-platform 1c1d000.usb: irq 32, io mem 0x01c1d000
[    3.737791] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    3.744074] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.752361] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.759596] usb usb5: Product: EHCI Host Controller
[    3.764488] usb usb5: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.770507] usb usb5: SerialNumber: 1c1d000.usb
[    3.775500] hub 5-0:1.0: USB hub found
[    3.779311] hub 5-0:1.0: 1 port detected
[    3.783933] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    3.790587] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    3.798502] ohci-platform 1c1b400.usb: irq 29, io mem 0x01c1b400
[    3.865991] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.874280] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.881515] usb usb6: Product: Generic Platform OHCI controller
[    3.887448] usb usb6: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    3.893466] usb usb6: SerialNumber: 1c1b400.usb
[    3.898759] hub 6-0:1.0: USB hub found
[    3.902562] hub 6-0:1.0: 1 port detected
[    3.907196] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    3.913857] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    3.921784] ohci-platform 1c1c400.usb: irq 31, io mem 0x01c1c400
[    3.989964] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.993839] [drm] Cannot find any crtc or sizes
[    3.998244] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.010013] usb usb7: Product: Generic Platform OHCI controller
[    4.015945] usb usb7: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    4.021963] usb usb7: SerialNumber: 1c1c400.usb
[    4.026955] hub 7-0:1.0: USB hub found
[    4.030762] hub 7-0:1.0: 1 port detected
[    4.035389] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    4.042045] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    4.050009] ohci-platform 1c1d400.usb: irq 33, io mem 0x01c1d400
[    4.117975] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    4.126266] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.133502] usb usb8: Product: Generic Platform OHCI controller
[    4.139436] usb usb8: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    4.145454] usb usb8: SerialNumber: 1c1d400.usb
[    4.150437] hub 8-0:1.0: USB hub found
[    4.154242] hub 8-0:1.0: 1 port detected
[    4.158927] usb_phy_generic usb_phy_generic.2.auto: usb_phy_generic.2.auto supply vcc not found, using dummy regulator
[    4.169705] usb_phy_generic usb_phy_generic.2.auto: Linked as a consumer to regulator.0
[    4.178022] musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
[    4.183801] musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 9
[    4.191857] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    4.200151] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.207390] usb usb9: Product: MUSB HDRC host driver
[    4.212367] usb usb9: Manufacturer: Linux 4.19.38-sunxi musb-hcd
[    4.218386] usb usb9: SerialNumber: musb-hdrc.3.auto
[    4.223772] hub 9-0:1.0: USB hub found
[    4.227589] hub 9-0:1.0: 1 port detected
[    4.232361] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01 00:00:40 UTC (40)
[    4.240582] of_cfs_init
[    4.243136] of_cfs_init: OK
[    4.246092] vcc3v0: disabling
[    4.249066] vcc5v0: disabling
[    4.252049] usb0-vbus: disabling
[    4.258974] Freeing unused kernel memory: 1024K
[    4.269970] Run /init as init process
done.
[    5.439227] random: fast init done
done.
[    5.529948] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
done.
[    6.096140] systemd[1]: System time before build time, advancing clock.
[    6.143815] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    6.165724] systemd[1]: Detected architecture arm.
[    6.194674] systemd[1]: Set hostname to <orangepipc>.
[    6.749138] random: systemd: uninitialized urandom read (16 bytes read)
[    6.756288] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.777990] random: systemd: uninitialized urandom read (16 bytes read)
[    6.785615] systemd[1]: Created slice System Slice.
[    6.801963] random: systemd: uninitialized urandom read (16 bytes read)
[    6.808665] systemd[1]: Reached target Swap.
[    6.826654] systemd[1]: Created slice User and Session Slice.
[    6.845916] systemd[1]: Reached target Slices.
[    6.862035] systemd[1]: Started ntp-systemd-netif.path.
[    6.878296] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.268552] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
         Mounting /tmp...
         Starting Network Name Resolution...
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
DRAM: 1024 MiB
DRAM:  1 GiB
MMC:   mmc@1c0f000: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
USB6:   USB EHCI 1.00
USB7:   USB OHCI 1.0
Scanning mmc 0:1...
   Image Name:   uInitrd
Starting kernel ...
[    0.000641] console [tty0] enabled
[    0.000694] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000722] pid_max: default: 32768 minimum: 301
[    0.000927] Security Framework initialized
[    0.000950] AppArmor: AppArmor disabled by boot time parameter
[    0.001032] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001056] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001891] CPU: Testing write buffer coherency: ok
[    0.002327] CPU0: update cpu_capacity 1024
[    0.002347] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002835] Setting up static identity map for 0x40100000 - 0x40100054
[    0.003003] rcu: Hierarchical SRCU implementation.
[    0.003739] smp: Bringing up secondary CPUs ...
[    0.014503] CPU1: update cpu_capacity 1024
[    0.014508] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.025291] CPU2: update cpu_capacity 1024
[    0.025296] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.036006] CPU3: update cpu_capacity 1024
[    0.036011] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.036104] smp: Brought up 1 node, 4 CPUs
[    0.036188] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.036202] CPU: All CPU(s) started in HYP mode.
[    0.036214] CPU: Virtualization extensions available.
[    0.037388] devtmpfs: initialized
[    0.043870] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.044095] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.044130] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.048810] xor: measuring software checksum speed
[    0.087966]    arm4regs  :  1255.000 MB/sec
[    0.128027]    8regs     :   748.000 MB/sec
[    0.168089]    32regs    :   766.000 MB/sec
[    0.208150]    neon      :  1270.000 MB/sec
[    0.208165] xor: using function: neon (1270.000 MB/sec)
[    0.208238] pinctrl core: initialized pinctrl subsystem
[    0.209160] NET: Registered protocol family 16
[    0.211525] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.212018] audit: initializing netlink subsys (disabled)
[    0.212214] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[    0.212721] cpuidle: using governor ladder
[    0.212767] cpuidle: using governor menu
[    0.213261] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.213284] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.296664] raid6: int32x1  gen()   189 MB/s
[    0.364577] raid6: int32x1  xor()   160 MB/s
[    0.432611] raid6: int32x2  gen()   255 MB/s
[    0.500683] raid6: int32x2  xor()   194 MB/s
[    0.568830] raid6: int32x4  gen()   258 MB/s
[    0.636961] raid6: int32x4  xor()   193 MB/s
[    0.704958] raid6: int32x8  gen()   247 MB/s
[    0.773175] raid6: int32x8  xor()   172 MB/s
[    0.841214] raid6: neonx1   gen()   495 MB/s
[    0.909264] raid6: neonx1   xor()   460 MB/s
[    0.977399] raid6: neonx2   gen()   664 MB/s
[    1.045463] raid6: neonx2   xor()   594 MB/s
[    1.113606] raid6: neonx4   gen()   798 MB/s
[    1.181655] raid6: neonx4   xor()   669 MB/s
[    1.249751] raid6: neonx8   gen()   716 MB/s
[    1.317853] raid6: neonx8   xor()   606 MB/s
[    1.317868] raid6: using algorithm neonx4 gen() 798 MB/s
[    1.317881] raid6: .... xor() 669 MB/s, rmw enabled
[    1.317895] raid6: using neon recovery algorithm
[    1.319256] SCSI subsystem initialized
[    1.319653] usbcore: registered new interface driver usbfs
[    1.319710] usbcore: registered new interface driver hub
[    1.319783] usbcore: registered new device driver usb
[    1.319965] media: Linux media interface: v0.10
[    1.320007] videodev: Linux video capture interface: v2.00
[    1.320136] pps_core: LinuxPPS API ver. 1 registered
[    1.320151] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.320228] PTP clock support registered
[    1.321746] clocksource: Switched to clocksource arch_sys_counter
[    1.424785] VFS: Disk quotas dquot_6.6.0
[    1.424889] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.432453] NET: Registered protocol family 2
[    1.433157] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    1.433205] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.433302] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    1.433426] TCP: Hash tables configured (established 8192 bind 8192)
[    1.433545] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.433621] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.433912] NET: Registered protocol family 1
[    1.434396] RPC: Registered named UNIX socket transport module.
[    1.434417] RPC: Registered udp transport module.
[    1.434430] RPC: Registered tcp transport module.
[    1.434443] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.434703] Trying to unpack rootfs image as initramfs...
[    1.887093] Freeing initrd memory: 7804K
[    1.888837] Initialise system trusted keyrings
[    1.889074] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.894777] zbud: loaded
[    1.896887] NFS: Registering the id_resolver key type
[    1.896927] Key type id_resolver registered
[    1.896941] Key type id_legacy registered
[    1.896962] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.896978] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.898132] JFS: nTxBlock = 7984, nTxLock = 63876
[    1.906901] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    1.914561] Key type asymmetric registered
[    1.914596] Asymmetric key parser 'x509' registered
[    1.914679] bounce: pool size: 64 pages
[    1.914767] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.914926] io scheduler noop registered
[    1.914943] io scheduler deadline registered
[    1.915148] io scheduler cfq registered (default)
[    1.915168] io scheduler mq-deadline registered
[    1.915182] io scheduler kyber registered
[    1.915319] io scheduler bfq registered
[    1.916425] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    1.920398] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    1.921967] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    1.970332] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.992678] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A
[    2.880952] console [ttyS0] enabled
[    2.907805] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a85d08)
[    2.914949] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a83454)
[    2.922681] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
[    2.931620] sun8i-dw-hdmi 1ee0000.hdmi: Linked as a consumer to regulator.0
[    2.939383] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    2.949235] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.956974] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8578c)
[    2.963785] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.970410] [drm] No driver support for vblank timestamp query.
[    2.976386] [drm] Cannot find any crtc or sizes
[    2.981338] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    2.991968] brd: module loaded
[    3.000451] loop: module loaded
[    3.005977] libphy: Fixed MDIO Bus: probed
[    3.010653] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    3.016458] dwmac-sun8i 1c30000.ethernet: No regulator found
[    3.022437] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[    3.031870] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    3.039113] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    3.046351] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    3.051329] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    3.058128] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    3.063799] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    3.069584] libphy: stmmac: probed
[    3.073472] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    3.079682] libphy: mdio_mux: probed
[    3.083290] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    3.089660] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    3.100987] libphy: mdio_mux: probed
[    3.105500] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.112046] ehci-platform: EHCI generic platform driver
[    3.117472] ehci-platform 1c1a000.usb: EHCI Host Controller
[    3.123092] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    3.131612] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    3.149755] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    3.156114] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.164408] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.171661] usb usb1: Product: EHCI Host Controller
[    3.176550] usb usb1: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.182568] usb usb1: SerialNumber: 1c1a000.usb
[    3.187661] hub 1-0:1.0: USB hub found
[    3.191482] hub 1-0:1.0: 1 port detected
[    3.196258] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.202495] ohci-platform: OHCI generic platform driver
[    3.207893] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    3.214540] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    3.222476] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    3.290011] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.298302] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.305541] usb usb2: Product: Generic Platform OHCI controller
[    3.311473] usb usb2: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    3.317492] usb usb2: SerialNumber: 1c1a400.usb
[    3.322521] hub 2-0:1.0: USB hub found
[    3.326376] hub 2-0:1.0: 1 port detected
[    3.331493] usbcore: registered new interface driver usb-storage
[    3.338310] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    3.345131] sun6i-rtc 1f00000.rtc: RTC enabled
[    3.349805] i2c /dev entries driver
[    3.355272] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    3.363906] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
[    3.370941] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    3.375668] ledtrig-cpu: registered to indicate activity on CPUs
[    3.381775] hidraw: raw HID events driver (C) Jiri Kosina
[    3.387301] usbcore: registered new interface driver usbhid
[    3.392892] usbhid: USB HID core driver
[    3.400696] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    3.403052] Initializing XFRM netlink socket
[    3.412633] NET: Registered protocol family 10
[    3.434361] Segment Routing with IPv6
[    3.438167] NET: Registered protocol family 17
[    3.442656] NET: Registered protocol family 15
[    3.447168] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.460172] 8021q: 802.1Q VLAN Support v1.8
[    3.464638] Key type dns_resolver registered
[    3.469328] Registering SWP/SWPB emulation handler
[    3.474705] registered taskstats version 1
[    3.478839] Loading compiled-in X.509 certificates
[    3.483764] zswap: loaded using pool lzo/zbud
[    3.490038] Btrfs loaded, crc32c=crc32c-generic
[    3.502759] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.502961] Key type encrypted registered
[    3.514993] mmc0: new high speed SDHC card at address aaaa
[    3.521985] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[    3.523914] sun4i-usb-phy 1c19400.phy: Linked as a consumer to regulator.4
[    3.534443] ehci-platform 1c1b000.usb: EHCI Host Controller
[    3.535133]  mmcblk0: p1
[    3.540066] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    3.550771] ehci-platform 1c1b000.usb: irq 28, io mem 0x01c1b000
[    3.569765] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    3.576095] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.584383] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.591617] usb usb3: Product: EHCI Host Controller
[    3.596509] usb usb3: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.602528] usb usb3: SerialNumber: 1c1b000.usb
[    3.607560] hub 3-0:1.0: USB hub found
[    3.611374] hub 3-0:1.0: 1 port detected
[    3.616096] ehci-platform 1c1c000.usb: EHCI Host Controller
[    3.621719] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[    3.629679] ehci-platform 1c1c000.usb: irq 30, io mem 0x01c1c000
[    3.649762] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    3.656042] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.664329] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.671566] usb usb4: Product: EHCI Host Controller
[    3.676458] usb usb4: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.682476] usb usb4: SerialNumber: 1c1c000.usb
[    3.687467] hub 4-0:1.0: USB hub found
[    3.691269] hub 4-0:1.0: 1 port detected
[    3.695896] ehci-platform 1c1d000.usb: EHCI Host Controller
[    3.701509] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[    3.709460] ehci-platform 1c1d000.usb: irq 32, io mem 0x01c1d000
[    3.729759] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    3.736035] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    3.744321] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.751557] usb usb5: Product: EHCI Host Controller
[    3.756449] usb usb5: Manufacturer: Linux 4.19.38-sunxi ehci_hcd
[    3.762467] usb usb5: SerialNumber: 1c1d000.usb
[    3.767438] hub 5-0:1.0: USB hub found
[    3.771241] hub 5-0:1.0: 1 port detected
[    3.775860] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    3.782523] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    3.790441] ohci-platform 1c1b400.usb: irq 29, io mem 0x01c1b400
[    3.857964] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.866252] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.873488] usb usb6: Product: Generic Platform OHCI controller
[    3.879421] usb usb6: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    3.885439] usb usb6: SerialNumber: 1c1b400.usb
[    3.890684] hub 6-0:1.0: USB hub found
[    3.894487] hub 6-0:1.0: 1 port detected
[    3.899100] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    3.905758] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    3.913671] ohci-platform 1c1c400.usb: irq 31, io mem 0x01c1c400
[    3.981931] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    3.990220] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.993810] [drm] Cannot find any crtc or sizes
[    3.997454] usb usb7: Product: Generic Platform OHCI controller
[    4.007916] usb usb7: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    4.013934] usb usb7: SerialNumber: 1c1c400.usb
[    4.018928] hub 7-0:1.0: USB hub found
[    4.022735] hub 7-0:1.0: 1 port detected
[    4.027366] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    4.034022] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    4.041951] ohci-platform 1c1d400.usb: irq 33, io mem 0x01c1d400
[    4.109935] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    4.118223] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.125459] usb usb8: Product: Generic Platform OHCI controller
[    4.131393] usb usb8: Manufacturer: Linux 4.19.38-sunxi ohci_hcd
[    4.137412] usb usb8: SerialNumber: 1c1d400.usb
[    4.142401] hub 8-0:1.0: USB hub found
[    4.146205] hub 8-0:1.0: 1 port detected
[    4.150881] usb_phy_generic usb_phy_generic.2.auto: usb_phy_generic.2.auto supply vcc not found, using dummy regulator
[    4.161657] usb_phy_generic usb_phy_generic.2.auto: Linked as a consumer to regulator.0
[    4.169985] musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
[    4.175761] musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 9
[    4.183816] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    4.192109] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.199347] usb usb9: Product: MUSB HDRC host driver
[    4.204325] usb usb9: Manufacturer: Linux 4.19.38-sunxi musb-hcd
[    4.210343] usb usb9: SerialNumber: musb-hdrc.3.auto
[    4.215737] hub 9-0:1.0: USB hub found
[    4.219546] hub 9-0:1.0: 1 port detected
[    4.224499] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01 00:01:02 UTC (62)
[    4.232720] of_cfs_init
[    4.235275] of_cfs_init: OK
[    4.238229] vcc3v0: disabling
[    4.241204] vcc5v0: disabling
[    4.244185] usb0-vbus: disabling
[    4.251114] Freeing unused kernel memory: 1024K
[    4.265941] Run /init as init process
done.
[    5.443556] random: fast init done
done.
[    5.485417] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
done.
[    6.052403] systemd[1]: System time before build time, advancing clock.
[    6.100005] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    6.121989] systemd[1]: Detected architecture arm.
[    6.150648] systemd[1]: Set hostname to <orangepipc>.
[    6.705934] random: systemd: uninitialized urandom read (16 bytes read)
[    6.713289] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.741978] random: systemd: uninitialized urandom read (16 bytes read)
[    6.748696] systemd[1]: Reached target Remote File Systems.
[    6.765856] random: systemd: uninitialized urandom read (16 bytes read)
[    6.772761] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.793903] systemd[1]: Reached target System Time Synchronized.
[    6.810815] systemd[1]: Created slice System Slice.
[    6.830263] systemd[1]: Listening on fsck to fsckd communication Socket.
[    6.850286] systemd[1]: Listening on Journal Socket.
[    7.213453] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
         Mounting /tmp...
[[0;32m  OK  [0m] Started Entropy daemon using the HAVEGE algorithm.
2 hours ago, vrs11 said:
sd card, with Armbian Bionic image, flashed with Etcher
Strange. Another SD card? Different brand, different PSU. Without anything attached to the board?
I can only confirm that my OPi PC+ boots without a problem. Don't have this exact board (Orangepi PC) to make sure.
Actualy, once it booted normaly, showde message that pc nesds to reboot, and than ends up with described problem
Let's wait for some other user report. I can't reproduce this.
