guidol Posted May 15, 2019 Posted May 15, 2019 Yesterday i did install Armbian_5.86_Aml-s905_Debian_buster_default_5.1.0_20190514.img from @balbes150 on my Sunvell T95KPro (S912). While installing Pihole the Installation does break when trying to start lighttpd. After checking with journalctl -u lighttpd it turns out that the file /usr/share/lighttpd/create-mime.assign.pl is missing, because in the newer lighttpd-version of debian buster the file has be renamed to /usr/share/lighttpd/create-mime.conf.pl (see also https://discourse.pi-hole.net/t/lighttpd-does-not-start/6207/11 ) Pihole doesnt know/use the new name with debian buster, so it fails to start the lighttpd So I did find 2 ways to resolve the problem. First (quick and dirty?) way: cp /usr/share/lighttpd/create-mime.conf.pl /usr/share/lighttpd/create-mime.assign.pl or ln -s /usr/share/lighttpd/create-mime.conf.pl /usr/share/lighttpd/create-mime.assign.pl read also:Pihole breaks lighttpd on Debian Buster #2557 https://github.com/pi-hole/pi-hole/issues/2557 the second way (found it at https://forum.kuketz-blog.de/viewtopic.php?t=3067 ) is to edit /etc/lighttpd/lighttpd.conf and search for the 2 following lines and comment them out (found the 2nd one at the end of the file): #include_shell "/usr/share/lighttpd/create-mime.assign.pl" #include_shell "cat external.conf 2>/dev/null" and add the follwoing line to the file: include_shell "/usr/share/lighttpd/create-mime.conf.pl" After saving the file you should be able to restart lighttpd via sudo /etc/init.d/lighttpd restart or sudo service lighttpd restart or sudo service lighttpd stop sudo service lighttpd start BUT second way does not work good with updating or repair-install of pihole, because I think this will set the config-file to the old state (also for server.error-handler-404) So maybe the first way will work better while pihole doenst know the new file-name - or you also can do both ways BTW: If you are experience a 400 Bad Request while only using the IP for getting to the Pihole-Webpage (and the redirect should ask you if you want to use the /admin page - but it doenst) then try the follwing small resolution - edit a line in the file /etc/lighttpd/lighttpd.conf from: server.error-handler-404 = "pihole/index.php" to: server.error-handler-404 = "/pihole/index.php" lighttpd.conf 2
renedis Posted June 19, 2019 Posted June 19, 2019 There is a new update from PiHole that should fix this issue.
Dan M Posted July 2, 2019 Posted July 2, 2019 (edited) On 6/19/2019 at 6:54 AM, renedis said: There is a new update from PiHole that should fix this issue. Although it (v.4.3.1) has been cited as fixing this issue I am still getting this error after a clean install 4.3.1. Strange. Edited July 2, 2019 by Dan M
guidol Posted July 26, 2019 Author Posted July 26, 2019 On 7/2/2019 at 12:49 PM, Dan M said: Although it (v.4.3.1) has been cited as fixing this issue I am still getting this error after a clean install 4.3.1. Strange. Today I gave buster a new try with pihole on my T95K Pro S912 TVBox. I compiled a actual version of debian buster for it (thanks to @balbes150): Debian Buster with Armbian Linux 5.3.0-rc1-next-20190726-aml-s912 package bsp-kernel[5.91] dtb[5.91] firmware[5.91] config[5.91] and started the pihole install via: curl -sSL https://install.pi-hole.net | bash The installation didnt broke like before with debian buster (no problem with lighttpd). In the middle of the installation I did get the following error-message between the installation-messages: [i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old iptables/1.8.2 Failed to initialize nft: Protocol not supported iptables/1.8.2 Failed to initialize nft: Protocol not supported Installation went fine, but I did search for the error and found the following page:https://gist.github.com/nickfox-taterli/fcddd0ac724ec066b51f8e777800fea2 The is listed that buster has as default now nftables and not xtables. The problem can be fixed with the following commands: sudo update-alternatives --set iptables /usr/sbin/iptables-legacy sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy This will set some new symbolic links ( to other symbolic links ) : ls -l /etc/alternatives/iptables lrwxrwxrwx 1 root root 25 Jul 26 15:42 /etc/alternatives/iptables -> /usr/sbin/iptables-legacy ls -l /usr/sbin/iptables-legacy lrwxrwxrwx 1 root root 20 Mar 1 15:28 /usr/sbin/iptables-legacy -> xtables-legacy-multi ls -l /etc/alternatives/ip6tables lrwxrwxrwx 1 root root 26 Jul 26 15:42 /etc/alternatives/ip6tables -> /usr/sbin/ip6tables-legacy ls -l /usr/sbin/ip6tables-legacy lrwxrwxrwx 1 root root 20 Mar 1 15:28 /usr/sbin/ip6tables-legacy -> xtables-legacy-multi Version is 4.3.1 (like the Pihole-team said the fixed the buster lighttpd problem): Pi-hole Version v4.3.1 Web Interface Version v4.3 FTL Version v4.3.1 But now it seems to work with buster BTW: for the redirect to the /admin page (400 Bad Request before) I also had to edit /etc/lighttpd/lighttpd.conf like before
guidol Posted September 12, 2019 Author Posted September 12, 2019 Today I did test to install pihole 4.3.1 on a Odroid C2 with Debian Buster with Armbian Linux 5.3.0-rc8-meson64 package bsp-kernel[5.96] u-boot[5.96] dtb[5.96] firmware[5.96] config[5.96] The installer did quit while setting up php (serveral times) So I did a apt upgrade and apt did complete to install 9 packages (including php). After that I restarted the pihole installer - he did found the php-installation and did install pihole FTLL an so on... and completed the installation successfully
guidol Posted September 16, 2019 Author Posted September 16, 2019 Pihole Core update to 4.3.2 https://github.com/pi-hole/pi-hole/releases also fixed: - Fix for 404 error when browsing to http://pi.hole/ (without /admin) #2826
guidol Posted January 20, 2020 Author Posted January 20, 2020 On 9/12/2019 at 1:14 PM, guidol said: The installer did quit while setting up php (serveral times) So I did a apt upgrade and apt did complete to install 9 packages (including php). After that I restarted the pihole installer - he did found the php-installation and did install pihole FTLL an so on... and completed the installation successfully Yesterday pihole 5.0 Beta was announced https://pi-hole.net/2020/01/19/announcing-a-beta-test-of-pi-hole-5-0/ As a test-device I took a NanoPi K1 Plus where I installed armbian bullseye kernel 5.5.0-rc6 and installed pihole 4.3.2 bullseye needs the same apt upgrade and second install restart, but installs pihole 4.3.2 successfully after the 4.3.2 installation I could update to the 5.0 Beta with echo "release/v5.0" | sudo tee /etc/pihole/ftlbranch pihole checkout core release/v5.0 pihole checkout web release/v5.0 5.0 Beta is now running on my test-system
guidol Posted April 19, 2020 Author Posted April 19, 2020 On 9/12/2019 at 1:14 PM, guidol said: The installer did quit while setting up php (serveral times) So I did a apt upgrade and apt did complete to install 9 packages (including php). After that I restarted the pihole installer - he did found the php-installation and did install pihole FTLL an so on... and completed the installation successfully additional information from another thread about dependencies:
guidol Posted May 16, 2020 Author Posted May 16, 2020 Pi-hole 5.0 is out of the BETA-Phase ! and has NO PROBLEMS to be installed on armbian focal ( System diagnosis information has been uploaded to http://ix.io/2mgt ) Just use: sudo apt install php-cgi php-common php php-sqlite3 -y && curl -sSL https://install.pi-hole.net | bash Pi-hole v5.0 is here! (2020-05-10 ) see: https://pi-hole.net/2020/05/10/pi-hole-v5-0-is-here/#page-content After a successful beta testing and development period (many thanks to the beta testers!), we are pleased to announce the release of 5.0 for general availability! Important notice (One-way-ticket) There are many fundamental changes between Pi-hole 4.x and 5.0 – as such, this is strictly a one way operation. Once you move from 4.x to 5.0, there is no way to go back; you will need to restore from a backup. Pi-hole 4.x to 5.0 To update to this new version from version 4.x, run pihole -up Pi-hole 5.0 BETA to new 5.0 release: If you have been running the 5.0 beta release, run pihole checkout master to move from the beta to the master branch. 1
