Gburas Posted May 22, 2019 Posted May 22, 2019 Hi, i have orangePi One with armbian ubuntu (updated up to day). I have this old one 11g wifi usb: Bus 003 Device 002: ID 0ace:1215 ZyDAS ZD1211B 802.11g i have tried to install firmware-zd1211 but there`s no package. i`m linux beginner so my knowledge end`s here, on forum i have tried to search info but unsuccessful Can anyone help me/point in to some direction? Will be grateful.
Igor Posted May 23, 2019 Posted May 23, 2019 16 hours ago, Gburas said: i have tried to install firmware-zd1211 but there`s no package. How you did? root@nanopifire3:~# apt install firmware-zd1211 Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: firmware-zd1211 0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded. Need to get 14.3 kB of archives. After this operation, 66.6 kB of additional disk space will be used. Get:1 http://cdn-fastly.deb.debian.org/debian stretch/non-free arm64 firmware-zd1211 all 1:1.5-4 [14.3 kB] Fetched 14.3 kB in 0s (43.5 kB/s) Selecting previously unselected package firmware-zd1211. (Reading database ... 32249 files and directories currently installed.) Preparing to unpack .../firmware-zd1211_1%3a1.5-4_all.deb ... Unpacking firmware-zd1211 (1:1.5-4) ... Setting up firmware-zd1211 (1:1.5-4) ... root@nanopifire3:~#
Gburas Posted May 23, 2019 Author Posted May 23, 2019 Thanks@Igor for answer, but as I mentioned I have Ubuntu and I assume You use Debian.Is it possible to just install package form Deb in Ubuntu? Or is it better just to flash Debian image?Wysłane z mojego Moto Z (2) przy użyciu Tapatalka
