Scan ssid by mobile phone the SSID can be seen . but always in password loop.
I've installed hostapd V2.7 and dnsmasq V2.79.  and wpa_supplicant and networkmanager are stopped.
The config files are as below:
1:  etc/hostapd/hostapd.conf
interface=wlan0
driver=nl80211
ssid=TinkerNet
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=3
wpa_passphrase=mypassphrase
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
2:/etc/dnsmasq.conf
interface=wlan0      # Use the require wireless interface - usually wlan0
dhcp-range=192.168.1.2,192.168.1.254,255.255.255.0,12h
Then I try armbian-config ...strange thing, there is not hotspot option in network. Anyone could explain how to config hotspot on Tinkerborad S with Ubuntu 18.04?
On 5/25/2019 at 5:00 PM, Kenji said:
wmm_enabled=0
macaddr_acl=0
auth_algs=1
wpa=3
I would guess wpa=2
There are also problems with older Phone Versions specially on Android. They have a problem sometime with the WPA2... Maybe you should try with a different phone or upgrade its firmware if you can...
Another hint is the Country code have you enabled on your armbian OS and the corresponding Channel which should meet to your Country settings and Phone Settings?
Hope this helps and you get this working
Roman
