I upgraded 4.13.16-sunxi to 4.19.47
Seems all went fine. but after reboot the former 4.13.16 kernel is still active.
My cubietruck runs sd-card+ssd with system moved to ssd by armbian-config.
Maybe the issue has to do with the sd-card/ssd booting sequence?
If I have the sd-card/ssd system up and running, will the sd-card be touched with later kernel upgrades too, or just the root system at ssd?
Holger
armbianmonitor:  http://ix.io/1Lit
The issue is your SD card boot has to remain mounted to /boot ... if you removed things from fstab or your initial installation was very very old upgrade might not work properly.
Copy /boot from SSD to /boot on SD card and it should be fine.
