cvxx Posted June 26, 2019 Share Posted June 26, 2019 Hi, as it is quite hot now in Europe, one of my boards is experiencing overheat and shuts down automatically: Jun 25 16:52:27 localhost kernel: [74505.568246] thermal thermal_zone0: critical temperature reached (90 C), shutting down Who is initiating this shutdown? Is it possible to: 1. Change the temperature value that triggers the shutdown 2. Hook a script instead of direct shutdown so I can handle the overheat Thanks Link to comment Share on other sites More sharing options...
0 Igor Posted June 26, 2019 Share Posted June 26, 2019 Without armbianmonitor -u nobody believe this really happened Link to comment Share on other sites More sharing options...
0 cvxx Posted June 30, 2019 Author Share Posted June 30, 2019 https://pastebin.com/AAvCYVkd Note that the script reports it's 26 C, but kernel reports different: Quote $ cat /sys/class/thermal/thermal_zone0/temp 56144 Link to comment Share on other sites More sharing options...
0 MTh Posted November 22, 2019 Share Posted November 22, 2019 (edited) Same problem. Some task's cause error info about thermal data and system going to shutdown. Edited November 22, 2019 by MTh Image added Link to comment Share on other sites More sharing options...
0 Igor Posted November 22, 2019 Share Posted November 22, 2019 9 minutes ago, MTh said: Same problem. Some task's cause error info about thermal data and system going to shutdown. Also after this? Link to comment Share on other sites More sharing options...
0 MTh Posted November 22, 2019 Share Posted November 22, 2019 13 minutes ago, Igor said: Also after this? Yes, after update to bionic distr. mth@orangepizero:~$ uname -a Linux orangepizero 4.19.62-sunxi #5.92 SMP Wed Jul 31 22:07:23 CEST 2019 armv7l armv7l armv7l GNU/Linux Previous distr (jessie) - working fine. Link to comment Share on other sites More sharing options...
0 Igor Posted November 22, 2019 Share Posted November 22, 2019 1 hour ago, MTh said: Yes Latest kernel is 5.3.y ... read text on that link. Link to comment Share on other sites More sharing options...
Question
cvxx
Is it possible to:
Thanks
Link to comment
6 answers to this question
