tkaiser Posted June 27, 2015 Posted June 27, 2015 Hi, I just started to fiddle around with my Cubietruck (since I exchanged it with a Banana Pi for productive stuff). I had to realize that /sys/devices/system/cpu/cpu0/cpufreq/ is missing and that cpufreq-info outputs "no or unknown cpufreq driver is active on this CPU" correctly. Anyone else seeing this behaviour? Cpufreq support should be back with 4.0? Based on a sysbench run ("sysbench --test=cpu --cpu-max-prime=5000 run --num-threads=2" -- takes 58 seconds) I would suppose it's running not even at 960 MHz (since 960 should finish in less than 54 seconds). I did some iperf tests (not that promising, just 600/650 Mbits/sec) and iozone with my usual test SSD (writes below 40MB/s, reads max out at 130MB/s). Am I'm right and the u-boot defaults [1] remain unpatched in this image? Does anyone have tested out other CONFIG_GMAC_TX_DELAY values? Thx, Thomas [1] Cubietruck_defconfig: CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12),USB_EHCI" CONFIG_FDTFILE="sun7i-a20-cubietruck.dtb" CONFIG_GMAC_TX_DELAY=1 CONFIG_VIDEO_VGA=y CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=127 CONFIG_DRAM_EMR1=4
tkaiser Posted June 27, 2015 Author Posted June 27, 2015 I did an upgrade to 4.1 (using the tar archive Igor supplied a few days ago) but that didn't change anything (expect the funny temperature readouts): root@cubietruck:~# uname -a Linux cubietruck 4.1.0-bananapi #26 SMP Wed Jun 24 09:25:45 CEST 2015 armv7l GNU/Linux root@cubietruck:~# zgrep CPUFREQ /proc/config.gz CONFIG_CPUFREQ_DT=y # CONFIG_ARM_KIRKWOOD_CPUFREQ is not set CONFIG_QORIQ_CPUFREQ=m root@cubietruck:~# zgrep CPU_THERMAL /proc/config.gz # CONFIG_CPU_THERMAL is not set I still have no /sys/devices/system/cpu/cpu0/cpufreq/ dir. Maybe related to 'CPU_THERMAL'? And installing to NAND also doesn't work : root@cubietruck:~# /root/nand-sata-install No targets avaliable! Hmm... seems a lot of things to consider are waiting on the Cubietruck
Igor Posted June 28, 2015 Posted June 28, 2015 The last build was done quickly so I made just boot test. Since cpufrequency scaling is working on Banana with the same kernel the problem must be elsewhere. DTB? Try boot with altered banana DTB. Am I'm right and the u-boot defaults [1] remain unpatched in this image? Does anyone have tested out other CONFIG_GMAC_TX_DELAY values? Yes, it's possible that it's not needed. And installing to NAND also doesn't work I think it's already done but not stable yet.
tkaiser Posted June 28, 2015 Author Posted June 28, 2015 Since cpufrequency scaling is working on Banana with the same kernel the problem must be elsewhere. DTB? Try boot with altered banana DTB. Just made a diff between sun7i-a20-bananapi.dts and sun7i-a20-cubietruck.dts and found only one suspicious looking difference (since all the other stuff seems to be related to differing hardware and pin mappings): &i2c0 { pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins_a>; status = "okay"; axp209: pmic@34 { compatible = "x-powers,axp209"; reg = <0x34>; interrupt-parent = <&nmi_intc>; interrupts = <0 IRQ_TYPE_LEVEL_LOW>; interrupt-controller; #interrupt-cells = <1>; }; }; (only "compatible = "x-powers,axp209";" was missing in cubietruck's .dts but this should be unrelated to cpufreq stuff). I also searched the web but to no avail. I'll give up here for the moment and try to get Armbian into NAND using LiveSuite.
tkaiser Posted July 3, 2015 Author Posted July 3, 2015 Update: Still missing with Cubietruck_Debian_4.0_wheezy_4.1.1 -- I will try out replacing .dtb files later this weekend.
andrew Posted July 23, 2015 Posted July 23, 2015 I am having the same problem. Did you ever figure out how to get cpufreq to working on the Cubietruck?
tkaiser Posted July 23, 2015 Author Posted July 23, 2015 I am having the same problem. Did you ever figure out how to get cpufreq to working on the Cubietruck? Nope, didn't even tried it due to focus on other problems (strange network performance stuff I'm currently after).
tkaiser Posted July 24, 2015 Author Posted July 24, 2015 FYI: https://groups.google.com/forum/#!topic/linux-sunxi/ld7lem8QTv0
tkaiser Posted July 24, 2015 Author Posted July 24, 2015 I am having the same problem. Did you ever figure out how to get cpufreq to working on the Cubietruck? Seems to be related to CONFIG_REGULATOR_AXP20X -- compare with the thread mentioned above. In the cubietruck's device tree CPU voltage scaling is also enabled but Igor's kernel config reads 'CONFIG_REGULATOR_AXP20X not set' at the moment. So Igor pointed already in the right direction and I missed these obvious differences between both .dts completely :-\ You should try to build the kernel yourself using CONFIG_REGULATOR_AXP20X=y (or watch the aforementioned thread whether Leonardo provides informations what went wrong in his case -- the Debian kernel builds this stuff as a module and that seems to not load correctly -- so you might also be able to compile the module).
tkaiser Posted July 24, 2015 Author Posted July 24, 2015 Everything now works as expected: root@cubietruck:~# uname -a Linux cubietruck 4.1.2-cubietruck #16 SMP Fri Jul 24 18:43:14 CEST 2015 armv7l GNU/Linux root@cubietruck:~# zgrep CONFIG_REGULATOR_AXP20X /proc/config.gz CONFIG_REGULATOR_AXP20X=y root@cubietruck:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies 312000 528000 720000 864000 912000 960000 I added a request for enhancement on Igor's github and provide the kernel dpkgs temporarely here: http://kaiser-edv.de/tmp/4.1.2-cubietruck-next.tar
Igor Posted July 24, 2015 Posted July 24, 2015 Thomas, thanks for assistance on this. I am already building 4.1.3 with - I hope - all requests and changing u-boot to latest stable 2015.07 ... I'll do basic testings and double check to fix all known issues before releasing.
tkaiser Posted July 26, 2015 Author Posted July 26, 2015 Maybe it's a good idea to wait for feedback regarding stability issues with AP6181 -- compare with http://www.bananapi.com/index.php/forum/general-discussion-for-bpi-m2/995-working-wifi-on-modern-kernels-4-1-tested?start=24#2903please
Igor Posted July 26, 2015 Posted July 26, 2015 Sure. In the mean time I am preparing deb repository so if everything went ok, next build will be apt-get update-able.
tkaiser Posted July 28, 2015 Author Posted July 28, 2015 Sure. In the mean time I am preparing deb repository so if everything went ok, next build will be apt-get update-able. That sounds great. BTW: Testing with 4.2-rc3 I always ended up relinking /boot/zImage manually (no idea why). BTW: The sunxi-mmc patch seems to work so I would propose an immediate inclusion: http://www.bananapi.com/index.php/forum/general-discussion-for-bpi-m2/995-working-wifi-on-modern-kernels-4-1-tested?start=30#3038
Igor Posted July 28, 2015 Posted July 28, 2015 That sounds great. BTW: Testing with 4.2-rc3 I always ended up relinking /boot/zImage manually (no idea why). BTW: The sunxi-mmc patch seems to work so I would propose an immediate inclusion: http://www.bananapi.com/index.php/forum/general-discussion-for-bpi-m2/995-working-wifi-on-modern-kernels-4-1-tested?start=30#3038 No idea either . I'll take a look. I am fixing the whole build structure. BTW: apt-get update works now . Need some more testing to make sure. sunx-mmc patch caused an build error on 4.1.3 .. huh
