Today I did want to compile a image, but at the start of creating the image I do get the following messages:
[ o.k. ] Downloading sources
[ o.k. ] Checking git sources [ u-boot v2019.04 ]
fatal: read error: Connection reset by peer
[ .... ] Fetching updates
[ .... ] Checking out
error: pathspec 'FETCH_HEAD' did not match any file(s) known to git.
after that lines the compile do work like there is no problem.....
BTW: inside the image creation I also do get the value-changes for apt & buster:
E: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'stable'
E: Repository 'http://httpredir.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'testing-updates' to 'stable-updates'
E: Repository 'http://security.debian.org buster/updates InRelease' changed its 'Suite' value from 'testing' to 'stable'
I dont know if they would be accepted in the script because of the E: (for Error)?
I have the same problem.
And the compilation ends with an error.
Yesterday everything was fine.
[ o.k. ] Checking git sources [ u-boot v2018.05 ]
[ .... ] Creating local copy
[ o.k. ] Checking git sources [ linux-sun8i sun8i ]
remote: Enumerating objects: 45974, done.
remote: Counting objects: 100% (45974/45974), done.
remote: Compressing objects: 100% (40178/40178), done.
remote: Total 45974 (delta 5234), reused 45827 (delta 5178), pack-reused 0
Receiving objects: 100% (45974/45974), 129.72 MiB | 5.93 MiB/s, done.
Resolving deltas: 100% (5234/5234), done.
From https://github.com/igorpecovnik/linux
 * branch              sun8i      -> FETCH_HEAD
 * [new branch]        sun8i      -> origin/sun8i
[ o.k. ] Checking git sources [ sunxi-tools master ]
remote: Enumerating objects: 88, done.
remote: Counting objects: 100% (88/88), done.
remote: Compressing objects: 100% (83/83), done.
remote: Total 88 (delta 14), reused 36 (delta 4), pack-reused 0
Unpacking objects: 100% (88/88), done.
From https://github.com/linux-sunxi/sunxi-tools
 * branch            master     -> FETCH_HEAD
 * [new branch]      master     -> origin/master
[ o.k. ] Checking git sources [ rkbin-tools master ]
remote: Enumerating objects: 333, done.
remote: Counting objects: 100% (333/333), done.
remote: Compressing objects: 100% (235/235), done.
remote: Total 333 (delta 105), reused 309 (delta 97), pack-reused 0
Receiving objects: 100% (333/333), 27.92 MiB | 5.71 MiB/s, done.
Resolving deltas: 100% (105/105), done.
From https://github.com/armbian/rkbin
[ o.k. ] Checking git sources [ marvell-tools A3700_utils-armada-18.12 ]
remote: Enumerating objects: 289, done.
remote: Counting objects: 100% (289/289), done.
remote: Compressing objects: 100% (156/156), done.
remote: Total 289 (delta 147), reused 210 (delta 130), pack-reused 0
Receiving objects: 100% (289/289), 5.78 MiB | 4.64 MiB/s, done.
Resolving deltas: 100% (147/147), done.
From https://github.com/MarvellEmbeddedProcessors/A3700-utils-marvell
 * branch            A3700_utils-armada-18.12 -> FETCH_HEAD
 * [new branch]      A3700_utils-armada-18.12 -> origin/A3700_utils-armada-18.12
[ o.k. ] Checking git sources [ marvell-ddr mv_ddr-armada-18.12 ]
remote: Enumerating objects: 120, done.
remote: Counting objects: 100% (120/120), done.
remote: Compressing objects: 100% (112/112), done.
remote: Total 120 (delta 54), reused 16 (delta 4), pack-reused 0
Receiving objects: 100% (120/120), 1.48 MiB | 3.11 MiB/s, done.
Resolving deltas: 100% (54/54), done.
From https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell
 * branch            mv_ddr-armada-18.12 -> FETCH_HEAD
 * [new branch]      mv_ddr-armada-18.12 -> origin/mv_ddr-armada-18.12
[ o.k. ] Checking git sources [ marvell-binaries binaries-marvell-armada-18.12 ]
remote: Enumerating objects: 4, done.
remote: Counting objects: 100% (4/4), done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 4 (delta 0), reused 3 (delta 0), pack-reused 0
Unpacking objects: 100% (4/4), done.
From https://github.com/MarvellEmbeddedProcessors/binaries-marvell
 * branch            binaries-marvell-armada-18.12 -> FETCH_HEAD
 * [new branch]      binaries-marvell-armada-18.12 -> origin/binaries-marvell-armada-18.12
[ o.k. ] Checking git sources [ odroidc2-blobs master ]
remote: Enumerating objects: 32, done.
remote: Counting objects: 100% (32/32), done.
remote: Compressing objects: 100% (31/31), done.
remote: Total 32 (delta 1), reused 29 (delta 1), pack-reused 0
Unpacking objects: 100% (32/32), done.
From https://github.com/armbian/odroidc2-blobs
[ o.k. ] Checking git sources [ testing-reports master ]
remote: Enumerating objects: 139, done.
remote: Counting objects: 100% (139/139), done.
remote: Compressing objects: 100% (81/81), done.
remote: Total 139 (delta 62), reused 115 (delta 56), pack-reused 0
Receiving objects: 100% (139/139), 34.42 KiB | 370.00 KiB/s, done.
Resolving deltas: 100% (62/62), done.
From https://github.com/armbian/testings
[ o.k. ] Compiling [ sunxi-tools ]
Setting version information: 42ffc5f
[ o.k. ] Installing [ rkbin-tools ]
[ o.k. ] Cleaning output/debs for [ orangepizero default ]
[ o.k. ] Cleaning [ u-boot/v2018.05 ]
grep: /home/user/development/armbian/build/cache/sources/u-boot/v2018.05/Makefile: No such file or directory
[ o.k. ] Compiling u-boot [ 0 ]
[ o.k. ] Compiler version [ arm-linux-gnueabihf-gcc 7.4.1 ]
[ .... ] Checking out sources
error: pathspec 'HEAD' did not match any file(s) known to git.
[ o.k. ] Started patching process for [ u-boot sun8i-orangepizero-default ]
[ o.k. ] Looking for user patches in [ userpatches/u-boot/u-boot-sunxi-legacy ]
[ warn ] * [l][c] 0020-sunxi-call-fdt_fixup_ethernet-again-to-set-macaddr-f.patch [ failed ]
[ warn ] * [l][c] 4kfix-limit-screen-to-full-hd.patch [ failed ]
[ o.k. ] * [l][c] Merrii_Hummingbird_A20.patch
[ warn ] * [l][c] add-a20-olinuxino-micro-emmc-support.patch [ failed ]
[ warn ] * [l][c] add-a20-optional-eMMC.patch [ failed ]
[ o.k. ] * [l][c] add-awsom-defconfig.patch
[ warn ] * [l][c] add-bananapi-bpi-zero.patch [ failed ]
[ warn ] * [l][c] add-beelink-x2.patch [ failed ]
[ warn ] * [l][c] add-emmc_support_to_neo1_and_2.patch [ failed ]
[ warn ] * [l][c] add-nanopi-air-emmc.patch [ failed ]
[ warn ] * [l][c] add-nanopi-duo.patch [ failed ]
[ warn ] * [l][c] add-nanopi-m1-plus2-emmc.patch [ failed ]
[ warn ] * [l][c] add-nanopineoplus2.patch [ failed ]
[ warn ] * [l][c] add-orangepi-plus2-emmc.patch [ failed ]
[ warn ] * [l][c] add-orangepi-zero-usb-boot-support.patch [ failed ]
[ warn ] * [l][c] add-orangepi-zeroplus.patch [ failed ]
[ warn ] * [l][c] add-orangepi-zeroplus2_h3.patch [ failed ]
[ warn ] * [l][c] add-sunvell-r69.patch [ failed ]
[ warn ] * [l][c] add-tritium-series.patch [ failed ]
[ warn ] * [l][c] add-xx-boot-auto-dt-select-neo2.patch [ failed ]
[ warn ] * [l][c] add-xx-nanopi-k1-plus-emmc.patch [ failed ]
[ warn ] * [l][c] add-xx-nanopineocore2.patch [ failed ]
[ warn ] * [l][c] add_emmc_olinuxino_a64.patch [ failed ]
[ warn ] * [l][c] add_emmc_orangepiwin.patch [ failed ]
[ warn ] * [l][c] adjust-default-dram-clockspeeds.patch [ failed ]
[ warn ] * [l][c] adjust-small-boards-cpufreq.patch [ failed ]
[ warn ] * [l][b] do-not-relocate-initrd.patch [ failed ]
[ warn ] * [l][c] enable-DT-overlays-support.patch [ failed ]
[ warn ] * [l][c] enable-autoboot-keyed.patch [ failed ]
[ warn ] * [l][c] enable-ethernet-orangepiprime.patch [ failed ]
[ warn ] * [l][b] enable-old-kernel-compat.patch [ failed ]
[ warn ] * [l][c] enable-r_pio-gpio-access-h3-h5.patch [ failed ]
[ warn ] * [l][c] fdt-setprop-fix-unaligned-access.patch [ failed ]
[ warn ] * [l][c] fix-usb1-vbus-opiwin.patch [ failed ]
[ warn ] * [l][c] h3-Fix-PLL1-setup-to-never-use-dividers.patch [ failed ]
[ warn ] * [l][c] h3-enable-power-led.patch [ failed ]
[ warn ] * [l][c] h3-set-safe-axi_apb-clock-dividers.patch [ failed ]
[ warn ] * [l][c] lower-default-DRAM-freq-A64-H5.patch [ failed ]
[ warn ] * [l][c] sun8i-set-machid.patch [ failed ]
[ warn ] * [l][c] sunxi-boot-splash.patch [ failed ]
sed: can't read .config: No such file or directory
[ error ] ERROR in function compile_uboot [ compilation.sh:199 ]
[ error ] U-boot compilation failed
[ o.k. ] Process terminated
Network issue, can't download stuff from Microsoft :D Github.
