cubox-i;buster;nftables.services doesn't start after reboot
Armbianmonitor:
I just switched from iptables to netfilter.
After a reboot I get this kind of status for the service
systemctl status nftables
● nftables.service - nftables
   Loaded: loaded (/lib/systemd/system/nftables.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Fri 2019-07-12 16:04:59 CEST; 4min 28s ago
     Docs: man:nft(8)
           http://wiki.nftables.org
  Process: 287 ExecStart=/usr/sbin/nft -f /etc/nftables.conf (code=exited, status=3)
 Main PID: 287 (code=exited, status=3)
Jul 12 16:04:59 cubox nft[287]: netlink.c:62: Unable to initialize Netlink socket: Protocol not supported
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
nftables installed ?
p  libnftables-dev - Development files for libnftables
i A libnftables0 - Netfilter nftables high level userspace API library
i  nftables - Program to control packet filtering rules by Netfilter project
update alternatives setup
ip6tables                      auto     /usr/sbin/ip6tables-nft
iptables                       auto     /usr/sbin/iptables-nft
Anyway, a manual restart of the service works and the rules in /etc/nftables.conf are load properly.
I suppose there is a problem with a kernel module?
Doing the same upgrade on raspberries worked :
Linux bowerick 4.19.50-v7+ #896 SMP Thu Jun 20 16:11:44 BST 2019 armv7l GNU/Linux
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Possible.
I would do it this way, but you can also do it. Compare cubox-i kernel config with the one from RPi .. and prepare a PR with missing components in and around NETFILTER section.
(1) https://superuser.com/questions/287371/obtain-kernel-config-from-currently-running-linux-system
(2) https://docs.armbian.com/Process_Contribute/
(3) https://github.com/armbian/build/tree/master/config/kernel (try to fix also for 5.1.y kernel)
17 hours ago, Igor said:
Possible.
In the meantime I found a workaround by inserting
cat /etc/rc.local
systemctl restart nftables
exit 0
Anyway, my first idea of a missing driver, is probably not correct:
It doesn't explain the correct working restart of nftables.service, when the system is up.
Regarding to your approach:
raspian and cubox is different hardware, so will the comparison really be helpfull?
cubox
lshw -c network
  *-network:0 DISABLED
       description: Ethernet interface
       physical id: 3
       logical name: dummy0
       serial: 92:c8:2f:98:51:2c
       capabilities: ethernet physical
       configuration: broadcast=yes driver=dummy driverversion=1.0
  *-network:1
       description: Wireless interface
       physical id: 4
       logical name: wlan0
       serial: 6c:ad:f8:1d:95:8b
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=brcmfmac driverversion=5.90.125.104 firmware=5.90.125.104 multicast=yes wireless=IEEE 802.11
  *-network:2
       physical id: 5
       logical name: eth0
       serial: d0:63:b4:00:c4:0f
       capacity: 1Gbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=fec driverversion=Revision: 1.0 duplex=full ip=nnn.nnn.nnn.nnn link=yes multicast=yes port=MII speed=1Gbit/s
raspberry
lshw -c network
  *-usb:0
       vendor: Standard Microsystems Corp.
       physical id: 1
       bus info: usb@1:1.1.1
       logical name: eth0
       version: 3.00
       serial: b8:27:eb:6c:7d:7d
       capacity: 1Gbit/s
       capabilities: usb-2.10 ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=lan78xx duplex=full ip=nnn.nnn.nnn.nnn link=yes maxpower=2mA multicast=yes port=MII speed=1Gbit/s
  *-network
       physical id: 2
       logical name: wlan0
       serial: b8:27:eb:39:28:28
       configuration: broadcast=yes driver=brcmfmac driverversion=7.45.154 firmware=01-4fbe0b04 multicast=yes wireless=IEEE 802.11
Anyway I compared the netfilter section  as you suggested:
raspian config.gz exists after
sudo modprobe configs
diff -y -W 200 --suppress-common-lines raspian_nf cubox_nf
# CONFIG_NF_LOG_NETDEV is not set                                   |    CONFIG_NF_LOG_NETDEV=m
        >    CONFIG_NF_CONNTRACK_SECMARK=y
# CONFIG_NF_CONNTRACK_TIMEOUT is not set                            |    CONFIG_NF_CONNTRACK_TIMEOUT=y
CONFIG_NF_CT_PROTO_GRE=m                                            |    CONFIG_NF_CT_PROTO_GRE=y
        >    CONFIG_NF_CT_NETLINK_TIMEOUT=m
CONFIG_NF_NAT_PROTO_DCCP=y                                          <
CONFIG_NF_NAT_PROTO_UDPLITE=y                                       <
CONFIG_NF_NAT_PROTO_SCTP=y                                          <
        >    CONFIG_NF_NAT_MASQUERADE=y
        >    CONFIG_NETFILTER_SYNPROXY=m
        >    CONFIG_NFT_XFRM=m
CONFIG_NF_DUP_NETDEV=m                                              |    # CONFIG_NF_DUP_NETDEV is not set
CONFIG_NFT_DUP_NETDEV=m                                             |    # CONFIG_NFT_DUP_NETDEV is not set
CONFIG_NFT_FWD_NETDEV=m                                             |    # CONFIG_NFT_FWD_NETDEV is not set
        >    CONFIG_NETFILTER_XT_TARGET_AUDIT=m
        >    CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=m
        >    CONFIG_NETFILTER_XT_TARGET_SECMARK=m
# CONFIG_NETFILTER_XT_MATCH_CGROUP is not set                       |    CONFIG_NETFILTER_XT_MATCH_CGROUP=m
# CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set                       |    CONFIG_NETFILTER_XT_MATCH_IPCOMP=m
# CONFIG_IP_SET_HASH_IPMARK is not set                              |    CONFIG_IP_SET_HASH_IPMARK=m
# CONFIG_IP_SET_HASH_IPMAC is not set                               |    CONFIG_IP_SET_HASH_IPMAC=m
# CONFIG_IP_SET_HASH_MAC is not set                                 |    CONFIG_IP_SET_HASH_MAC=m
# CONFIG_IP_SET_HASH_NETPORTNET is not set                          |    CONFIG_IP_SET_HASH_NETPORTNET=m
# CONFIG_IP_SET_HASH_NETNET is not set                              |    CONFIG_IP_SET_HASH_NETNET=m
# CONFIG_IP_VS_IPV6 is not set                                      |    CONFIG_IP_VS_IPV6=y
To be honest, I have no idea of all that options.
Just stumbled across something inconsistent after replacing iptables with nftables (the default on debian buster 10):
 A check with lynis gave me a warning about the "leftover" iptables package:
 -[ Lynis 2.7.5 Results ]-
  Warnings (2):
  ! iptables module(s) loaded, but no rules active [FIRE-4512]
      https://cisofy.com/lynis/controls/FIRE-4512/
Is this dependency necessary?
 aptitude purge iptables
The following packages will be REMOVED:
  iptables{p}
0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 1.444 kB will be freed.
The following packages have unmet dependencies:
 armbian-config : Depends: iptables but it is not going to be installed
The following actions will resolve these dependencies:
     Remove the following packages:
1)     armbian-config [5.90 (buster, now)]
 -[ Lynis 2.7.5 Results ]- Warnings (2): ----------------------------[...] ! iptables module(s) loaded, but no rules active [FIRE-4512]      https://cisofy.com/lynis/controls/FIRE-4512/
 aptitude purge iptablesThe following packages will be REMOVED:   iptables{p} 0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded.Need to get 0 B of archives. After unpacking 1.444 kB will be freed.The following packages have unmet dependencies:armbian-config : Depends: iptables but it is not going to be installedThe following actions will resolve these dependencies:    Remove the following packages:       1)     armbian-config [5.90 (buster, now)]
Hey Wanda
I found this. Not sure what it would take to reconcile.
https://github.com/armbian/config/blob/167e0dc2d81a2327c05740c5abfc6fa1fd99f9d9/debian-config-functions-network#L613
Sent from my iPad using Tapatalk
On 7/15/2019 at 4:52 AM, lanefu said:
Hi, thanks for the hint. To be honest  I don't get the content of the link, I mean referring to my question about the package dependency armbian-config and iptables.
nft list ruleset (without any f2b-entry) is fine, it will be created with the first ban action.
