Morigal Posted May 23, 2015 Share Posted May 23, 2015 Hello, I'm using the Wheezy Image with Kernel 3.4.107-cubietruck, downloaded 25th May 2015, on my Cubietruck. Working through the Guide "Enable Access point mode" I ended up having a running hostapd with a ESSID which my clients can see but can not connect. I tried with default config given by the image (ssid=cubietruck and wpa=2 with wpa_passphrase=12345678). I also tried disabling wpa (wpa=0). But no client can connect. Starting "hostapd /etc/hostapd.conf" prints root@cubietruck:~# hostapd /etc/hostapd.conf Configuration file: /etc/hostapd.conf nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory) Using interface wlan0 with hwaddr 02:1a:11:f2:53:57 and ssid "cubietruck" wlan0: interface state UNINITIALIZED->ENABLED wlan0: AP-ENABLED wlan0: STA d4:8f:33:c1:65:74 IEEE 802.11: associated wlan0: AP-STA-CONNECTED d4:8f:33:c1:65:74 wlan0: STA d4:8f:33:c1:65:74 RADIUS: starting accounting session 5560CD08-00000000 wlan0: STA d4:8f:33:c1:65:74 IEEE 802.11: disassociated wlan0: AP-STA-DISCONNECTED d4:8f:33:c1:65:74 ^Cwlan0: interface state ENABLED->DISABLED wlan0: AP-DISABLED nl80211: deinit ifname=wlan0 disabled_11b_rates=0 The bold text is what I get, when a clients tries to connect. Any idea how to make hostapd work? Link to comment Share on other sites More sharing options...
Igor Posted May 23, 2015 Share Posted May 23, 2015 Cubietruck has one exception and only with kernel 3.4.x - wifi module must be loaded (/etc/modules) this way to enable AP mode: bcmdhd op_mode=2 I suggest you to use this predefined configuration - which you probably already set. /etc/network/interfaces.hostapd You need to have some DHCP server running on the network - which usually is. 1 Link to comment Share on other sites More sharing options...
Morigal Posted May 23, 2015 Author Share Posted May 23, 2015 I changed my /etc/interfaces according to your suggest and it works. Thanks alot. 1 Link to comment Share on other sites More sharing options...
GrandPeter Posted June 8, 2015 Share Posted June 8, 2015 Hello, Igor! Please Help me setting hostapp. I'm using the Wheezy and jessie Image with Kernel 3.4.107 OrangePi mini root@orangepi:~# cat /etc/network/interfaces auto lo br0iface lo inet loopbackallow-hotplug eth0iface eth0 inet manualallow-hotplug wlan0iface wlan0 inet manualiface br0 inet dhcpbridge_ports eth0 wlan0#hwaddress ether # will be added at first boot root@orangepi:~# ifconfig br0 Link encap:Ethernet HWaddr 00:e0:4c:1c:1c:1c inet addr:10.0.0.75 Bcast:10.0.0.255 Mask:255.255.255.0 inet6 addr: fe80::2e0:4cff:fea2:1c1c/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:185883 errors:0 dropped:0 overruns:0 frame:0 TX packets:6456 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:13922051 (13.2 MiB) TX bytes:621324 (606.7 KiB)eth0 Link encap:Ethernet HWaddr 02:17:04:61:61:80 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:208530 errors:0 dropped:633 overruns:0 frame:0 TX packets:6617 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:21024049 (20.0 MiB) TX bytes:719634 (702.7 KiB) Interrupt:117lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:9 errors:0 dropped:0 overruns:0 frame:0 TX packets:9 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:1216 (1.1 KiB) TX bytes:1216 (1.1 KiB)wlan0 Link encap:Ethernet HWaddr 00:e0:4c:1c:1c:1c UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 root@orangepi:~# iwlist wlan0 scan wlan0 Scan completed : Cell 01 - Address: 00:1A:70:32:19:C8 ESSID:"Europol" Protocol:IEEE 802.11bg Mode:Master Frequency:2.462 GHz (Channel 11) Encryption key:on Bit Rates:54 Mb/s Extra:rsn_ie=30140100000fac040100000fac040100000fac020000 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=0/100 Signal level=-64 dBm Cell 02 - Address: 00:1A:70:32:50:E8 ESSID:"europol_learnroom" Protocol:IEEE 802.11bg Mode:Master Frequency:2.462 GHz (Channel 11) Encryption key:on Bit Rates:54 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2040050f20201000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK Extra:rsn_ie=30180100000fac020200000fac04000fac020100000fac020000 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK Quality=101/100 Signal level=-71 dBm root@orangepi:~# iwconfig lo no wireless extensions.br0 no wireless extensions.tunl0 no wireless extensions.wlan0 unassociated Nickname:"<WIFI@REALTEK>" Mode:Auto Frequency=2.412 GHz Access Point: Not-Associated Sensitivity:0/0 Retry:off RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=0/100 Signal level=0 dBm Noise level=0 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0eth0 no wireless extensions.bond0 no wireless extensions. root@orangepi:~# hostapd /etc/hostapd.conf Configuration file: /etc/hostapd.confnl80211: deinit ifname=wlan0 disabled_11b_rates=0nl80211 driver initialization failed.wlan0: interface state UNINITIALIZED->DISABLEDwlan0: AP-DISABLED hostapd_free_hapd_data: Interface wlan0 wasn't started root@orangepi:~# hostapd /etc/hostapd.conf-rt Configuration file: /etc/hostapd.conf-rtLine 10: invalid/unknown driver 'rtl871xdrv'1 errors found in configuration file '/etc/hostapd.conf-rt'Failed to set up interface with /etc/hostapd.conf-rtFailed to initialize interface Link to comment Share on other sites More sharing options...
Igor Posted June 8, 2015 Share Posted June 8, 2015 You need to use rt-patched hostapd: hostapd-rt /etc/hostapd.conf-rt 1 Link to comment Share on other sites More sharing options...
GrandPeter Posted June 9, 2015 Share Posted June 9, 2015 Thanks it worked! Link to comment Share on other sites More sharing options...
