sunzone Posted July 23, 2019 Posted July 23, 2019 Hi. I am trying to control an i2c device at the u-boot stage. i2c 0 bus is activated through /boot/armbianEnv.txt file After settings some i2c commands at /boot/boot.cmd i checked the i2c sdk and sda pins via an oscilloscope. But neither output a signal. i2c dev 0 i2c mw 0x3c 0x00 0xae I included above commands and tested. Can I know how to activate or use i2c at u-boot level? image: ARMBIAN 5.75 stable Ubuntu 18.04.2 LTS 4.19.38-sunxi
Igor Posted July 23, 2019 Posted July 23, 2019 On 7/23/2019 at 10:04 AM, sunzone said: Can I know how to activate or use i2c at u-boot level? Expand I haven't tried I2C in u-boot ... but in any case you need to recompile with enabled support for it. I am not sure if its enabled by default. Try this way: ./compile.sh CREATE_PATCHES="yes" and when you will be asked for changes go to sources/u-boot/v2019.04/ and run make menuconfig ... enable i2c, go out, save config and return to the build script and proceed. Install u-boot package from output/deb Then run armbian-config -> system -> intstall & update u-boot -> choose update u-boot ... reboot into new u-boot. You can do this also on your board. Cloning sources, applying patches, default config, enabling i2c, flashing bootloader with dd following by reboot.
