1001er1001 Posted July 26, 2019 Posted July 26, 2019 I have orange pi pc+. i downloaded armbian bionic with kernel 4.19, when I connect an ethernet cable sometimes, he doesn't see it, when he see it i have very slow connection, even wifi faster than ethernet, what can I do?
Igor Posted July 26, 2019 Posted July 26, 2019 20 minutes ago, 1001er1001 said: what can I do? Have you tried different cables? Perhaps your switch / router is the troublemaker? There are many many users of Orangepi PC+ and I have't heard of any troubles with a NIC. Hardware failure is also possible, but that is not an Armbian problem anymore.
1001er1001 Posted July 26, 2019 Author Posted July 26, 2019 1 minute ago, Igor said: Have you tried different cables? Perhaps your switch / router have is the troublemaker? There are many many users of Orangepi PC+ and I have't heard of any troubles with a NIC. Hardware failure is also possible, but that is not Armbian problem. Yes, I tried different cables and even reconnected to different plugs in the router
Igor Posted July 26, 2019 Posted July 26, 2019 What about legacy kernel (3.4.y) images? Is the problem also present there?
1001er1001 Posted July 26, 2019 Author Posted July 26, 2019 7 minutes ago, Igor said: What about legacy kernel (3.4.y) images? Is the problem also present there? I have not tried kernel 3.4.y, because my orange pi pc + is in another house and I can’t connect to it because of very slow internet. when i tried sudo apt-get update i got an error, but when i used wifi i don't have this error
1001er1001 Posted July 27, 2019 Author Posted July 27, 2019 18 hours ago, Igor said: What about legacy kernel (3.4.y) images? Is the problem also present there? When i start installation armbian xenial:
1001er1001 Posted July 27, 2019 Author Posted July 27, 2019 18 hours ago, Igor said: What about legacy kernel (3.4.y) images? Is the problem also present there? but when i start installation armbian buster i don't have problem same as on top
Igor Posted July 27, 2019 Posted July 27, 2019 3 hours ago, 1001er1001 said: When i start installation armbian xenial It's normal that you get error regarding network "wait-online" here if you are not online. Attached network where your DHCP server is operational and do some tests ... 1
1001er1001 Posted July 27, 2019 Author Posted July 27, 2019 5 hours ago, Igor said: It's normal that you get error regarding network "wait-online" here if you are not online. Attached network where your DHCP server is operational and do some tests ... I reinstalled armbian bionic, it was installed without a graphical shell and it works great, the problem is solved
