hatahata Posted May 2, 2016 Posted May 2, 2016 Hi all at present state , i installed slim or gdm , but they are not good to start GUI automatically . so i start GUI by startx . what display manager is good for ondroid-c2 ? cat .xinitrcstartxfce4 --- regards i write the install steps at http://odroid-akita.blogspot.jp/2016/04/odoroid-c2.html (japanese input is OK)
Igor Posted May 3, 2016 Posted May 3, 2016 In theory any is good but arm64 lack of some packages so you might run into problems. Use our desktop build and be prepared. C2 is not yet fully stable and arm64 was introduced not long ago.
hatahata Posted May 4, 2016 Author Posted May 4, 2016 i tried to install arch linux on odoroid-c2 . alike armbian , slim can not boot GUI .
Igor Posted May 4, 2016 Posted May 4, 2016 C2 still has some fundamental bugs. Workaround: https://github.com/igorpecovnik/lib/blob/master/scripts/c2_init.sh
Vincent Tham Posted September 20, 2017 Posted September 20, 2017 I've found a solution to autostart the lightdm-greeter for user login. Following the steps below: My solution was to run: rm /etc/systemd/system/default.target systemctl set-default graphical.target This will replace the default target file, which in my case must have prevented systemd from reaching the graphical target, with a symlink to the graphical target. After this, lightdm (and gdm when selected with dpkg-reconfigure) starts automatically. /etc/X11/default-display-manager was already set to the correct value so this appears to be a different root cause from OP's. You will have to install the following: # apt install lightdm-gtk-greeter lightdm
