Hi, I am trying to use a tinker board S as a Logitech Media Server for my multi room installation. The server runs well when streaming radio for a whole day or more. As soon as I start to stream music from the attached USB drive it stops after a few minutes for some seconds continuous then and stops again. After a few of this itterations it stops completely. I tryed to install all available server-OS. At the moment I run BIONIC. I looked in the LMS logs but found noothing. As I am new too this kind of topics I do not know how to find the issue. Can you point me in the right direction?
1 hour ago, Greenhouse133456 said:
attached USB drive
Is that USB drive powered externally? If not, do it ... and provide logs with:
armbianmonitor -u
2 hours ago, Greenhouse133456 said:
I have to buy one.
Power issues are not in the log. Maybe you can borrow a powered USB-Hub to test it. I would like to hear about the result
Okay. But previously I had a Raspberry pi 3b+ and it worked fine with the same setup. The only issue with the pi was it could only serve one player at a time and I want to run multiple rooms in parallel. Just for your information, I use a 5V 3A power supply with the tinker board.
when it stops try this command
dmesg | tail -7
To see the last lines of the kernel log and post it here in the Code box
// sent from mobile phone //
root@MusicServer2:~# dmesg | tail -7
[ 8715.488321] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 8715.488930] sd 0:0:0:0: [sda] Write Protect is off
[ 8715.488935] sd 0:0:0:0: [sda] Mode Sense: 47 00 00 08
[ 8715.489553] sd 0:0:0:0: [sda] Disabling FUA
[ 8715.489559] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 8715.498223]  sda: sda1 sda2
[ 8715.500816] sd 0:0:0:0: [sda] Attached SCSI disk
The counter in the web app counts and jumps back about 10 sec then goes on to jump back again. I would be able to start the play back again by jumping to the next title.
I just tried the same setup but instead of connecting an USB storage with my music I connected the server to a NAS system which I run in my network. I works perfect. There seems to be a problem with the USB connection.
