Jeffer Posted August 3, 2019 Posted August 3, 2019 I'm trying to install wiringpi by following the instruction given here https://github.com/Pavelectric/WiringPi_M4. Most of the steps that I followed worked fine but when I do the very last command below, Quote $ sudo easy_install wiringpi-2.44.4-py3.6-linux-aarch64.egg I get a following error, Quote Traceback (most recent call last): File "/usr/local/bin/easy_install", line 11, in <module> load_entry_point('setuptools==33.1.1', 'console_scripts', 'easy_install')() File "/home/pi/.local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 489, in load_entry_point return get_distribution(dist).load_entry_point(group, name) File "/home/pi/.local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2843, in load_entry_point return ep.load() File "/home/pi/.local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2434, in load return self.resolve() File "/home/pi/.local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2440, in resolve module = __import__(self.module_name, fromlist=['__name__'], level=0) File "/usr/local/lib/python3.6/dist-packages/setuptools-33.1.1-py3.6.egg/setuptools/command/easy_install.py", line 51, in <module> File "/usr/local/lib/python3.6/dist-packages/setuptools-33.1.1-py3.6.egg/setuptools/archive_util.py", line 11, in <module> ImportError: cannot import name 'ContextualZipFile' I googled how to deal with this kind of error, and some people tell that 'ContextualZipFile' in archive_util.py doesn't have to be installed so I just need to comment that out. Although, I couldn't find '/usr/local/lib/python3.6/dist-packages/setuptools-33.1.1-py3.6.egg/setuptools/archive_util.py', I did that comment out solution to the all files below, which I got by doing find-command-research Quote /home/pi/Downloads/WiringPi_M4-master/setuptools-33.1.1/build/lib/setuptools/archive_util.py /home/pi/Downloads/WiringPi_M4-master/setuptools-33.1.1/setuptools/archive_util.py /home/pi/.local/lib/python3.6/site-packages/setuptools/archive_util.py /home/pi/.pyenv/versions/3.5.6/lib/python3.5/site-packages/setuptools/archive_util.py Now I don't know what to do here... It is very nice if anyone can help me get out of this darkness... Thank you,
pavelectric Posted August 3, 2019 Posted August 3, 2019 Good day. First try for Python 2: $ sudo easy_install-2.7 wiringpi-2.44.4-py2.7-linux-aarch64.egg I understand that you need the 3rd Python, but still ...
Jeffer Posted August 19, 2019 Author Posted August 19, 2019 Thank you for replying to my question. After I tried with different .img file, which is nightly I think, everything worked well. I successfully installed wiringpi both in Python2 and Python3. But a problem now is that I get "Segmentation fault" errors when I try to use call back function with wiringpi.wiringPiISR(PIN_TO_SENSE, wiringpi.GPIO.INT_EDGE_BOTH, gpio_callback) in some codes such as shown here https://github.com/WiringPi/WiringPi-Python/blob/master/examples/callback.py. as soon as I command wiringpi.wiringPiISR(PIN_TO_SENSE, wiringpi.GPIO.INT_EDGE_BOTH, gpio_callback) the gpio_callback function which I defined execute some times (typically ~10 times), that segmentation fault error occurs. I have tested it with python2 and python3 as well. Do you have any idea why this happens or maybe how to deal with this? Thank you,
