mario76 Posted August 21, 2019 Share Posted August 21, 2019 Is there way to configure sound over hdmi? Display is working ok (configuration for 1366x768 and 1920x1080 was made manually), but there is no sound. 0 Quote Link to comment Share on other sites More sharing options...
Localhost Posted August 21, 2019 Share Posted August 21, 2019 Unfortunately, No Even for me, the official linux image still does not play sound, but the Android one does. If you want this board to server you media, then go with android. But if you really want to do this on linux, then install something like soundwire and use another piece of hardware to play sound Another option would be using a dedicated sound card, by sacrificing a USB port If you take a look at Linux Mainlining Effort page, you will see that in fact nobody works, niether has worked on audio over hdmi for an allwinner SoC. 0 Quote Link to comment Share on other sites More sharing options...
jernej Posted August 21, 2019 Share Posted August 21, 2019 26 minutes ago, Localhost said: If you take a look at Linux Mainlining Effort page, you will see that in fact nobody works, niether has worked on audio over hdmi for an allwinner SoC. That's not true. HDMI audio works for example LibreELEC images for Allwinner boards (A64, H3 and H6) and there is an effort to mainline support for it. But that's only for newer SoCs, from A83T onwards (all with DW-HDMI core). I guess I should change status on that page. 0 Quote Link to comment Share on other sites More sharing options...
Elt Posted March 15, 2021 Share Posted March 15, 2021 Hi, shouldn't this issue be mentioned on download page? If I would have seen this, I would have bought another card... By the way, 2 years later, still no solution to have sound over HDMI on this card? Thanks 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted March 15, 2021 Share Posted March 15, 2021 2 hours ago, Elt said: shouldn't this issue be mentioned on download page? Not exactly a critical issue worth mentioning. Most of people around here are operating in CLI world anyway. Also, this is amateur / community backed project - if you feel something needs to be changed, like you just expose, welcome to join listening and acting on users demands (nothing personal). There are around 1000x more asking for something, giving nothing in return. 2 hours ago, Elt said: By the way, 2 years later, still no solution to have sound over HDMI on this card? I believe stock Orangepi Debian supports this function since the day one while mainlining - development from scratch mainly on community / developers own expense - takes years and you can't really bother anyone. 0 Quote Link to comment Share on other sites More sharing options...
